#include <intrins.h>      //51基本运算(包括_nop_空函数)
#include <math.h>
#include "src\Define.h"
///////全局变量///////
uchar data DelayTime=9;          //<=8效果最好;
uchar data INTTime=0x40;  //0x40;
uchar data gain=6;
uchar data Menu=2;
uchar idata refreshflag[40];
uchar  data LEDBuf[35];          //15列;从左到右;亮的位为真(1);
uint32  data TouchKey=0;
uchar data CBeep=0;
void Delays(uint t)
        uint j;
        while(--t)
                for(j=0;j<5;j++);
void Delaysms(uint t)
        uint j;
        while(--t)
                for(j=0;j<15;j++);
#include "src\ADC.c"
#include "src\Font.c"
#include "src\fft.h"
void PWM_init (void)          //PWM初始化函数         //PWM模式,接P1.3接口(PWM0),强上拉.
        CMOD=0x00;    //设置PCA定时器          0x00~0x03;
         CL=0xEF;
         CH=0xEF;
        CCAPM0=0x42; //PWM0设置PCA工作方式为PWM方式(0100 0010)
         CCAP0L=0xEF; //设置PWM0初始值与CCAP0H相同
         CCAP0H=0xFF; // PWM0初始时为0
         CR=1;        //启动PCA定时器
void PWM0_set (uchar set)           //PWM0占空比设置函数        (0x00~0xFF)
        CCAP0L= set; //设置值写入CCAP0L
         CCAP0H= set; //设置值写入CCAP0H
void IOINIT(void)                                                          //I/O强上拉模式;
        P4SW = 0xff;                                  //启动I/O:P4;
        P4M1 = B(00000000); P4M0 = B(10000000);P47=0;//震动马达;
        P0M1 = 0x00;            P0M0 = 0xff;       P0=0; //点阵列(Y)(L:OFF; H,H+:ON,ON+;)
        P1M1 = B(01000011); P1M0 = B(00110100);P1=B(10110111); //(P17@(高阻,IN)&P16@(高阻,IN);TouchKey) ... P14@(传统IO,Beep,IN) P13@(强推,OUT)呼吸灯 ... P11@(高阻,IN)AD2;P10@(高阻,IN)AD1;
        P2M1 = B(00000000); P2M0 = B(11111111);P2=0; //点阵行(X0(Left))(L:OFF; H,H+:ON,ON+;)
        P3M1 = B(00000000);        P3M0 = B(11111111);P3=0; //点阵行(X1(Right))(L:OFF; H,H+:ON,ON+;)
        P1ASF =B(00000011);                          //将P10,P11的IO设置为模拟输入功能;
//  Y(P0)
//H        |
//L        |
//        [L:X0(P2):H][L:X1(P3):H]
//TestCode:
//        P0=B(10000000);
//        P2=B(00000001);
//        P3=B(00010000);
void BufToLED_Refresh()                     //Refresh&Write Buf to LED ;
         uchar data i;
         uchar data X=1;
         uchar data Y=1;
         for(X=1,i=2;X;X<<=1,i+=2)              //for(X=1;X!=0;X<<=1) //8bit
                  P2=X;
                for(Y=1;Y!=0;Y<<=1)                            //Y=Y<<1;
                        P0=Y&LEDBuf[i];
                        Delays(DelayTime);
                        P0=0;
                P2=0;
         for(X=1;X<B(10000000);X<<=1,i+=2)            //7bit
                  P3=X;
                        P0=Y&LEDBuf[i];
                        Delays(DelayTime);
                        P0=0;
                P3=0;
void LEDRefresh_INT() interrupt 3 //using 3
        static uint x=0;
        static uchar flag=1;
    TL1 = 0x00;
    TH1 = INTTime;               //0x50~0x80
         if(flag)
                if(++x==0xFF)                         //MINOUTPUT
                        flag=0;
        else
                if(--x==0xCF)                 //MAXOUTPUT
                        flag=1;
        PWM0_set(x);                 //设置PWM占空比
        BufToLED_Refresh();
void Timer_INT()
         TMOD = 0x11; //高4位控制T/C1
        EA = 1;             //开总中断
        TH1 = 0x00;  //16位计数寄存器T1高8位
        TL1 = 0x00;  //16位计数寄存器T1低8位
        ET1 = 1;     //T/C1中断开
    TR1 = 1;     //T/C1启动
void FullScan()
        uchar data X=1;
        uchar data Y=1;
                 P0=Y;
                for(X=1;X;X<<=1)                   //8bit
                         P2=X;
                        Delays(7);
                P2=0;
                for(X=1;X<B(10000000);X<<=1)    //7bit
                         P3=X;
                        Delays(7);
                P3=0;
                P0=0;
void Main()
        uint data Count=700;
        uchar data i,Cgain,num=0;
        IOINIT();
        InitADC();
        while(--Count)
                FullScan();
        for(i=0;i<40;i++) refreshflag[i]=0x09;
        P14=0;                          //Beep
        Delays(4000);
        P14=1;
        PWM_init();      //PWM初始化
        PWM0_set(0xFB);
        Timer_INT();
        for(i=0;i<34;i++)
                LEDBuf[i]=0x00;
        FontDisp();
        while(520)
                for(i=0;i<65;i++)
                        dd[i].real=(GetADCResult(0)+GetADCResult(1))<<gain;          //读取ad结果并放大;
                 processfft();//傅立叶变化及处理
                 ///////////////////TouchKey//////////////////////////
                 while(P16==1)                                           //依据:脉冲 干扰持续时间短;
                        if(CBeep)P14=0;
                        if(++TouchKey>0x0000FF00)break;
                 P14=1;
                 if(P16==1)
                        if(++Menu==4)Menu=0;
                        P14=0;
                        P47=1;
                        Delays(7000);
                        P14=1;
                        P47=0;
                        TouchKey=0;
                if(P17==0)CBeep=!CBeep;
                 if(dd[2].real<32)
                         if(++Count==300)          //电平值过小,这降低gain,减少噪音的电平显示;
                                Count=0;
                                //if(++Menu==4)Menu=0;                  //切换Menu,显示方式;
                                gain=6;
                                P14=0;                          //Beep
                                Delays(1000);
                                P14=1;
                 else
                         Count=1;
                         if(++num==0xAF)                         //播放时,Auto gain;
                                num=0;
                                P14=0;                                   //Beep
                                Delays(700);
                                P14=1;
                                                           //自动增益;Automatic gain;
                                Cgain=dd[2].real/32;
                                if(7<Cgain<=8)
                                        gain=4;
                                else if(4<Cgain<=6)
                                        gain=5;
                                else if(2<Cgain<=4)
                                        gain=6;
                                else
                                        gain=7;
        while(1);
