[工具下载] C#上位机串口通信带曲线显示和历史曲线查看
504|1
 楼主| robincotton 发表于 2023-8-26 22:00 | 显示全部楼层 |阅读模式
1:应用程序界面
2:实现的功能
(1)常规的串口收发操作
(2)私有通信协议的格式转化
(3)数据的定时刷新显示和实时存储(txt)
(4)数据的历史曲线查看
3:实现的方式
串口设置的核心代码
private void SearchAndAddSerialToComboBox(SerialPort MyPort, ComboBox MyBox)        {                                                               //将可用端口号添加到ComboBox            string[] MyString = new string[20];                         //最多容纳20个,太多会影响调试效率            string Buffer;                                              //缓存            MyBox.Items.Clear();                                        //清空ComboBox内容            for (int i = 1; i < 20; i++)                                //循环            {                try                                                     //核心原理是依靠try和catch完成遍历                {                    Buffer = "COM" + i.ToString();                    MyPort.PortName = Buffer;                    MyPort.Open();                                      //如果失败,后面的代码不会执行                    MyString[i - 1] = Buffer;                    MyBox.Items.Add(Buffer);                            //打开成功,添加至下拉列表                    MyPort.Close();                                     //关闭                }                catch                {                }            }            MyBox.Text = MyString[0];                                   //初始化        }        private void button1_Click_1(object sender, EventArgs e)        {            if (serialPort1.IsOpen)                                     //串口打开就关闭            {                try                {                    serialPort1.Close();                }                catch { }                                               //确保万无一失                button1.Text = "打开串口";                Button1Statue = false;                                  //按钮状态                            }            else            {                try                {                    serialPort1.PortName = comboBox1.Text;              //端口号                    serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text, 10);//十进制数据转换                    serialPort1.DataBits = Convert.ToInt32(comboBox3.Text, 10);//十进制数据转换                    switch (comboBox4.Text)                    {                        case "0":                            serialPort1.StopBits = StopBits.None;                            break;                        case "1":                            serialPort1.StopBits = StopBits.One;                            break;                        case "1.5":                            serialPort1.StopBits = StopBits.OnePointFive;                            break;                        case "2":                            serialPort1.StopBits = StopBits.Two;                            break;                        default:                            MessageBox.Show("Error:参数不正确", "Error");                            break;                    }                    serialPort1.Open();                                 //打开端口                    button1.Text = "关闭串口";                    Button1Statue = true;                                //按钮状态                }                catch                {                    MessageBox.Show("串口打开失败", "错误");                }            }        }
定时刷新显示的核心代码:
private void refresh_curve()        {            while (true)            {                string test_time = DateTime.Now.ToString("yyyy-MM-dd-HH:mm:ss");                string Path1 = "";                if (starttime == "")                {                    Path1 = get_latest_file(Datapath);                }                else                {                    Path1 = @".\data\" + starttime + ".txt";                }                /*调试代码                lstReceiveMsg.Invoke(new EventHandler(delegate                {                    lstReceiveMsg.AppendText(test_time + "-->" + "\r\n");                    lstReceiveMsg.AppendText(Path1 + "-->" + "\r\n");                                                        }));                 */                // 从文件中读取并显示每行                string line = "";                try                {                    using (StreamReader sr = new StreamReader(Path1))                    {                        SortedList sl = new SortedList();                        while ((line = sr.ReadLine()) != null)                        {                            string[] array = line.Split('+');                            sl.Add(array[0], array[1]);                        }                        // 获取键的集合                        ICollection key = sl.Keys;                        foreach (string k in key)                        {                            //  Console.WriteLine(k + ": " + sl[k]);                            Time_axis.Add(k);                            Curve.Add(sl[k].ToString().Split(',')[type_curve]);                        }                    }                }                catch                {                    using (StreamReader sr = new StreamReader(get_latest_file(Datapath)))                    {                        SortedList sl = new SortedList();                        while ((line = sr.ReadLine()) != null)                        {                            string[] array = line.Split('+');                            sl.Add(array[0], array[1]);                        }                        // 获取键的集合                        ICollection key = sl.Keys;                        foreach (string k in key)                        {                            //  Console.WriteLine(k + ": " + sl[k]);                            Time_axis.Add(k);                            Curve.Add(sl[k].ToString().Split(',')[type_curve]);                        }                    }                    Console.WriteLine("没有当前时间段数据:" + Path1);                }                                //建立委托机制,防止线程间异常                chart1.Invoke(new EventHandler(delegate                {                    chart1.Series[0].Points.DataBindXY(Time_axis, Curve);                    chart1.Series[0].Name = chart_series_name[type_curve];                }));                             Thread.Sleep(3000);                Time_axis.Clear();                Curve.Clear();            }        }
