[STM32H7] STM32H723ZGT6 CAN1 CAN2 发送和接受
690|10
 楼主| 喂什么玩意 发表于 2023-12-20 16:35 | 显示全部楼层 |阅读模式
注意:相互探讨,如有参考请不要用于盈利。
1本文档只关注CAN
2.Stm32CubeMX配置
 楼主| 喂什么玩意 发表于 2023-12-20 16:36 | 显示全部楼层
 楼主| 喂什么玩意 发表于 2023-12-20 16:37 | 显示全部楼层
2.代码
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "fdcan.h"
  3. /* USER CODE BEGIN 0 */
  4. #include<stdio.h>
  5. #include<string.h>
  6. FDCAN_TxHeaderTypeDef fdcan_TxHeader;
  7. /* USER CODE END 0 */
  8. FDCAN_HandleTypeDef hfdcan1;
  9. FDCAN_HandleTypeDef hfdcan2;
  10. /* FDCAN1 init function */
  11. void MX_FDCAN1_Init(void)
  12. {
  13.   /* USER CODE BEGIN FDCAN1_Init 0 */
  14.   /* USER CODE END FDCAN1_Init 0 */
  15.   /* USER CODE BEGIN FDCAN1_Init 1 */
  16.   /* USER CODE END FDCAN1_Init 1 */
  17.   hfdcan1.Instance = FDCAN1;
  18.   hfdcan1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
  19.   hfdcan1.Init.Mode = FDCAN_MODE_NORMAL;
  20.   hfdcan1.Init.AutoRetransmission = DISABLE;
  21.   hfdcan1.Init.TransmitPause = DISABLE;
  22.   hfdcan1.Init.ProtocolException = DISABLE;
  23.   hfdcan1.Init.NominalPrescaler = 1;
  24.   hfdcan1.Init.NominalSyncJumpWidth = 1;
  25.   hfdcan1.Init.NominalTimeSeg1 = 15;
  26.   hfdcan1.Init.NominalTimeSeg2 = 4;
  27.   hfdcan1.Init.DataPrescaler = 1;
  28.   hfdcan1.Init.DataSyncJumpWidth = 1;
  29.   hfdcan1.Init.DataTimeSeg1 = 0xF;
  30.   hfdcan1.Init.DataTimeSeg2 = 0x4;
  31.   hfdcan1.Init.MessageRAMOffset = 0;
  32.   hfdcan1.Init.StdFiltersNbr = 1;
  33.   hfdcan1.Init.ExtFiltersNbr = 0;
  34.   hfdcan1.Init.RxFifo0ElmtsNbr = 32;
  35.   hfdcan1.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
  36.   hfdcan1.Init.RxFifo1ElmtsNbr = 0;
  37.   hfdcan1.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
  38.   hfdcan1.Init.RxBuffersNbr = 0;
  39.   hfdcan1.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
  40.   hfdcan1.Init.TxEventsNbr = 0;
  41.   hfdcan1.Init.TxBuffersNbr = 0;
  42.   hfdcan1.Init.TxFifoQueueElmtsNbr = 6;
  43.   hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
  44.   hfdcan1.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
  45.   if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
  46.   {
  47.     Error_Handler();
  48.   }
  49.   /* USER CODE BEGIN FDCAN1_Init 2 */
  50.         printf("%lx\r\n",SRAMCAN_BASE);
  51.         printf("%x\r\n",hfdcan1.msgRam.EndAddress);
  52.         FDCAN1_RX_Filter_Init();
  53.         HAL_FDCAN_Start(&hfdcan1);
  54.
  55.   /* USER CODE END FDCAN1_Init 2 */
  56. }
  57. /* FDCAN2 init function */
  58. void MX_FDCAN2_Init(void)
  59. {
  60.   /* USER CODE BEGIN FDCAN2_Init 0 */
  61.   /* USER CODE END FDCAN2_Init 0 */
  62.   /* USER CODE BEGIN FDCAN2_Init 1 */
  63.   /* USER CODE END FDCAN2_Init 1 */
  64.   hfdcan2.Instance = FDCAN2;
  65.   hfdcan2.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
  66.   hfdcan2.Init.Mode = FDCAN_MODE_NORMAL;
  67.   hfdcan2.Init.AutoRetransmission = DISABLE;
  68.   hfdcan2.Init.TransmitPause = DISABLE;
  69.   hfdcan2.Init.ProtocolException = DISABLE;
  70.   hfdcan2.Init.NominalPrescaler = 1;
  71.   hfdcan2.Init.NominalSyncJumpWidth = 1;
  72.   hfdcan2.Init.NominalTimeSeg1 = 15;
  73.   hfdcan2.Init.NominalTimeSeg2 = 4;
  74.   hfdcan2.Init.DataPrescaler = 1;
  75.   hfdcan2.Init.DataSyncJumpWidth = 1;
  76.   hfdcan2.Init.DataTimeSeg1 = 15;
  77.   hfdcan2.Init.DataTimeSeg2 = 4;
  78.   hfdcan2.Init.MessageRAMOffset = 0x406;
  79.   hfdcan2.Init.StdFiltersNbr = 1;
  80.   hfdcan2.Init.ExtFiltersNbr = 0;
  81.   hfdcan2.Init.RxFifo0ElmtsNbr = 0;
  82.   hfdcan2.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
  83.   hfdcan2.Init.RxFifo1ElmtsNbr = 32;
  84.   hfdcan2.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
  85.   hfdcan2.Init.RxBuffersNbr = 0;
  86.   hfdcan2.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
  87.   hfdcan2.Init.TxEventsNbr = 0;
  88.   hfdcan2.Init.TxBuffersNbr = 0;
  89.   hfdcan2.Init.TxFifoQueueElmtsNbr = 6;
  90.   hfdcan2.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
  91.   hfdcan2.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
  92.   if (HAL_FDCAN_Init(&hfdcan2) != HAL_OK)
  93.   {
  94.     Error_Handler();
  95.   }
  96.   /* USER CODE BEGIN FDCAN2_Init 2 */
  97.         FDCAN2_RX_Filter_Init();
  98.         HAL_FDCAN_Start(&hfdcan2);
  99.
  100.   /* USER CODE END FDCAN2_Init 2 */
  101. }
  102. static uint32_t HAL_RCC_FDCAN_CLK_ENABLED=0;
  103. void HAL_FDCAN_MspInit(FDCAN_HandleTypeDef* fdcanHandle)
  104. {
  105.   GPIO_InitTypeDef GPIO_InitStruct = {0};
  106.   if(fdcanHandle->Instance==FDCAN1)
  107.   {
  108.   /* USER CODE BEGIN FDCAN1_MspInit 0 */
  109.   /* USER CODE END FDCAN1_MspInit 0 */
  110.     /* FDCAN1 clock enable */
  111.     HAL_RCC_FDCAN_CLK_ENABLED++;
  112.     if(HAL_RCC_FDCAN_CLK_ENABLED==1){
  113.       __HAL_RCC_FDCAN_CLK_ENABLE();
  114.     }
  115.     __HAL_RCC_GPIOA_CLK_ENABLE();
  116.     /**FDCAN1 GPIO Configuration
  117.     PA11     ------> FDCAN1_RX
  118.     PA12     ------> FDCAN1_TX
  119.     */
  120.     GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12;
  121.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  122.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  123.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  124.     GPIO_InitStruct.Alternate = GPIO_AF9_FDCAN1;
  125.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  126.     /* FDCAN1 interrupt Init */
  127.     HAL_NVIC_SetPriority(FDCAN1_IT0_IRQn, 0, 0);
  128.     HAL_NVIC_EnableIRQ(FDCAN1_IT0_IRQn);
  129.   /* USER CODE BEGIN FDCAN1_MspInit 1 */
  130.   /* USER CODE END FDCAN1_MspInit 1 */
  131.   }
  132.   else if(fdcanHandle->Instance==FDCAN2)
  133.   {
  134.   /* USER CODE BEGIN FDCAN2_MspInit 0 */
  135.   /* USER CODE END FDCAN2_MspInit 0 */
  136.     /* FDCAN2 clock enable */
  137.     HAL_RCC_FDCAN_CLK_ENABLED++;
  138.     if(HAL_RCC_FDCAN_CLK_ENABLED==1){
  139.       __HAL_RCC_FDCAN_CLK_ENABLE();
  140.     }
  141.     __HAL_RCC_GPIOB_CLK_ENABLE();
  142.     /**FDCAN2 GPIO Configuration
  143.     PB12     ------> FDCAN2_RX
  144.     PB6     ------> FDCAN2_TX
  145.     */
  146.     GPIO_InitStruct.Pin = GPIO_PIN_12;
  147.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  148.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  149.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  150.     GPIO_InitStruct.Alternate = GPIO_AF9_FDCAN2;
  151.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  152.     GPIO_InitStruct.Pin = GPIO_PIN_6;
  153.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  154.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  155.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  156.     GPIO_InitStruct.Alternate = GPIO_AF9_FDCAN2;
  157.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  158.     /* FDCAN2 interrupt Init */
  159.     HAL_NVIC_SetPriority(FDCAN2_IT0_IRQn, 0, 0);
  160.     HAL_NVIC_EnableIRQ(FDCAN2_IT0_IRQn);
  161.   /* USER CODE BEGIN FDCAN2_MspInit 1 */
  162.   /* USER CODE END FDCAN2_MspInit 1 */
  163.   }
  164. }
  165. void HAL_FDCAN_MspDeInit(FDCAN_HandleTypeDef* fdcanHandle)
  166. {
  167.   if(fdcanHandle->Instance==FDCAN1)
  168.   {
  169.   /* USER CODE BEGIN FDCAN1_MspDeInit 0 */
  170.   /* USER CODE END FDCAN1_MspDeInit 0 */
  171.     /* Peripheral clock disable */
  172.     HAL_RCC_FDCAN_CLK_ENABLED--;
  173.     if(HAL_RCC_FDCAN_CLK_ENABLED==0){
  174.       __HAL_RCC_FDCAN_CLK_DISABLE();
  175.     }
  176.     /**FDCAN1 GPIO Configuration
  177.     PA11     ------> FDCAN1_RX
  178.     PA12     ------> FDCAN1_TX
  179.     */
  180.     HAL_GPIO_DeInit(GPIOA, GPIO_PIN_11|GPIO_PIN_12);
  181.     /* FDCAN1 interrupt Deinit */
  182.     HAL_NVIC_DisableIRQ(FDCAN1_IT0_IRQn);
  183.   /* USER CODE BEGIN FDCAN1_MspDeInit 1 */
  184.   /* USER CODE END FDCAN1_MspDeInit 1 */
  185.   }
  186.   else if(fdcanHandle->Instance==FDCAN2)
  187.   {
  188.   /* USER CODE BEGIN FDCAN2_MspDeInit 0 */
  189.   /* USER CODE END FDCAN2_MspDeInit 0 */
  190.     /* Peripheral clock disable */
  191.     HAL_RCC_FDCAN_CLK_ENABLED--;
  192.     if(HAL_RCC_FDCAN_CLK_ENABLED==0){
  193.       __HAL_RCC_FDCAN_CLK_DISABLE();
  194.     }
  195.     /**FDCAN2 GPIO Configuration
  196.     PB12     ------> FDCAN2_RX
  197.     PB6     ------> FDCAN2_TX
  198.     */
  199.     HAL_GPIO_DeInit(GPIOB, GPIO_PIN_12|GPIO_PIN_6);
  200.     /* FDCAN2 interrupt Deinit */
  201.     HAL_NVIC_DisableIRQ(FDCAN2_IT0_IRQn);
  202.   /* USER CODE BEGIN FDCAN2_MspDeInit 1 */
  203.   /* USER CODE END FDCAN2_MspDeInit 1 */
  204.   }
  205. }
  206. /* USER CODE BEGIN 1 */
  207. /**
  208.   * 函数功能: 设置并初始化滤波器0,供FDCAN1使用
  209.   * 输入参数: void
  210.   * 返回值:  void
  211.   */
  212. void FDCAN1_RX_Filter_Init(void)
  213. {
  214.          FDCAN_FilterTypeDef hfdcan1_RX_Filter;   /* FDCAN1滤波器0对象句柄 */
  215.
  216.          hfdcan1_RX_Filter.IdType = FDCAN_STANDARD_ID;              /* 只接收标准帧ID */
  217.    hfdcan1_RX_Filter.FilterIndex = 0;                         /* 滤波器索引0 */
  218.    hfdcan1_RX_Filter.FilterType = FDCAN_FILTER_MASK;          /* 滤波器类型 */
  219.    hfdcan1_RX_Filter.FilterConfig = FDCAN_FILTER_TO_RXFIFO0;  /* 滤波器关联到RXFIFO0 */
  220.    hfdcan1_RX_Filter.FilterID1 = 0x111;                       /* 滤波ID1: 0x00 */
  221.    hfdcan1_RX_Filter.FilterID2 = 0x7FF; /* 滤波ID2: 0x00 */
  222.    HAL_FDCAN_ConfigFilter(&hfdcan1,&hfdcan1_RX_Filter);       /* 看看滤波器有没有创建成功 */
  223.    /* HAL_FDCAN_ConfigGlobalFilter()
  224.     * 参数2:设置标准帧ID,接收的报文ID没有匹配上滤波器时,选择拒绝接收(没有匹配上时,可以选择放入FIFO0或者FIFO1)。
  225.     * 参数3:设置拓展帧ID,接收的报文ID没有匹配上滤波器时,选择拒绝接收。
  226.     * 参数4:设置是否拒绝远程标准帧,ENABLE代表拒绝接收。
  227.     * 参数5:设置是否拒绝远程拓展帧,ENABLE代表拒绝接收。
  228.     */
  229.    HAL_FDCAN_ConfigGlobalFilter(&hfdcan1,FDCAN_REJECT,FDCAN_REJECT,DISABLE,ENABLE); /* 设置FDCAN1滤波器0全局配置  */
  230.          HAL_FDCAN_ActivateNotification(&hfdcan1,FDCAN_IT_RX_FIFO0_NEW_MESSAGE,0);
  231. }
  232. /**
  233.   * 函数功能: 设置并初始化滤波器1,供FDCAN2使用
  234.   * 输入参数: void
  235.   * 返回值:  void
  236.   */
  237. void FDCAN2_RX_Filter_Init(void)
  238. {
  239.          FDCAN_FilterTypeDef hfdcan2_RX_Filter;   /* FDCAN2滤波器0对象句柄 */
  240.
  241.          hfdcan2_RX_Filter.IdType = FDCAN_STANDARD_ID;              /* 只接收标准帧ID */
  242.    hfdcan2_RX_Filter.FilterIndex = 0;                         /* 滤波器索引0 */
  243.    hfdcan2_RX_Filter.FilterType = FDCAN_FILTER_MASK;          /* 滤波器类型(允许接收报文的ID范围是FilterID1至FilterID2 */
  244.    hfdcan2_RX_Filter.FilterConfig = FDCAN_FILTER_TO_RXFIFO1;  /* 滤波器关联到RXFIFO1 */
  245.    hfdcan2_RX_Filter.FilterID1 = 0x111;                       /* 滤波ID1: 0x00 */
  246.    hfdcan2_RX_Filter.FilterID2 = 0x7FF;                      /* 滤波ID2:   0x00 */
  247.    HAL_FDCAN_ConfigFilter(&hfdcan2,&hfdcan2_RX_Filter);       /* 看看滤波器有没有创建成功 */
  248.    /* HAL_FDCAN_ConfigGlobalFilter()
  249.     * 参数2:设置标准帧ID,接收的报文ID没有匹配上滤波器时,选择拒绝接收(没有匹配上时,可以选择放入FIFO0或者FIFO1)。
  250.     * 参数3:设置拓展帧ID,接收的报文ID没有匹配上滤波器时,选择拒绝接收。
  251.     * 参数4:设置是否拒绝远程标准帧,ENABLE代表拒绝接收。
  252.     * 参数5:设置是否拒绝远程拓展帧,ENABLE代表拒绝接收。
  253.     */
  254.    HAL_FDCAN_ConfigGlobalFilter(&hfdcan2,FDCAN_REJECT,FDCAN_REJECT,DISABLE,ENABLE); /* 设置FDCAN1滤波器1全局配置  */
  255.          HAL_FDCAN_ActivateNotification(&hfdcan2,FDCAN_IT_RX_FIFO1_NEW_MESSAGE,0);
  256. }
  257. /**
  258.   * 函数功能: FDCAN2启动
  259.   * 输入参数: uint8_t  canordernumber  CAN1 为1 CAN2为2
  260.   * 输入参数: uint8_t  sendcanid  发送数据的canid
  261.         * 输入参数: uint8_t* msg  发送数据的数组
  262.         * 输入参数: uint32_t len  发送数据的长度
  263.   * 返回值:  uint8_t  成功返回数据1 失败返回数据0
  264.   * 说明:
  265.   */
  266. uint8_t FDCAN_Send_Msg(uint8_t canordernumber,uint32_t sendcanid,uint8_t* msg,uint32_t len)
  267. {
  268.           static uint8_t msgdata[10]={0};
  269.                 memcpy(msgdata,msg,len);
  270.     fdcan_TxHeader.Identifier=sendcanid;                      //32位ID
  271.     fdcan_TxHeader.IdType=FDCAN_STANDARD_ID;                  //标准ID
  272.     fdcan_TxHeader.TxFrameType=FDCAN_DATA_FRAME;              //数据帧
  273.     fdcan_TxHeader.DataLength=FDCAN_DLC_BYTES_8;              //数据长度
  274.     fdcan_TxHeader.ErrorStateIndicator=FDCAN_ESI_ACTIVE;
  275.     fdcan_TxHeader.BitRateSwitch=FDCAN_BRS_OFF;               //关闭速率切换
  276.     fdcan_TxHeader.FDFormat=FDCAN_CLASSIC_CAN;                //传统的CAN模式
  277.     fdcan_TxHeader.TxEventFifoControl=FDCAN_NO_TX_EVENTS;     //无发送事件
  278.     fdcan_TxHeader.MessageMarker=0;
  279.
  280.                 if(canordernumber==1)
  281.                 {
  282.                                 if(HAL_FDCAN_AddMessageToTxFifoQ(&hfdcan1,&fdcan_TxHeader,msgdata)!=HAL_OK) return 1;//发送
  283.                 }
  284.                 else if(canordernumber==2)
  285.                 {
  286.                                 if(HAL_FDCAN_AddMessageToTxFifoQ(&hfdcan2,&fdcan_TxHeader,msgdata)!=HAL_OK) return 1;//发送
  287.                 }
  288.     return 0;
  289. }
  290. /**
  291.   * 函数功能: FIFO0的接收中断回调函数
  292.   * 输入参数: RxFifo0ITs:返回标志位
  293.   * 返回值:  void
  294.   * 说明:
  295.   *      1.FDCAN1使用RXFIFO0
  296.   */
  297. void HAL_FDCAN_RxFifo0Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo0ITs)
  298. {
  299.                 uint8_t i=0;
  300.     uint8_t rxdata[8];
  301.           FDCAN_RxHeaderTypeDef FDCAN1_RxHeader;
  302.     if((RxFifo0ITs&FDCAN_IT_RX_FIFO0_NEW_MESSAGE)!=RESET)   //FIFO0新数据中断
  303.     {
  304.         //提取FIFO0中接收到的数据
  305.         HAL_FDCAN_GetRxMessage(hfdcan,FDCAN_RX_FIFO0,&FDCAN1_RxHeader,rxdata);
  306.         printf("id:%#x\r\n",FDCAN1_RxHeader.Identifier);
  307.         printf("len:%d\r\n",FDCAN1_RxHeader.DataLength>>16);
  308.         for(i=0;i<8;i++)
  309.         printf("rxdata[%d]:%d\r\n",i,rxdata[i]);
  310.
  311.                                 FDCAN_Send_Msg(1,FDCAN1_RxHeader.Identifier,rxdata,8);
  312.     }
  313. }
  314. /**
  315.   * 函数功能: FIFO1的接收中断回调函数
  316.   * 输入参数: RxFifo0ITs:返回标志位
  317.   * 返回值:  void
  318.   * 说明:
  319.   *     1、FDCAN2使用RXFIFO1
  320.   */
  321. void HAL_FDCAN_RxFifo1Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo1ITs)
  322. {
  323.           uint8_t i=0;
  324.     uint8_t rxdata[8];
  325.           FDCAN_RxHeaderTypeDef FDCAN2_RxHeader;
  326.     if((RxFifo1ITs&FDCAN_IT_RX_FIFO1_NEW_MESSAGE)!=RESET)   //FIFO1新数据中断
  327.     {
  328.         //提取FIFO0中接收到的数据
  329.         HAL_FDCAN_GetRxMessage(hfdcan,FDCAN_RX_FIFO1,&FDCAN2_RxHeader,rxdata);
  330.         printf("id:%#x\r\n",FDCAN2_RxHeader.Identifier);
  331.         printf("len:%d\r\n",FDCAN2_RxHeader.DataLength>>16);
  332.         for(i=0;i<8;i++)
  333.         printf("rxdata[%d]:%d\r\n",i,rxdata[i]);
  334.                           FDCAN_Send_Msg(2,FDCAN2_RxHeader.Identifier,rxdata,8);
  335.     }
  336. }
  337. /* USER CODE END 1 */
