ZCC2785-500V线性稳压器芯片,替代NCP785
814|0
 楼主| HPT-Lt 发表于 2024-1-17 16:46 | 显示全部楼层 |阅读模式
The ZCC2785 is a high-performance linear regulator, offering a very wide operating input voltage range of up to 450 V DC, with an output current of up to10 mA.
Ideal for high input voltage applications such as industrial and home metering, home appliances. The ZCC2785 family offers ±5% initial accuracy, extremely high-power supply rejection ratio and ultra-low quiescent current. The ZCC2785 is optimized for high-voltage line and load transients, making this part ideal for harsh environment applications.
The ZCC2785 is offered in fixed output voltage options 3.3 V, and5.0 V. ESOP8 & SOT89 package offers good thermal performance and help to minimize the solution size.
Features
● Wide Input Voltage Range:
DC: Up to 450 V
AC: 85 V to 260 V (half-wave rectifier and 2.2μF capacitor)
●10 mA Guaranteed Output Current
●Ultra Low Quiescent Current: Typ. 10 μA (VOUT ≤ 5 V)
●±5% Accuracy Over Full Load, Line and Temperature Variations
●Ultra-high PSRR: 70 dB at 60 Hz, 90 dB at 100 kHz
●Stable with Ceramic Output Capacitor 22μF MLCC
●Thermal Shutdown and Current Limit Protection
●Available in Thermally Enhanced ESOP8 & SOT89 Package
●This is a Pb-Free Device
Typical Applications
●Industrial Applications, Home Appliances
●Home Metering / Network Application
●Off-line Power Supplies
