[射频芯片] GSR1385S 兼容替代SKY13585
3384|0
 楼主| pennyyao 发表于 2024-1-19 10:51 | 显示全部楼层 |阅读模式
GSR1385S: CMOS SOI SPDT Switch
0.01-7.2 GHz
Applications
WLAN 802.11a/b/g/n/ac/ax networks
ISM band radios
Low power T/R systems
Features
P0.1dB +32dBm typical @ +3.3V
Low insertion loss (0.25dB @ 2.5GHz,0.35dB @ 5.8GHz)
High isolation (37dB @ 2.5GHz)
Low delay, switch time:75~125nS
1.0mm x 1.0mm QFN Package(MSL3,260°C per JEDEC-J-STD-020)
Description
Using advanced switching technologies, the GSR1385S is a single pole dual throw (SPDT) high power switch in a low cost miniature 1.0 mm × 1.0 mm package. The GSR1385S is ideally suited for applications where high power, low insertion loss and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 7.2 GHz requiring high power at low control voltage.
