- unsigned char huan[] =
- 0x04, 0x24, 0x44, 0x84, 0x64, 0x9C, 0x40, 0x30, 0x0F, 0xC8, 0x08, 0x08, 0x28, 0x18, 0x00, 0x00,
- 0x10, 0x08, 0x06, 0x01, 0x82, 0x4C, 0x20, 0x18, 0x06, 0x01, 0x06, 0x18, 0x20, 0x40, 0x80, 0x00
- };/*"欢",0*/
- unsigned char ying[] =
- 0x40, 0x40, 0x42, 0xCC, 0x00, 0x00, 0xFC, 0x04, 0x02, 0x00, 0xFC, 0x04, 0x04, 0xFC, 0x00, 0x00,
- 0x00, 0x40, 0x20, 0x1F, 0x20, 0x40, 0x4F, 0x44, 0x42, 0x40, 0x7F, 0x42, 0x44, 0x43, 0x40, 0x00
- };/*"迎",1*/
- unsigned char shi[] =
- 0x80, 0x60, 0xF8, 0x07, 0x04, 0xE4, 0x24, 0x24, 0x24, 0xFF, 0x24, 0x24, 0x24, 0xE4, 0x04, 0x00,
- 0x00, 0x00, 0xFF, 0x00, 0x80, 0x81, 0x45, 0x29, 0x11, 0x2F, 0x41, 0x41, 0x81, 0x81, 0x80, 0x00
- };/*"使",0*/
- unsigned char yong[] =
- 0x00, 0x00, 0xFE, 0x22, 0x22, 0x22, 0x22, 0xFE, 0x22, 0x22, 0x22, 0x22, 0xFE, 0x00, 0x00, 0x00,
- 0x80, 0x60, 0x1F, 0x02, 0x02, 0x02, 0x02, 0x7F, 0x02, 0x02, 0x42, 0x82, 0x7F, 0x00, 0x00, 0x00
- };/*"用",1*/
主函数部分代码
- int main(void)
- u8 t;
- u8 *temp;
- u16 SET_VOLTAGE = 123;
- SystemInit ();
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
- delay_init(); //延时初始化
- LCD_IO_init(); //显示屏IO初始化
- Lcd_Init(); //显示屏寄存器初始化
- LCD_Clear(); //显示屏清屏操作
- uart_init(9600); //波特率使用115200
- printf("欢迎使用\r\n");
- while(1)
- display_graphic_16x16(3, 16, 0, huan);
- display_graphic_16x16(3, 32, 0, ying);
- display_graphic_16x16(3, 48, 0, shi);
- display_graphic_16x16(3, 64, 0, yong);
