实际上就是Vchannelx = (3.0xVrefint/FULL_SCALE)*(ADCx_DATA/VREFINT_DATA),其中(3.0xVrefint/FULL_SCALE)=1.20V
#define ADC1_DR_ADDR ((uint32_t)0x4001244C)
float battaryValue;
u16 ADC_VALUE[2];
void ADC1_AdcInit(void)
//ADC_InitTypeDef ADC_InitStuctrue;
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_ADC1,ENABLE); //使能AHB预分频器到端口A的开关
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//引脚复用 进行重映射时要开启AFIO 时钟
//声明结构变量
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //定义PA0,PA1脚为AD输入
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //IO口为模拟输入模式
//GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //AD口设置为浮空输入
GPIO_Init(GPIOA, &GPIO_InitStructure);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
/* DMA1 channel1 configuration ----------------------------------------------*/
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDR;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_VALUE;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 2;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
//DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE);
/* Enable DMA1 channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
// ADC内置温度传感器禁止
ADC_TempSensorVrefintCmd(DISABLE);
/* ADC1 configuration ------------------------------------------------------*/
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//DISABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 2;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_17, 2, ADC_SampleTime_55Cycles5);
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 external trigger */
ADC_ExternalTrigConvCmd(ADC1, DISABLE);
ADC_Cmd(ADC1, ENABLE);
/* 重置ADC校准寄存器 */
ADC_ResetCalibration(ADC1);
/* 检测ADC校准寄存器状态 */
while(ADC_GetResetCalibrationStatus(ADC1));
/* 开始ADC校准程序 */
ADC_StartCalibration(ADC1);
/* 检测ADC校准状态 */
while(ADC_GetCalibrationStatus(ADC1));
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
ADC_TempSensorVrefintCmd(ENABLE);//打开内部参照电压
void readBattaryValue(void)
battaryValue=(float)1.20*((float)ADC_VALUE[0]/ADC_VALUE[1]);//参考电压1.2 V
