PT32L007F8P7K与SC7A20H IIC通讯代码分享
3363|1
 楼主| rickluo 发表于 2024-3-5 10:21 | 显示全部楼层 |阅读模式
#技术资源#
1、开发板图: DSC_2270修.jpg
2、规格书:
SC7A20H 说明书0.1(1)(1).pdf (1.04 MB, 下载次数: 20)
PT32L007x数据手册1.1.pdf (2.88 MB, 下载次数: 4)
3、接线图:
接线说明:VCC  GND   SDA(PB5)-传感器模块第4PIN  SCL(PB4)-  传感器模块第5PIN
4、代码:
#define   READ_ADDR    0x33
#define   DEVICE_ADDR  0x32
u8 arry_write[10]={0x37,0x01,0x40,0x88,0x01,0x2a,0x01,0x00};
void I2C_GPIO_Config(void)
        /* 配置I2C管脚的复用功能 */
        GPIO_DigitalRemapConfig(AFIOB, GPIO_Pin_5, AFIO_AF_0,ENABLE);        //PB5 I2C SDA
        GPIO_DigitalRemapConfig(AFIOB, GPIO_Pin_4, AFIO_AF_0,ENABLE);        //PB4 I2C SCL
void I2C_Driver(void)
    I2C_InitTypeDef I2C_InitStruct;
    I2C_InitStruct.I2C_Acknowledge = I2C_Acknowledge_Disable;
    I2C_InitStruct.I2C_Broadcast = I2C_Broadcast_Disable;
    I2C_InitStruct.I2C_OwnAddress = 0x00;
    I2C_InitStruct.I2C_Prescaler = 640-1;
    I2C_Init(I2C,&I2C_InitStruct);
* @brief IIC写函数
* @param pBuffer:需要写入的数据
* @param WriteAddr:从机地址
* @param NumByteToWrite:需要写入的数据长度
* @retval 无
void I2C_EE_Write(u8 pBuffer, unsigned int WriteAddr, u16 data_size)
//        int i;
/******************等待从机ready***************/
        I2C_GenerateEvent(I2C,I2C_Event_Start,DISABLE);
        I2C->CCR |= I2C_CCR_SI | I2C_CCR_ACK;
        I2C_Cmd(I2C,DISABLE);
        I2C_Cmd(I2C,ENABLE);
        I2C_GenerateEvent(I2C,I2C_Event_Start,ENABLE);
        while(I2C_GetFlagStatus(I2C,I2C_FLAG_StartOk)!= SET);
        I2C_SendAddr(I2C, DEVICE_ADDR);//器件地址,写
        while(I2C_GetFlagStatus(I2C,I2C_FLAG_MASGetAckW)!=SET);
        I2C_SendData(I2C,WriteAddr);//发送要写的字地址
        while(I2C_GetFlagStatus(I2C,I2C_FLAG_MDSGetAck)!=SET);
//        for(i=0;i<data_size;i++)
//                I2C_SendData(I2C, *(pBuffer++));
//                while(I2C_GetFlagStatus(I2C,I2C_FLAG_MDSGetAck) != SET);
        I2C_SendData(I2C, pBuffer);
                /******************发送停止位***************/
        I2C_GenerateEvent(I2C,I2C_Event_Stop,ENABLE);
//uint8_t I2C_EE_Read(u8* pBuffer,u16 ReadAddr, u16 DeviceAddr, u16 data_size)
uint8_t I2C_EE_Read(u16 ReadAddr)
//        int i;
        uint8_t date = 0 ;
        I2C_SendData(I2C,ReadAddr);//发送要读的页地址
        //printf("-----%s  %d----\n", __func__, __LINE__) ;
/******************接收数据***************/
        I2C_SendAddr(I2C, READ_ADDR);//器件地址,读
        while(I2C_GetFlagStatus(I2C,I2C_FLAG_MASGetAckR)!=SET);
        I2C->CCR=I2C_CCR_ACK|I2C_CCR_SI;//主机发送NACK
        while(I2C_GetFlagStatus(I2C,I2C_FLAG_MDGSendNack) != SET);
        date = I2C_ReceiveData(I2C);
        return date ;
init(void)
        I2C_EE_Write(arry_write[0], 0x20, 1);Software_Delay(100000) ;
        I2C_EE_Write(arry_write[1], 0x21, 1);Software_Delay(100000) ;
        I2C_EE_Write(arry_write[2], 0x22, 1);Software_Delay(100000) ;
        I2C_EE_Write(arry_write[3], 0x23, 1);Software_Delay(100000) ;
        I2C_EE_Write(arry_write[4], 0x1f, 3);Software_Delay(100000) ;
        I2C_EE_Write(arry_write[5], 0x30, 1);Software_Delay(100000) ;
        I2C_EE_Write(arry_write[6], 0x32, 1);Software_Delay(100000) ;
        I2C_EE_Write(arry_write[7], 0x32, 1);Software_Delay(100000) ;
磁编码器 发表于 2024-3-7 10:56 | 显示全部楼层
多谢分享
