如何在 C 编程中使用每个列出的关键字的简要示例。
- // auto
- void function() {
- auto int localVar = 0; // localVar has automatic storage duration, typical for local variables.
- // break
- for(int i = 0; i < 10; i++) {
- if(i == 5) break; // Exits the loop when i equals 5.
- // case, default, switch
- int num = 2;
- switch(num) {
- case 1:
- // Code for case 1
- break;
- case 2:
- // Code for case 2
- break;
- default:
- // Code if no case matches
- break;
- // char
- char letter = 'A'; // Declares a character variable.
- // const
- const int MAX = 100; // MAX is a constant, its value cannot be changed.
- // continue
- if(i % 2 == 0) continue; // Skips the rest of the loop body for even numbers.
- // Odd numbers code here
- // do, while
- int count = 0;
- do {
- // Code to execute
- count++;
- } while(count < 5); // Loops until count is less than 5.
- // double
- double pi = 3.14159; // Declares a double-precision floating-point variable.
- // else, if
- int a = 5;
- if(a > 10) {
- // Code if condition is true
- } else {
- // Code if condition is false
- // enum
- enum colors {red, green, blue};
- enum colors shirt = red; // Assigns the first value of enum colors to shirt.
- // float
- float temperature = 36.6f; // Declares a single-precision floating-point variable.
- // for
- // Loop code here
- // goto
- label:
- // Code to jump to
- goto label; // Jumps to the label.
- // int
- int age = 30; // Declares an integer variable.
- // long
- long distance = 1234567890L; // Declares a long integer variable.
- // register
- register int fastVar = 5; // Suggests that fastVar should be stored in a register for faster access.
- // return
- int add(int x, int y) {
- return x + y; // Returns the sum of x and y.
- // short
- short height = 170; // Declares a short integer variable.
- // signed
- signed int temperature = -20; // Explicitly declares a signed integer.
- // sizeof
- int size = sizeof(int); // Gets the size of int type in bytes.
- // static
- void counter() {
- static int count = 0; // count retains its value between function calls.
- count++;
- // struct
- struct Person {
- char name[50];
- int age;
- struct Person person1; // Declares a variable of type Person.
- // typedef
- typedef unsigned int uint;
- uint counter = 100; // Uses uint as an alias for unsigned int.
- // union
- union Data {
- int i;
- float f;
- char str[20];
- union Data data; // Declares a variable of type Data, which can hold an int, a float, or a char array.
- // unsigned
- unsigned int positive = 300; // Declares an unsigned integer, ensuring it's non-negative.
- // void
- void myFunction() {
- // A function that returns no value.
- // volatile
- volatile int shared = 0; // Tells the compiler that the value of shared can be changed unexpectedly.
- // while
- int i = 0;
- while(i < 5) {
- // Code to execute while i is less than 5.
- i++;
