概述:
在使用STM8L101F3这款单片机时,由于它只有8K的flash,空间非常小,只要调用C库函数printf编译后整个文件很大,直接程序溢出。这也就意味着我们实现printf串口打印调试就没办法进行。既然使用不了库函数,那么我们就可以自己动手封装类似printf的函数,这样我们就可以实现数据串口打印啦。这里就直接放上我的STM8L101F3的部分源码了,希望可以给你一些参考。
源码:
- #include "stdarg.h"
- #include "stm8l10x.h"
- void USART_Config(void)
- /*Set the USART RX and USART TX at high level*/
- GPIO_ExternalPullUpConfig(GPIOC,GPIO_Pin_3|GPIO_Pin_4, ENABLE);
- /* Enable USART clock */
- CLK_PeripheralClockConfig(CLK_Peripheral_USART, ENABLE);
- USART_DeInit();
- USART_Init((uint32_t)9600, USART_WordLength_8D, USART_StopBits_1,
- USART_Parity_No, (USART_Mode_TypeDef)(USART_Mode_Rx | USART_Mode_Tx));
- USART_Cmd(DISABLE);
- enableInterrupts();
- USART_Cmd(ENABLE);
- /*发送串口数据*/
- void send_uart_data(uint8_t data)
- while (USART_GetFlagStatus(USART_FLAG_TXE) == RESET);
- USART_SendData8(data);
- 功能:将int型数据转为2,8,10,16进制字符串
- 参数:value --- 输入的int整型数
- str --- 存储转换的字符串
- radix --- 进制类型选择
- 注意:8位单片机int字节只占2个字节
- char *sky_itoa(int value, char *str, unsigned int radix)
- char list[] = "0123456789ABCDEF";
- unsigned int tmp_value;
- int i = 0, j, k = 0;
- if (NULL == str) {
- return NULL;
- if (2 != radix && 8 != radix && 10 != radix && 16 != radix) {
- return NULL;
- if (radix == 10 && value < 0) {
- //十进制且为负数
- tmp_value = (unsigned int)(0 - value);
- str[i++] = '-';
- k = 1;
- } else {
- tmp_value = (unsigned int)value;
- //数据转换为字符串,逆序存储
- do {
- str[i ++] = list[tmp_value%radix];
- tmp_value /= radix;
- } while(tmp_value);
- str[i] = '\0';
- //将逆序字符串转换为正序
- char tmp;
- for (j = k; j < (i+k)/2; j++) {
- tmp = str[j];
- str[j] = str[i-j-1+k];
- str[i-j-1+k] = tmp;
- return str;
- 功能:将double型数据转为字符串
- 参数:value --- 输入的double浮点数
- str --- 存储转换的字符串
- eps --- 保留小数位选择,至少保留一个小数位,至多保留4个小数位
- void sky_ftoa(double value, char *str, unsigned int eps)
- unsigned int integer;
- double decimal;
- char list[] = "0123456789";
- //将整数及小数部分提取出来
- if (value < 0) {
- decimal = (double)(((int)value) - value);
- integer = (unsigned int)(0 - value);
- str[i ++] = '-';
- k = 1;
- } else {
- integer = (unsigned int)(value);
- decimal = (double)(value - integer);
- //整数部分数据转换为字符串,逆序存储
- do {
- str[i ++] = list[integer%10];
- integer /= 10;
- } while(integer);
- str[i] = '\0';
- //将逆序字符串转换为正序
- char tmp;
- tmp = str[j];
- //处理小数部分
- if (eps < 1 || eps > 4) {
- eps = 4;
- //精度问题,防止输入1.2输出1.19等情况
- double pp = 0.1;
- for (j = 0; j <= eps; j++) {
- pp *= 0.1;
- decimal += pp;
- while (eps) {
- decimal *= 10;
- eps --;
- int tmp_decimal = (int)decimal;
- str[i ++] = '.';
- k = i;
- do {
- str[i ++] = list[tmp_decimal%10];
- tmp_decimal /= 10;
- } while(tmp_decimal);
- str[i] = '\0';
- //将逆序字符串转换为正序
- tmp = str[j];
- str[i] = '\0';
- void mprintf(char * Data, ...)
- const char *s;
- int d;
- char buf[16];
- uint8_t txdata;
- va_list ap;
- va_start(ap, Data);
- while ( * Data != 0 ) {
- if ( * Data == 0x5c ) {
- switch ( *++Data ) {
- case 'r':
- txdata = 0x0d;
- send_uart_data(txdata);
- Data ++;
- break;
- case 'n':
- txdata = 0x0a;
- Data ++;
- break;
- default:
- Data ++;
- break;
- } else if ( * Data == '%') {
- case 's':
- s = va_arg(ap, const char *);
- for ( ; *s; s++) {
- send_uart_data(*((uint8_t *)s));
- Data++;
- break;
- case 'd':
- d = va_arg(ap, int);
- sky_itoa(d, buf, 10);
- for (s = buf; *s; s++) {
- Data++;
- break;
- case 'x': {
- sky_itoa(d, buf, 16);
- Data++;
- break;
- case 'f': {
- double num = va_arg(ap, double);
- sky_ftoa(num, buf, 4);
- Data++;
- break;
- default:
- Data++;
- break;
- } else {
- send_uart_data(*((uint8_t *)Data));
- Data++;
- void main(void)
- USART_Config();
- mprintf("STM8L start...\r\n");
- mprintf("%f %f %f\r\n", 1.2, 12.36, -1.2364568);
- mprintf("%x %x %x\r\n", 0x1035, 0x0830, 0x2018);
- mprintf("%d %d %d\r\n", 12, -12345, 2);
- mprintf("STM8L end...\r\n");
- while (1) {
