为什么protues上仿真没问题,但是现实中数码管一直在闪动?
21168|19
 楼主| dzydybz 发表于 2024-4-6 17:41 | 显示全部楼层 |阅读模式
这是相关代码:
/* 头文件声明区 */
#include <STC89C5xRC.H>//89c52专用头文件
#include <init.h>//初始化底层驱动专用头文件
#include <key.h>//按键底层驱动专用头文件
#include <seg.h>//数码管底层驱动专用头文件
#include <led.h>//Led底层驱动专用头文件
#include <intrins.h>//包含了各种内联函数和宏,用于访问处理器特定的指令和功能的头文件
/* 变量声明区 */
unsigned char Key_Val,Key_Down,Key_Old,Key_Up;//按键专用变量
unsigned char Key_Slow_Down;//按键减速专用变量
unsigned char Seg_Buf[8] = {10,10,10,10,10,10,10,10};//数码管显示数据存放数组
unsigned char Seg_Point[8] = {0,0,0,0,0,0,0,0};//数码管小数点数据存放数组
unsigned char Seg_Pos;//数码管扫描专用变量
unsigned int Seg_Slow_Down;//数码管减速专用变量
unsigned char ucLed[8] = {0,0,0,0,0,0,0,0};//Led显示数据存放数组
unsigned char Seg_Disp_Mode=1;//数码管模式显示变量 0为学号显示 1为按键显示
unsigned char Seg_Student[16]={8,2,0,6,2,2,0,7,2,7,0,0,0,0,0,0};//学号存储数组
/*自定义延迟函数(毫秒)*/
void Delay(unsigned int xms)                //@12.000MHz
        unsigned char i, j;
  while(xms--)
                i = 2;
          j = 239;
          do
                        while (--j);
          } while (--i);
/* 键盘处理函数 */
void Key_Proc()
        if(Key_Slow_Down) return;
        Key_Slow_Down = 1;//键盘减速程序
        Key_Val = Key_Read();//实时读取键码值
        Key_Down = Key_Val & (Key_Old ^ Key_Val);//捕捉按键下降沿
        Key_Up = ~Key_Val & (Key_Old ^ Key_Val);//捕捉按键上降沿
        Key_Old = Key_Val;//辅助扫描变量
  switch(Key_Down)
                case 16:
                        if(Seg_Disp_Mode==1)
                   Seg_Buf[0] =0;
                   LcdGotoXY(3,0);
           LcdPrintStr("键盘显示0  ");
                break;
                case 1:
                   Seg_Buf[0] =1;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示1  ");
                break;
                case 2:
                   Seg_Buf[0] =2;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示2  ");
                break;
                case 3:
                   Seg_Buf[0] =3;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示3  ");
                break;
                case 4:
                   Seg_Buf[0] =4;
               LcdGotoXY(3,0);
           LcdPrintStr("键盘显示4  ");
                break;
                case 5:
                   Seg_Buf[0] =5;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示5  ");
                break;
                case 6:
                   Seg_Buf[0] =6;
                    LcdGotoXY(3,0);
           LcdPrintStr("键盘显示6  ");
                break;
                case 7:
                   Seg_Buf[0] =7;
                    LcdGotoXY(3,0);
           LcdPrintStr("键盘显示7  ");
                break;
                case 8:
                   Seg_Buf[0] =8;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示8  ");
                break;
                case 9:
                   Seg_Buf[0] =9;
                    LcdGotoXY(3,0);
           LcdPrintStr("键盘显示9  ");
                break;
                case 10:
                   Seg_Buf[0] =11;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示A  ");
                break;
                        case 11:
                   Seg_Buf[0] =12;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示b  ");
                break;
                case 12:
                   Seg_Buf[0] =13;
                    LcdGotoXY(3,0);
     break;
                case 13:
                   Seg_Buf[0] =14;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示d  ");
                break;
                case 14:
                   Seg_Buf[0] =15;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示E  ");
                break;
                case 15:
                   Seg_Buf[0] =16;
                     LcdGotoXY(3,0);
           LcdPrintStr("键盘显示F  ");
                   break;
    case 17:
                        Seg_Disp_Mode = 0;
                   LcdWriteCmd(0xff);
                   LcdGotoXY(3,0);
           LcdPrintStr("学号流水显示");
                break;
          case 18:
                        Seg_Disp_Mode = 1;
                break;
/* 信息处理函数 */
void Seg_Proc()
        unsigned char i,j;//循环变量
        if(Seg_Slow_Down) return;
        Seg_Slow_Down = 1;//数码管减速程序
        if(Seg_Disp_Mode==0)//学号显示界面
         Seg_Buf[7] =0;
                 for(i=0,j=0;i<=5,j<=15;i++,j++)
         if(i==6)
                         i=0;
                   Seg_Buf =Seg_Student[j];
             Delay(500);
         else
             Delay(500);
          if(Seg_Disp_Mode==1)//按键响应界面
     Seg_Buf[1] =10;
                 Seg_Buf[2] =10;
                 Seg_Buf[3] =10;
                 Seg_Buf[4] =10;
                 Seg_Buf[5] =10;
                 Seg_Buf[6] =10;
                 Seg_Buf[7] =1;
/* 其他显示函数 */
void Led_Proc()
void Timer0Init(void)                //1毫秒@12.000MHz
        AUXR &= 0x7F;                //定时器时钟12T模式
        TMOD &= 0xF0;                //设置定时器模式
        TL0 = 0x18;                //设置定时初始值
        TH0 = 0xFC;                //设置定时初始值
        TF0 = 0;                //清除TF0标志
        TR0 = 1;                //定时器0开始计时
        ET0 = 1;    //定时器中断0打开
        EA = 1;     //总中断打开
void Timer0Server() interrupt 1
        if(++Key_Slow_Down == 10) Key_Slow_Down = 0;//键盘减速专用
        if(++Seg_Slow_Down == 500) Seg_Slow_Down = 0;//数码管减速专用
        if(++Seg_Pos == 8) Seg_Pos = 0;//数码管显示专用
        Seg_Disp(Seg_Pos,Seg_Buf[Seg_Pos],Seg_Point[Seg_Pos]);
        Led_Disp(Seg_Pos,ucLed[Seg_Pos]);
/* Main函数 */
void main()
        Timer0Init();
        LcdInit();        // LCD12864液晶功能初始化
        LcdShowInit();
        while (1)
                Key_Proc();
                Seg_Proc();
                Led_Proc();
有些是关于lcd12864的代码我去掉了,与这个模块没关系
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
 楼主| dzydybz 发表于 2024-4-6 17:44 来自手机 | 显示全部楼层
就是像这样一样,protues上com端一直在扫描,但是数码管就显示一个一,这也是我想要的结果。
但是显示做的就是不行,数码管疯狂闪动,求求各位大佬,根本想不明白为什么。
@dzydybz :换个思路:只点亮一个数码管,依次显示0~9,刷新频率尽量慢,其他的都灭掉。观察显示0~9的时候,这个数码管是不是还闪烁。如果是,要么硬件电路没焊好要么数码管驱动写的不对。  发表于 2024-4-7 21:06
@minfugan :我改了下这个,这下他不闪烁了,但是不是我想要的效果,我就想要他最高位显示1,但是他现在每个都是全亮:( void Timer0Server() interrupt 1 { if(++Key_Slow_Down == 10) Key_Slow_Down = 0;//键盘减速专用 if(++Seg_Slow_Down == 200) Seg_Slow_Down = 0;//数码管减速专用 if(++Se  发表于 2024-4-7 17:08
大幅调高或者调低刷新频率,再观察实际效果  发表于 2024-4-7 16:11
qinlu123 发表于 2024-4-7 08:24 | 显示全部楼层
看看电路图,还有你的数码管驱动程序在哪里
一叶倾城wwq 发表于 2024-4-7 08:39 | 显示全部楼层
那个delay一定要去掉,当然是刷新频率不够啦
 楼主| dzydybz 发表于 2024-4-7 12:53 来自手机 | 显示全部楼层
这个是数码管底层函数
 楼主| dzydybz 发表于 2024-4-7 12:58 来自手机 | 显示全部楼层
自己焊的与仿真的电路图
 楼主| dzydybz 发表于 2024-4-7 13:00 来自手机 | 显示全部楼层
所以关于自定义延迟函数的的都去掉吗?
 楼主| dzydybz 发表于 2024-4-7 13:05 来自手机 | 显示全部楼层
哦哦,是这两行去掉是吧
一叶倾城wwq 发表于 2024-4-7 13:35 | 显示全部楼层
所以关于自定义延迟函数的的都去掉吗?
我看了下你的主函数,没有用到定时器,那你先不去掉,把delay的次数改小,就不会闪烁了
@dzydybz :是在不行的话,你加我微信(a1255429984),我也不是一直有登录论坛,我给你解决  发表于 2024-4-7 19:20
@dzydybz :数码管每次刷新之前需要清屏,不清屏当然会全亮了  发表于 2024-4-7 19:17
我改了下这个,这下他不闪烁了,但是不是我想要的效果,我就想要他最高位显示1,但是他现在每个都是全亮:( void Timer0Server() interrupt 1 { if(++Key_Slow_Down == 10) Key_Slow_Down = 0;//键盘减速专用 if(++Seg_Slow_Down == 200) Seg_Slow_Down = 0;//数码管减速专用 if(++Seg_Pos == 8) Seg_Pos = 0;//数码管显示专用 Seg_Di  发表于 2024-4-7 17:06
没示波器  发表于 2024-4-7 16:56
@dzydybz :手里有示波器吗?量一下数码管COM口的频率,看看是多少,大于50HZ以上就不闪烁了。  发表于 2024-4-7 16:53
刚才试了试还是不行,数码管还是闪烁  发表于 2024-4-7 16:51
田舍郎 发表于 2024-4-7 22:42 来自手机 | 显示全部楼层
刷新率低了么?
springvirus 发表于 2024-4-8 08:47 | 显示全部楼层
没看你程序,一般闪烁就是由于动态扫描的频率不够高,人眼能看到识别到闪烁,频率足够高时,就看不到了
可以用不同频率来测试显示效果,直到自己满意
