- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.0
- * $Revision: 4 $
- * $Date: 20/06/30 8:04p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Demonstrate how to trigger DAC conversion by software method.
- * SPDX-License-Identifier: Apache-2.0
- * [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2020 Nuvoton Technology Corp. All rights reserved.
- #include "stdio.h"
- #include "NuMicro.h"
- /* Define global variables and constants */
- static uint16_t sine[] = {2047, 2251, 2453, 2651, 2844, 3028, 3202, 3365, 3515, 3650, 3769, 3871, 3954,
- 4019, 4064, 4088, 4095, 4076, 4040, 3984, 3908, 3813, 3701, 3573, 3429, 3272,
- 3102, 2921, 2732, 2536, 2335, 2132, 1927, 1724, 1523, 1328, 1141, 962, 794,
- 639, 497, 371, 262, 171, 99, 45, 12, 0, 7, 35, 84, 151,
- 238, 343, 465, 602, 754, 919, 1095, 1281, 1475, 1674, 1876
- static uint32_t index = 0;
- const uint32_t array_size = sizeof(sine) / sizeof(uint16_t);
- /* Define functions prototype */
- int32_t main(void);
- void DAC_FunctionTest(void);
- void SYS_Init(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System Clock */
- /* Enable HIRC clock (Internal RC 22.1184MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Wait for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Select HIRC as the clock source of UART0 */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
- /* Enable UART peripheral clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable UART module clock */
- /* Enable DAC module clock */
- CLK_EnableModuleClock(DAC0_MODULE);
- /* Init I/O Multi-function */
- /* Set PB multi-function pins for UART0 RXD=PB.6 and TXD=PB.4 */
- SYS->GPB_MFP1 = (SYS->GPB_MFP1 & ~(SYS_GPB_MFP1_PB4MFP_Msk | SYS_GPB_MFP1_PB6MFP_Msk)) | \
- (SYS_GPB_MFP1_PB4MFP_UART0_TXD | SYS_GPB_MFP1_PB6MFP_UART0_RXD);
- void UART0_Init()
- /* Init UART */
- /* Reset UART module */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 baud rate */
- UART_Open(UART0, 115200);
- /* DAC function test */
- void DACFunctionTest(void)
- uint32_t ii;
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| DAC software trigger test |\n");
- printf("\n\nPlease hit any key to start DAC output\n");
- getchar();
- /* modify the test pattern to 5-bit width */
- for(ii=0; ii<sizeof(sine)/2; ii++)
- sine[ii] = (sine[ii]>>7)&0x1F;
- /* Set the software trigger, enable DAC even trigger mode and enable D/A converter */
- DAC_Open(DAC, 0, DAC_SOFTWARE_TRIGGER);
- /* The DAC conversion settling time is 8us */
- DAC_SetDelayTime(DAC, 8);
- /* Enable DAC pin output */
- DAC_ENABLE_OUTPUT(DAC);
- /* Select reference voltage from Vreff */
- DAC_VREFFSRC_AVDD(DAC);
- /* Set DAC 5-bit holding data */
- DAC_WRITE_DATA(DAC, 0, sine[index]);
- /* Clear the DAC conversion complete finish flag for safe */
- DAC_CLR_INT_FLAG(DAC, 0);
- /* Enable the DAC interrupt */
- DAC_ENABLE_INT(DAC, 0);
- NVIC_EnableIRQ(DAC0_IRQn);
- /* Start A/D conversion */
- DAC_START_CONV(DAC);
- printf("\nHit any key to quit!\n");
- while(1)
- if((DEBUG_PORT->FIFOSTS & UART_FIFOSTS_RXEMPTY_Msk) != 0)
- continue;
- else
- break;
- return;
- /* DAC interrupt handler */
- void DAC0_IRQHandler(void)
- if(DAC_GET_INT_FLAG(DAC, 0))
- if(index == array_size)
- index = 0;
- else
- DAC_WRITE_DATA(DAC, 0, sine[index++]);
- /* Clear the DAC conversion complete finish flag */
- return;
- /* Main Function */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- /* SAMPLE CODE */
- printf("\nSystem clock rate: %d Hz\n", SystemCoreClock);
- /* Enable DAC output pin function (PA0/PA1) */
- printf("*****************************************************\n");
- printf("* select PA0 pin function *\n");
- printf("* [0] PA0/PA1 as ICE DAT/CLK *\n");
- printf("* [1] PA0/PA1 as DAC output and VREFF *\n");
- switch(getchar())
- case '0':
- default:
- SYS->GPA_MFP0 &= ~SYS_GPA_MFP0_PA0MFP_Msk;
- SYS->GPA_MFP0 |= SYS_GPA_MFP0_PA0MFP_ICE_DAT;
- SYS->GPA_MFP0 &= ~SYS_GPA_MFP0_PA1MFP_Msk;
- SYS->GPA_MFP0 |= SYS_GPA_MFP0_PA1MFP_ICE_CLK;
- break;
- case '1':
- SYS->GPA_MFP0 |= SYS_GPA_MFP0_PA0MFP_DAC0_OUT;
- SYS->GPA_MFP0 |= SYS_GPA_MFP0_PA1MFP_ADC0_CH1;
- break;
- /* Single Mode test */
- DACFunctionTest();
- /* Reset DAC module */
- SYS_ResetModule(DAC0_RST);
- /* Disable DAC IP clock */
- CLK_DisableModuleClock(DAC0_MODULE);
- /* Disable External Interrupt */
- NVIC_DisableIRQ(DAC0_IRQn);
- printf("Exit DAC sample code\n");
- while(1);
