- static void Usart3RxIrqCallback(void)
- read = USART_RecData(USART3_CH);
- if(RXflage == false)
- RXbuff[readdata] = read;
- if((RXbuff[0] & 0xFF) == 0xAC)
- readdata++;
- if(readdata >= 8)
- readdata = 0;
- RXflage = true;
- static void Usart3TxIrqCallback(void)
- if(TXflage == true)
- { USART_SendData(USART3_CH, TXbuff[writedata+1]);
- writedata++;
- if(writedata >= 7)
- writedata = 0;
- TXflage = false;
- else if(TXflage == false)
- //USART_FuncCmd(USART3_CH, UsartTxEmptyInt, Disable);
- //USART_FuncCmd(USART3_CH, UsartTxCmpltInt, Enable);
- while (Reset == USART_GetStatus(USART3_CH, UsartTxComplete))
- EN_485_L;
- static void Usart3ErrIrqCallback(void)
- if (Set == USART_GetStatus(USART3_CH, UsartFrameErr))
- USART_ClearStatus(USART3_CH, UsartFrameErr);
- if (Set == USART_GetStatus(USART3_CH, UsartParityErr))
- USART_ClearStatus(USART3_CH, UsartParityErr);
- if (Set == USART_GetStatus(USART3_CH, UsartOverrunErr))
- USART_ClearStatus(USART3_CH, UsartOverrunErr);
- if (Set == USART_GetStatus(USART3_CH, UsartRxNoEmpty))
- USART_ClearStatus(USART3_CH, UsartRxNoEmpty);
- if (Set == USART_GetStatus(USART3_CH, UsartTxComplete))
- USART_ClearStatus(USART3_CH, UsartTxComplete);
- if (Set == USART_GetStatus(USART3_CH, UsartTxEmpty))
- USART_ClearStatus(USART3_CH, UsartTxEmpty);
- if (Set == USART_GetStatus(USART3_CH, UsartRxTimeOut))
- USART_ClearStatus(USART3_CH, UsartRxTimeOut);
- if (Set == USART_GetStatus(USART3_CH, UsartRxMpb))
- USART_ClearStatus(USART3_CH, UsartRxMpb);
- static void Usart3TimeoutIrqCallback(void)
- TIMER0_Cmd(TMR_UNIT,Tim0_ChannelA,Disable);
- //USART3_CH->CR1_f.CRTOF = 1ul;
- static void Usart3TxCmpltIrqCallback(void)
- USART_FuncCmd(USART3_CH,UsartTx,Disable);
- USART_FuncCmd(USART3_CH,UsartTxCmpltInt,Disable);
- void Uart3_Init(void)
- en_result_t enRet = Ok;
- stc_irq_regi_conf_t stcIrqRegiCfg;
- const stc_usart_uart_init_t stcInitCfg = {
- UsartIntClkCkNoOutput,
- //UsartIntClkCkOutput,
- UsartClkDiv_64,
- UsartDataBits8,
- UsartDataLsbFirst,
- UsartOneStopBit,
- UsartParityNone,
- UsartSampleBit8,
- UsartStartBitFallEdge,
- UsartRtsEnable,
- PWC_Fcg1PeriphClockCmd(PWC_FCG1_PERIPH_USART3,Enable);
- PORT_SetFunc(USART3_RX_PORT,USART3_RX_PIN,USART3_RX_FUNC,Disable);
- PORT_SetFunc(USART3_TX_PORT,USART3_TX_PIN,USART3_TX_FUNC,Disable);
- enRet = USART_UART_Init(USART3_CH,&stcInitCfg);
- if(enRet != Ok)
- while(1)
- enRet = USART_SetBaudrate(USART3_CH,USART3_BAUDRATE);
- if(enRet != Ok)
- while(1)
- stcIrqRegiCfg.enIRQn = Int001_IRQn;
- stcIrqRegiCfg.pfnCallback = &Usart3RxIrqCallback;
- stcIrqRegiCfg.enIntSrc = USART3_RI_NUM;
- enIrqRegistration(&stcIrqRegiCfg);
- NVIC_SetPriority(stcIrqRegiCfg.enIRQn, DDL_IRQ_PRIORITY_DEFAULT);
- NVIC_ClearPendingIRQ(stcIrqRegiCfg.enIRQn);
- NVIC_EnableIRQ(stcIrqRegiCfg.enIRQn);
- stcIrqRegiCfg.enIRQn = Int002_IRQn;
- stcIrqRegiCfg.pfnCallback = &Usart3ErrIrqCallback;
- stcIrqRegiCfg.enIntSrc = USART3_EI_NUM;
- stcIrqRegiCfg.enIRQn = Int008_IRQn;
- stcIrqRegiCfg.pfnCallback = &Usart3TimeoutIrqCallback;
- stcIrqRegiCfg.enIntSrc = USART3_RTO_NUM;
- stcIrqRegiCfg.enIRQn = Int000_IRQn;
- stcIrqRegiCfg.pfnCallback = &Usart3TxIrqCallback;
- stcIrqRegiCfg.enIntSrc = USART3_TI_NUM;
- stcIrqRegiCfg.enIRQn = Int004_IRQn;
- stcIrqRegiCfg.pfnCallback = &Usart3TxCmpltIrqCallback;
- stcIrqRegiCfg.enIntSrc = USART3_TCI_NUM;
- USART_FuncCmd(USART3_CH, UsartRx, Enable);
- USART_FuncCmd(USART3_CH, UsartRxInt, Enable);
- USART_FuncCmd(USART3_CH, UsartTx, Enable);
- USART_FuncCmd(USART3_CH, UsartTimeOut, Enable);
- USART_FuncCmd(USART3_CH, UsartTimeOutInt, Enable);
- USART_FuncCmd(USART3_CH, UsartTxEmptyInt, Enable);
- //USART_SetMode(USART3_CH, UsartUartMode);
