[技术问答] 为什么M0518的PF5配成PWM输出一直输出0V
1938|2
 楼主| flycamelaaa 发表于 2024-5-14 15:45 | 显示全部楼层 |阅读模式
  /* Enable PWM1 clock source */
    CLK_EnableModuleClock(PWM1_MODULE);
                /* Select PWM module clock source */
    //CLK_SetModuleClock(PWM0_MODULE, CLK_CLKSEL3_PWM0_S_HClK, 0);
    CLK_SetModuleClock(PWM1_MODULE, CLK_CLKSEL3_PWM1_S_PCLK, 0);
    /* Reset PWM0 */
    SYS_ResetModule(PWM1_RST);
                    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
          /* Set GPA multi-function pins for PWM1 Channel 2 */
    SYS->GPA_MFP &= ~(SYS_GPA_MFP_PA10_Msk);
    SYS->GPA_MFP |= (SYS_GPA_MFP_PA10_PWM1_CH2);
          /* Set GPA multi-function pins for PWM1 Channel 5 */
    SYS->GPF_MFP &= ~(SYS_GPF_MFP_PF5_Msk);
    SYS->GPF_MFP |= (SYS_GPF_MFP_PF5_PWM1_CH5);
SYS->ALT_MFP3 |= SYS_ALT_MFP3_PA10_PWM1_CH2;
SYS->ALT_MFP3 |= SYS_ALT_MFP3_PF5_PWM1_CH5;
奔跑的牛 发表于 2024-6-11 10:03 | 显示全部楼层
小灵通2018 发表于 2024-6-13 22:39 | 显示全部楼层
看看其他的IO配置代码啊,是不是又操作了这个IO
