[STM32F4] 使用DMA发送DAC数据,为啥不进传输完成中断
1167|8
 楼主| 洗个菠萝 发表于 2024-5-16 14:42 | 显示全部楼层 |阅读模式
  1. void dac2_dma_config(void)
  3.     // 使能相关时钟
  4.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  5.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  6.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  7.     // 配置PA4为模拟输出
  8.     GPIO_InitTypeDef GPIO_InitStructure;
  9.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  10.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  11.     GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  12.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  13.     // DAC Channel 1 配置
  14.     DAC_InitTypeDef DAC_InitStructure;
  15.     DAC_DeInit();                                     // 重置DAC
  16.     DAC_InitStructure.DAC_Trigger = DAC_Trigger_None; // 软件触发
  17.     DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  18.     DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_LFSRUnmask_Bit0;
  19.     DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
  20.     DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  21.     DMA_DeInit(DMA1_Stream5); // 先清除之前可能存在的配置
  22.     while (DMA_GetCmdStatus(DMA1_Stream5) != DISABLE)
  23.     {
  24.     } // 等待DMA1_Stream5可配置
  25.     DMA_ClearITPendingBit(DMA1_Stream5, DMA_IT_FEIF5 | DMA_IT_DMEIF5 | DMA_IT_TEIF5 | DMA_IT_HTIF5 | DMA_IT_TCIF5); // 清空DMA1_Stream6上所有中断标志
  26.     DMA_InitTypeDef DMA_InitStructure;
  27.     DMA_InitStructure.DMA_Channel = DMA_Channel_7;                              // 对应于DAC的DMA通道
  28.     DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(DAC->DHR12R1));     // DAC通道1的12位右对齐数据保持寄存器地址
  29.     DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&dma_buffer[0];           // 数据缓冲区地址
  30.     DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;                     // 存储器到外设模式
  31.     DMA_InitStructure.DMA_BufferSize = BUFFER_SIZE;                             // 数据传输
  32.     DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;            // 外设非增量模式
  33.     DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                     // 存储器增量模式
  34.     DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; // 外设数据长度:16字节
  35.     DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;         // 存储器数据长度:16字节
  36.     DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                             // 使用循环模式
  37.     DMA_InitStructure.DMA_Priority = DMA_Priority_High;                         // 高优先级
  38.     DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;                      // 不使用FIFO模式
  39.     DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  40.     DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;                 // 外设突发单次传输
  41.     DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;         // 存储器突发单次传输
  42.     DMA_Init(DMA1_Stream5, &DMA_InitStructure);                                 // 初始化DMA Stream
  43.     // 使能DMA中断
  44.     DMA_ITConfig(DMA1_Stream5, DMA_IT_TC, ENABLE);
  45.     // 配置NVIC
  46.     NVIC_InitTypeDef NVIC_InitStructure;
  47.     NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream5_IRQn;
  48.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  49.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  50.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  51.     NVIC_Init(&NVIC_InitStructure);
  52.     // 使能DAC和DMA
  53.     DAC_Cmd(DAC_Channel_1, ENABLE);
  54.     DAC_DMACmd(DAC_Channel_1, ENABLE);
  55.     DMA_Cmd(DMA1_Stream5, ENABLE);
  56. }
  1. void DMA1_Stream5_IRQHandler(void)
  3.     if (DMA_GetITStatus(DMA1_Stream5, DMA_IT_TCIF5) == SET) // DMA1_Stream5,传输完成标志
  4.     {
  5.         DMA_ClearITPendingBit(DMA1_Stream5, DMA_IT_TCIF5);
  6.         usart_printf("**********DMA1_Stream5_IRQHandler********\r\n");
  7.     }
  8. }
使用DAC_SoftwareTriggerCmd(DAC_Channel_1, ENABLE);软件触发
jcky001 发表于 2024-6-12 10:18 | 显示全部楼层
检查DMA配置是否正确
呐咯密密 发表于 2024-6-12 15:09 | 显示全部楼层
传输完成了吗
cr315 发表于 2024-6-13 10:00 | 显示全部楼层
检查DAC配置还有中断配置是否有误
EmmaTT 发表于 2024-6-18 22:28 | 显示全部楼层
这是程序写的有问题吧
是你的乱码 发表于 2024-8-31 13:54 | 显示全部楼层
检查DMA的源地址、目标地址、数据方向和传输模式是否正确设置。
花间一壶酒sd 发表于 2024-8-31 21:57 | 显示全部楼层
确认DMA传输完成中断已经使能。检查相关的DMA中断使能位是否被设置。
