- void dac2_dma_config(void)
- // 使能相关时钟
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
- // 配置PA4为模拟输出
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- // DAC Channel 1 配置
- DAC_InitTypeDef DAC_InitStructure;
- DAC_DeInit(); // 重置DAC
- DAC_InitStructure.DAC_Trigger = DAC_Trigger_None; // 软件触发
- DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
- DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_LFSRUnmask_Bit0;
- DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
- DAC_Init(DAC_Channel_1, &DAC_InitStructure);
- DMA_DeInit(DMA1_Stream5); // 先清除之前可能存在的配置
- while (DMA_GetCmdStatus(DMA1_Stream5) != DISABLE)
- } // 等待DMA1_Stream5可配置
- DMA_ClearITPendingBit(DMA1_Stream5, DMA_IT_FEIF5 | DMA_IT_DMEIF5 | DMA_IT_TEIF5 | DMA_IT_HTIF5 | DMA_IT_TCIF5); // 清空DMA1_Stream6上所有中断标志
- DMA_InitTypeDef DMA_InitStructure;
- DMA_InitStructure.DMA_Channel = DMA_Channel_7; // 对应于DAC的DMA通道
- DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(DAC->DHR12R1)); // DAC通道1的12位右对齐数据保持寄存器地址
- DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&dma_buffer[0]; // 数据缓冲区地址
- DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; // 存储器到外设模式
- DMA_InitStructure.DMA_BufferSize = BUFFER_SIZE; // 数据传输
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; // 外设非增量模式
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; // 存储器增量模式
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; // 外设数据长度:16字节
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; // 存储器数据长度:16字节
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; // 使用循环模式
- DMA_InitStructure.DMA_Priority = DMA_Priority_High; // 高优先级
- DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; // 不使用FIFO模式
- DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
- DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; // 外设突发单次传输
- DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; // 存储器突发单次传输
- DMA_Init(DMA1_Stream5, &DMA_InitStructure); // 初始化DMA Stream
- // 使能DMA中断
- DMA_ITConfig(DMA1_Stream5, DMA_IT_TC, ENABLE);
- // 配置NVIC
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream5_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- // 使能DAC和DMA
- DAC_Cmd(DAC_Channel_1, ENABLE);
- DAC_DMACmd(DAC_Channel_1, ENABLE);
- DMA_Cmd(DMA1_Stream5, ENABLE);
- void DMA1_Stream5_IRQHandler(void)
- if (DMA_GetITStatus(DMA1_Stream5, DMA_IT_TCIF5) == SET) // DMA1_Stream5,传输完成标志
- DMA_ClearITPendingBit(DMA1_Stream5, DMA_IT_TCIF5);
- usart_printf("**********DMA1_Stream5_IRQHandler********\r\n");
使用DAC_SoftwareTriggerCmd(DAC_Channel_1, ENABLE);软件触发
