[少儿编程] 深度学习圣经:Deep learning
2686|2
 楼主| keer_zu 发表于 2024-5-17 09:33 来自手机 | 显示全部楼层 |阅读模式
Deep Learning by Ian Goodfellow, Yoshua Bengio, Aaron Courville (z-lib.org).pdf (18.39 MB, 下载次数: 20)
 楼主| keer_zu 发表于 2024-5-17 10:05 | 显示全部楼层
If we had separate parameters  for each value of the time index, we could not generalize to sequence lengths not  seen during training, nor share statistical strength across different sequence lengths  and across different positions in time.
The idea of parameter sharing manifests in the application of the same convolution kernel at each time step.  发表于 2024-5-17 13:22
