- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 1 $
- * $Date: 15/11/05 11:31a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Mini58 SPI Driver Sample Code
- * This is a SPI master mode demo and need to be tested with a slave device.
- * @note
- * Copyright (C) 2015 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "Mini58Series.h"
- #define TEST_COUNT 16
- uint32_t g_au32SourceData[TEST_COUNT];
- uint32_t g_au32DestinationData[TEST_COUNT];
- volatile uint32_t g_u32TxDataCount = 0;
- volatile uint32_t g_u32RxDataCount = 0;
- void SYS_Init(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- SYS_UnlockReg();
- /* Init System Clock */
- /* Set P5 multi-function pins for XTAL1 and XTAL2 */
- SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
- SYS->P5_MFP |= (SYS_MFP_P50_XT1_IN | SYS_MFP_P51_XT1_OUT);
- /* Enable external 12MHz XTAL, HIRC */
- CLK->PWRCTL |= CLK_PWRCTL_XTL12M | CLK_PWRCTL_HIRCEN_Msk;
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_STATUS_XTLSTB_Msk | CLK_STATUS_HIRCSTB_Msk);
- /* Switch HCLK clock source to XTL */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_XTAL,CLK_CLKDIV_HCLK(1));
- /* STCLK to XTL STCLK to XTL */
- CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_XTAL);
- /* Enable IP clock */
- CLK_EnableModuleClock(UART0_MODULE);
- CLK_EnableModuleClock(SPI0_MODULE);
- /* Select IP clock source */
- CLK_SetModuleClock(UART0_MODULE,CLK_CLKSEL1_UARTSEL_XTAL,CLK_CLKDIV_UART(1));
- CLK_SetModuleClock(SPI0_MODULE,CLK_CLKSEL1_SPISEL_XTAL,0);
- /* Init I/O Multi-function */
- /* Set P1 multi-function pins for UART RXD and TXD */
- SYS->P1_MFP &= ~(SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
- SYS->P1_MFP |= (SYS_MFP_P12_UART0_RXD | SYS_MFP_P13_UART0_TXD);
- /* Setup SPI multi-function pin */
- SYS->P0_MFP |= SYS_MFP_P04_SPI0_SS | SYS_MFP_P05_SPI0_MOSI | SYS_MFP_P06_SPI0_MISO | SYS_MFP_P07_SPI0_CLK;
- /* Lock protected registers */
- SYS_LockReg();
- /* Update System Core Clock */
- SystemCoreClockUpdate();
- void UART_Init(void)
- /* Init UART */
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART and set UART Baudrate */
- UART_Open(UART0, 115200);
- void SPI_Init(void)
- /* Init SPI */
- /* Configure as a master, clock idle low, falling clock edge Tx, rising edge Rx and 32-bit transaction */
- /* Set IP clock divider. SPI clock rate = 1MHz */
- SPI_Open(SPI, SPI_MASTER, SPI_MODE_0, 32, 1000000);
- /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
- SPI_EnableAutoSS(SPI, SPI_SS, SPI_SS_ACTIVE_LOW);
- void SPI_IRQHandler(void)
- uint32_t temp;
- while((SPI_GET_RX_FIFO_EMPTY_FLAG(SPI0))==0)
- temp = SPI_READ_RX(SPI0);
- g_au32DestinationData[g_u32RxDataCount++] = temp;
- while( (SPI_GET_TX_FIFO_FULL_FLAG(SPI0)==0) && (g_u32TxDataCount<TEST_COUNT) )
- SPI_WRITE_TX(SPI0, g_au32SourceData[g_u32TxDataCount++]);
- if(g_u32TxDataCount>=TEST_COUNT)
- SPI_DisableInt(SPI0, SPI_FIFO_TX_INTEN_MASK); /* Disable TX FIFO threshold interrupt */
- int main(void)
- uint32_t u32DataCount;
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Init UART for printf */
- UART_Init();
- /* Init SPI */
- SPI_Init();
- printf("\n\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| SPI Driver Sample Code |\n");
- printf("\n");
- printf("Configure SPI as a master.\n");
- printf("SPI clock rate: %d Hz\n", SPI_GetBusClock(SPI0));
- for(u32DataCount=0; u32DataCount<TEST_COUNT; u32DataCount++)
- g_au32SourceData[u32DataCount] = 0x00550000 + u32DataCount;
- g_au32DestinationData[u32DataCount] = 0;
- printf("Before starting the data transfer, make sure the slave device is ready. Press any key to start the transfer.\n");
- getchar();
- printf("\n");
- SPI_EnableInt(SPI0, SPI_FIFO_TX_INTEN_MASK | SPI_FIFO_RX_INTEN_MASK);
- NVIC_EnableIRQ(SPI_IRQn);
- SPI_EnableFIFO(SPI0, 2, 1);
- /* Wait for transfer done */
- while(g_u32RxDataCount<TEST_COUNT);
- printf("Received data:\n");
- printf("%d:\t0x%08X\n", u32DataCount, g_au32DestinationData[u32DataCount]);
- printf("The data transfer was done.\n");
- while(1);
