- /* USER CODE BEGIN Header */
- * [url=home.php?mod=space&uid=288409]@file[/url] DMA/DMA_FLASHToRAM/Src/main.c
- * [url=home.php?mod=space&uid=187600]@author[/url] MCD Application Team
- * [url=home.php?mod=space&uid=247401]@brief[/url] This example provides a description of how to use a DMA channel
- * to transfer a word data buffer from FLASH memory to embedded
- * SRAM memory through the STM32H5xx HAL API.
- * @attention
- * Copyright (c) 2023 STMicroelectronics.
- * All rights reserved.
- * This software is licensed under terms that can be found in the LICENSE file
- * in the root directory of this software component.
- * If no LICENSE file comes with this software, it is provided AS-IS.
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include <string.h>
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- DMA_HandleTypeDef handle_GPDMA1_Channel0;
- /* USER CODE BEGIN PV */
- static const uint32_t aSRC_Const_Buffer[BUFFER_SIZE] =
- 0x01020304, 0x05060708, 0x090A0B0C, 0x0D0E0F10,
- 0x11121314, 0x15161718, 0x191A1B1C, 0x1D1E1F20,
- 0x21222324, 0x25262728, 0x292A2B2C, 0x2D2E2F30,
- 0x31323334, 0x35363738, 0x393A3B3C, 0x3D3E3F40,
- 0x41424344, 0x45464748, 0x494A4B4C, 0x4D4E4F50,
- 0x51525354, 0x55565758, 0x595A5B5C, 0x5D5E5F60,
- 0x61626364, 0x65666768, 0x696A6B6C, 0x6D6E6F70,
- 0x71727374, 0x75767778, 0x797A7B7C, 0x7D7E7F80
- static uint32_t aDST_Buffer[BUFFER_SIZE];
- static __IO uint32_t transferErrorDetected; /* Set to 1 if an error transfer is detected */
- static __IO uint32_t transferCompleteDetected; /* Set to 1 if transfer is correctly completed */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void MX_GPIO_Init(void);
- static void MX_GPDMA1_Init(void);
- static void MX_ICACHE_Init(void);
- /* USER CODE BEGIN PFP */
- static void TransferComplete(DMA_HandleTypeDef *handle_GPDMA1_Channel0);
- static void TransferError(DMA_HandleTypeDef *handle_GPDMA1_Channel0);
- static uint32_t Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* STM32H5xx HAL library initialization:
- - Systick timer is configured by default as source of time base, but user
- can eventually implement his proper time base source (a general purpose
- timer for example or other time source), keeping in mind that Time base
- duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
- handled in milliseconds basis.
- - Set NVIC Group Priority to 4
- - Low Level Initialization
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_GPDMA1_Init();
- MX_ICACHE_Init();
- /* USER CODE BEGIN 2 */
- /* Initialize LED2 */
- BSP_LED_Init(LED2);
- /* Reset transferErrorDetected to 0, it will be set to 1 if a transfer error is detected */
- transferErrorDetected = 0;
- /* Reset transferCompleteDetected to 0, it will be set to 1 if a transfer is correctly completed */
- transferCompleteDetected = 0;
- /* Select Callbacks functions called after Transfer complete and Transfer error */
- HAL_DMA_RegisterCallback(&handle_GPDMA1_Channel0, HAL_DMA_XFER_CPLT_CB_ID, TransferComplete);
- HAL_DMA_RegisterCallback(&handle_GPDMA1_Channel0, HAL_DMA_XFER_ERROR_CB_ID, TransferError);
- /* Clean destination buffer */
- memset((void *)aDST_Buffer, 0U, sizeof(aDST_Buffer) );
- /* Configure the source, destination and buffer size DMA fields and Start DMA Channel/Stream transfer */
- /* Enable All the DMA interrupts */
- if (HAL_DMA_Start_IT(&handle_GPDMA1_Channel0, (uint32_t)&aSRC_Const_Buffer, (uint32_t)&aDST_Buffer, sizeof(aDST_Buffer)) != HAL_OK)
- /* Transfer Error */
- Error_Handler();
- /* Wait for end of transmission or an error occurred */
- while ((transferCompleteDetected == 0) && (transferErrorDetected == 0U));
- /* Check DMA error */
- if (transferErrorDetected == 1U)
- Error_Handler();
- /* Check destination aDST_Buffer */
- if (Buffercmp((uint8_t *)aSRC_Const_Buffer, (uint8_t *)aDST_Buffer, (BUFFER_SIZE * 4U)) != 0U)
- Error_Handler();
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- /* Turn LED2 on*/
- BSP_LED_On(LED2);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Configure the main internal regulator output voltage
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0);
- while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
- /** Initializes the RCC Oscillators according to the specified parameters
- * in the RCC_OscInitTypeDef structure.
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLL1_SOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLM = 12;
- RCC_OscInitStruct.PLL.PLLN = 250;
- RCC_OscInitStruct.PLL.PLLP = 2;
- RCC_OscInitStruct.PLL.PLLQ = 2;
- RCC_OscInitStruct.PLL.PLLR = 2;
- RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1_VCIRANGE_1;
- RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1_VCORANGE_WIDE;
- RCC_OscInitStruct.PLL.PLLFRACN = 0;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB buses clocks
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
- |RCC_CLOCKTYPE_PCLK3;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
- Error_Handler();
- /** Configure the programming delay
- __HAL_FLASH_SET_PROGRAM_DELAY(FLASH_PROGRAMMING_DELAY_2);
- * @brief GPDMA1 Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN GPDMA1_Init 0 */
- /* USER CODE END GPDMA1_Init 0 */
- /* Peripheral clock enable */
- __HAL_RCC_GPDMA1_CLK_ENABLE();
- /* GPDMA1 interrupt Init */
- HAL_NVIC_SetPriority(GPDMA1_Channel0_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(GPDMA1_Channel0_IRQn);
- /* USER CODE BEGIN GPDMA1_Init 1 */
- /* USER CODE END GPDMA1_Init 1 */
- handle_GPDMA1_Channel0.Instance = GPDMA1_Channel0;
- handle_GPDMA1_Channel0.Init.Request = DMA_REQUEST_SW;
- handle_GPDMA1_Channel0.Init.BlkHWRequest = DMA_BREQ_SINGLE_BURST;
- handle_GPDMA1_Channel0.Init.Direction = DMA_MEMORY_TO_MEMORY;
- handle_GPDMA1_Channel0.Init.SrcInc = DMA_SINC_INCREMENTED;
- handle_GPDMA1_Channel0.Init.DestInc = DMA_DINC_INCREMENTED;
- handle_GPDMA1_Channel0.Init.SrcDataWidth = DMA_SRC_DATAWIDTH_WORD;
- handle_GPDMA1_Channel0.Init.DestDataWidth = DMA_DEST_DATAWIDTH_WORD;
- handle_GPDMA1_Channel0.Init.Priority = DMA_LOW_PRIORITY_HIGH_WEIGHT;
- handle_GPDMA1_Channel0.Init.SrcBurstLength = 1;
- handle_GPDMA1_Channel0.Init.DestBurstLength = 1;
- handle_GPDMA1_Channel0.Init.TransferAllocatedPort = DMA_SRC_ALLOCATED_PORT0|DMA_DEST_ALLOCATED_PORT1;
- handle_GPDMA1_Channel0.Init.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
- handle_GPDMA1_Channel0.Init.Mode = DMA_NORMAL;
- if (HAL_DMA_Init(&handle_GPDMA1_Channel0) != HAL_OK)
- Error_Handler();
- if (HAL_DMA_ConfigChannelAttributes(&handle_GPDMA1_Channel0, DMA_CHANNEL_NPRIV) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN GPDMA1_Init 2 */
- /* USER CODE END GPDMA1_Init 2 */
- * @brief ICACHE Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN ICACHE_Init 0 */
- /* USER CODE END ICACHE_Init 0 */
- /* USER CODE BEGIN ICACHE_Init 1 */
- /* USER CODE END ICACHE_Init 1 */
- /** Enable instruction cache (default 2-ways set associative cache)
- if (HAL_ICACHE_Enable() != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN ICACHE_Init 2 */
- /* USER CODE END ICACHE_Init 2 */
- * @brief GPIO Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN MX_GPIO_Init_1 */
- /* USER CODE END MX_GPIO_Init_1 */
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOH_CLK_ENABLE();
- /* USER CODE BEGIN MX_GPIO_Init_2 */
- /* USER CODE END MX_GPIO_Init_2 */
- /* USER CODE BEGIN 4 */
- * @brief DMA conversion complete callback
- * [url=home.php?mod=space&uid=536309]@NOTE[/url] This function is executed when the transfer complete interrupt
- * is generated
- * @retval None
- transferCompleteDetected = 1;
- * @brief DMA conversion error callback
- * @note This function is executed when the transfer error interrupt
- * is generated during DMA transfer
- * @retval None
- transferErrorDetected = 1;
- * @brief Compares two buffers.
- * @param pBuffer1, pBuffer2: buffers to be compared.
- * @param BufferLength: buffer's length
- * @retval 0 : pBuffer1 identical to pBuffer2
- * > 0 : pBuffer1 differs from pBuffer2
- while (BufferLength--)
- if ((*pBuffer1) != *pBuffer2)
- return BufferLength;
- pBuffer1++;
- pBuffer2++;
- return 0;
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- while (1)
- /* Toggle LED2 with a period of 1 s */
- BSP_LED_Toggle(LED2);
- HAL_Delay(1000);
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- while (1)
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
当编译运行后,不能再次下载其他程序。
并且报告下面的错误?
这是怎么个情况,该怎么做呢?
用相关工具也没有检测到stlink?
怎么办呢?
