EmbeddedBuilder_v1.4.1.23782 打开工程 EXTI_Key_external_interrupt_mode 无法图形化配置
1470|0
 楼主| lostspeed 发表于 2024-8-10 14:18 | 显示全部楼层 |阅读模式
打开 D:\EmbeddedBuilder_v1.4.1.23782\EmbeddedBuilder\Embedded Builder.exe
引入工程 D:\EmbeddedBuilder_v1.4.1.23782\examples\GD32F3x0\examples\EXTI\EXTI_Key_external_interrupt_mode 成功
双击Key_external_interrupt_mode.gdc,报错 Failed to create the part's controls
有没有GD原厂的同学帮看一下,是EmbeddedBuilder_v1.4.1.23782有bug, 还是EmbeddedBuilder_v1.4.1.23782自带的.gdc有问题?
具体报错的信息如下:
  1. java.lang.NullPointerException: Cannot invoke "org.eclipse.core.runtime.IPath.toOSString()" because the return value of "org.eclipse.core.resources.IProject.getLocation()" is null
  2.         at com.gigadevice.gdconfig.ui.access.SerializeAccess.GetGdcFilePath(SerializeAccess.java:60)
  3.         at com.gigadevice.gdconfig.ui.access.SerializeAccess_Template.DeserializeExtract(SerializeAccess_Template.java:100)
  4.         at com.gigadevice.gdconfig.ui.editor.GDCEditor.createPartControl(GDCEditor.java:170)
  5.         at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:158)
  6.         at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
  7.         at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:365)
  8.         at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  9.         at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
  10.         at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  11.         at java.base/java.lang.reflect.Method.invoke(Method.java:568)
  12.         at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
  13.         at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:976)
  14.         at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:938)
  15.         at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:138)
  16.         at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:385)
  17.         at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:311)
  18.         at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:203)
  19.         at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
  20.         at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
  21.         at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
  22.         at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
  23.         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:995)
  24.         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
  25.         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:763)
  26.         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:728)
  27.         at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:47)
  28.         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:712)
  29.         at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:105)
  30.         at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
  31.         at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:183)
  32.         at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
  33.         at org.eclipse.swt.widgets.Display.syncExec(Display.java:4802)
  34.         at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
  35.         at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
  36.         at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:208)
  37.         at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:206)
  38.         at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
  39.         at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
  40.         at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
  41.         at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
  42.         at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
  43.         at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
  44.         at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
  45.         at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
  46.         at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
  47.         at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
  48.         at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
  49.         at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:661)
  50.         at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:625)
  51.         at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:796)
  52.         at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
  53.         at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1270)
  54.         at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3233)
  55.         at org.eclipse.ui.internal.WorkbenchPage.lambda$11(WorkbenchPage.java:3123)
  56.         at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
  57.         at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3121)
  58.         at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3091)
  59.         at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:325)
  60.         at org.eclipse.ui.actions.OpenWithMenu.lambda$0(OpenWithMenu.java:182)
  61.         at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
  62.         at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4273)
  63.         at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
  64.         at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4071)
  65.         at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3659)
  66.         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
  67.         at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:342)
  68.         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
  69.         at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
  70.         at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:648)
  71.         at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:342)
  72.         at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:555)
  73.         at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:173)
  74.         at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
  75.         at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:208)
  76.         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
  77.         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
  78.         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
  79.         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
  80.         at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  81.         at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
  82.         at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  83.         at java.base/java.lang.reflect.Method.invoke(Method.java:568)
  84.         at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:651)
  85.         at org.eclipse.equinox.launcher.Main.basicRun(Main.java:588)
  86.         at org.eclipse.equinox.launcher.Main.run(Main.java:1459)
