[STM32H7] 【STM32H7S78-DK测评】-进阶任务之JPEG
2388|3
 楼主| HuaWng 发表于 2024-10-11 17:48 | 显示全部楼层 |阅读模式
STM32H7自带了8bit的JPEG编解码模块,能够解码使用JPEG压缩算法的图像数据流。与此同时,该模块也能够很好的处理JPEG Header。
参考数据手册,JPEG硬件编解码模块的主要特性如下:
    • High-speed fully synchronous operation
    • Configurable as encoder or decoder
    • Single-clock-per-pixel encode/decode
    • RGB, YCbCr, YCMK, and BW (gray scale) image color
    • 8-bit depth per image component at encode/decode
    • JPEG header generator/parser with enable/disable
    • Four programmable quantization tables
    • Single-clock Huffman coding and decoding
    • Fully programmable Huffman tables (two AC and two
    • Fully programmable minimum coded unit (MCU)
    • Concurrent input and output data stream interfaces
JPEG codec的硬件框图如下:
JPEG硬件驱动设计框架:
JPEG编解码的数据流是通过MDMA进行搬运的,因此首先要配置好JPEG与DMA的协同工作模式。
  1. void HAL_JPEG_MspInit(JPEG_HandleTypeDef* hjpeg)
  3.   if(hjpeg->Instance==JPEG)
  4.   {
  5.   /* USER CODE BEGIN JPEG_MspInit 0 */
  6.   /* USER CODE END JPEG_MspInit 0 */
  7.     /* Peripheral clock enable */
  8.     __HAL_RCC_JPEG_CLK_ENABLE();
  9.     /* JPEG DMA Init */
  10.     /* HPDMA1_REQUEST_JPEG_TX Init */
  11.     handle_HPDMA1_Channel1.Instance = HPDMA1_Channel1;
  12.     handle_HPDMA1_Channel1.Init.Request = HPDMA1_REQUEST_JPEG_TX;
  13.     handle_HPDMA1_Channel1.Init.BlkHWRequest = DMA_BREQ_SINGLE_BURST;
  14.     handle_HPDMA1_Channel1.Init.Direction = DMA_PERIPH_TO_MEMORY;
  15.     handle_HPDMA1_Channel1.Init.SrcInc = DMA_SINC_FIXED;
  16.     handle_HPDMA1_Channel1.Init.DestInc = DMA_DINC_INCREMENTED;
  17.     handle_HPDMA1_Channel1.Init.SrcDataWidth = DMA_SRC_DATAWIDTH_WORD;
  18.     handle_HPDMA1_Channel1.Init.DestDataWidth = DMA_DEST_DATAWIDTH_WORD;
  19.     handle_HPDMA1_Channel1.Init.Priority = DMA_LOW_PRIORITY_LOW_WEIGHT;
  20.     handle_HPDMA1_Channel1.Init.SrcBurstLength = 8;
  21.     handle_HPDMA1_Channel1.Init.DestBurstLength = 8;
  22.     handle_HPDMA1_Channel1.Init.TransferAllocatedPort = DMA_SRC_ALLOCATED_PORT1|DMA_DEST_ALLOCATED_PORT0;
  23.     handle_HPDMA1_Channel1.Init.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
  24.     handle_HPDMA1_Channel1.Init.Mode = DMA_NORMAL;
  25.     if (HAL_DMA_Init(&handle_HPDMA1_Channel1) != HAL_OK)
  26.     {
  27.       Error_Handler();
  28.     }
  29.     __HAL_LINKDMA(hjpeg, hdmaout, handle_HPDMA1_Channel1);
  30.     if (HAL_DMA_ConfigChannelAttributes(&handle_HPDMA1_Channel1, DMA_CHANNEL_NPRIV) != HAL_OK)
  31.     {
  32.       Error_Handler();
  33.     }
  34.     /* HPDMA1_REQUEST_JPEG_RX Init */
  35.     handle_HPDMA1_Channel0.Instance = HPDMA1_Channel0;
  36.     handle_HPDMA1_Channel0.Init.Request = HPDMA1_REQUEST_JPEG_RX;
  37.     handle_HPDMA1_Channel0.Init.BlkHWRequest = DMA_BREQ_SINGLE_BURST;
  38.     handle_HPDMA1_Channel0.Init.Direction = DMA_MEMORY_TO_PERIPH;
  39.     handle_HPDMA1_Channel0.Init.SrcInc = DMA_SINC_INCREMENTED;
  40.     handle_HPDMA1_Channel0.Init.DestInc = DMA_DINC_FIXED;
  41.     handle_HPDMA1_Channel0.Init.SrcDataWidth = DMA_SRC_DATAWIDTH_WORD;
  42.     handle_HPDMA1_Channel0.Init.DestDataWidth = DMA_DEST_DATAWIDTH_WORD;
  43.     handle_HPDMA1_Channel0.Init.Priority = DMA_LOW_PRIORITY_LOW_WEIGHT;
  44.     handle_HPDMA1_Channel0.Init.SrcBurstLength = 8;
  45.     handle_HPDMA1_Channel0.Init.DestBurstLength = 8;
  46.     handle_HPDMA1_Channel0.Init.TransferAllocatedPort = DMA_SRC_ALLOCATED_PORT0|DMA_DEST_ALLOCATED_PORT1;
  47.     handle_HPDMA1_Channel0.Init.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
  48.     handle_HPDMA1_Channel0.Init.Mode = DMA_NORMAL;
  49.     if (HAL_DMA_Init(&handle_HPDMA1_Channel0) != HAL_OK)
  50.     {
  51.       Error_Handler();
  52.     }
  53.     __HAL_LINKDMA(hjpeg, hdmain, handle_HPDMA1_Channel0);
  54.     if (HAL_DMA_ConfigChannelAttributes(&handle_HPDMA1_Channel0, DMA_CHANNEL_NPRIV) != HAL_OK)
  55.     {
  56.       Error_Handler();
  57.     }
  58.     /* JPEG interrupt Init */
  59.     HAL_NVIC_SetPriority(JPEG_IRQn, 8, 0);
  60.     HAL_NVIC_EnableIRQ(JPEG_IRQn);
  61.   /* USER CODE BEGIN JPEG_MspInit 1 */
  62.   /* USER CODE END JPEG_MspInit 1 */
  63.   }
  64. }
接下来进行JPEG模块初始化:
  1. JPEG_HandleTypeDef hjpeg;
  2. HAL_JPEG_Init(&hjpeg);
接下来启动JPEG解码器:
  1. /**
  2.   * [url=home.php?mod=space&uid=247401]@brief[/url]  Decode_DMA
  3.   * @param hjpeg: JPEG handle pointer
  4.   * @param  FrameSourceAddress    : video buffer address.
  5.   * @param  DestAddress : YCbCr destination Frame Buffer Address.
  6.   * @retval None
  7.   */
  8. uint32_t JPEG_Decode_DMA(JPEG_HandleTypeDef *hjpeg, uint32_t FrameSourceAddress ,uint32_t FrameSize, uint32_t DestAddress)
  9. {
  10.   JPEGSourceAddress =  FrameSourceAddress ;
  11.   FrameBufferAddress = DestAddress;
  12.   Input_frameIndex = 0;
  13.   Input_frameSize = FrameSize;
  14.   Jpeg_HWDecodingEnd = 0;
  15.   /* Start JPEG decoding with DMA method */
  16.   HAL_JPEG_Decode_DMA(hjpeg ,(uint8_t *)JPEGSourceAddress ,CHUNK_SIZE_IN ,(uint8_t *)FrameBufferAddress ,CHUNK_SIZE_OUT);
  17.   return 0;
  18. }
实际调用如下:
  1. JPEG_Decode_DMA(&hjpeg, (uint32_t)new_320_240, IMAGE_320_240_JPG_SIZE, (uint32_t) rawBuffer);
其中,JPEG图像是分辨率是320 * 240,存储于FLASH中。
  1. const uint8_t new_320_240[]={0xff,0xd8,0xff,0xe0,0x00,0x10,0x4a,0x46,0x49,0x46,0x00,0x01,0x01,0x01,0x00,0x60,0x00,0x60,0x00,0x00,0xff,0xfe,0x00,0x14,0x53,0x6f,0x66,0x74,0x77,0x61,0x72,0x65,0x3a,0x20,0x53,0x6e,0x69,0x70,0x61,0x73,0x74,0x65,0xff,0xdb,0x00,0x43,0x00,0x03,0x02,0x02,0x03,0x02,0x02,0x03,0x03,0x03,0x03,0x04,0x03,0x03,0x04,0x05,0x08,0x05,0x05,0x04,0x04,0x05,0x0a,0x07,0x07,0x06,0x08,0x0c,0x0a,0x0c,0x0c,0x0b,0x0a,0x0b,0x0b,0x0d,0x0e,0x12,0x10,0x0d,0x0e,0x11,0x0e,0x0b,0x0b,0x10,0x16,0x10,0x11,0x13,0x14,0x15,0x15,0x15,0x0c,0x0f,0x17,0x18,0x16,0x14,0x18,0x12,0x14,0x15,0x14,0xff,0xdb,0x00,0x43,0x01,0x03,0x04,0x04,0x05,0x04,0x05,0x09,0x05,0x05,0x09,0x14,0x0d,0x0b,0x0d,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14,0xff,0xc0,0x00,0x11,0x08,0x00,0xf0,0x01,0x40,0x03,0x01,0x22,0x00,0x02,0x11,0x01,0x03,0x11,0x01,0xff,0xc4,0x00,0x1f,0x00,0x00,0x01,0x05,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0xff,0xc4,0x00,0xb5,0x10,0x00,0x02,0x01,0x03,0x03,0x02,0x04,0x03,0x05,0x05,0x04,0x04,0x00,0x00,0x01,0x7d,0x01,0x02,0x03,0x00,0x04,0x11,0x05,0x12,0x21,0x31,0x41,0x06,0x13,0x51,0x61,0x07,0x22,0x71,0x14,0x32,0x81,0x91,0xa1,0x08,0x23,0x42,0xb1,0xc1,0x15,0x52,0xd1,0xf0,0x24,0x33,0x62,0x72,0x82,0x09,0x0a,0x16,0x17,0x18,0x19,0x1a,0x25,0x26,0x27,0x28,0x29,0x2a,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xff,0xc4,0x00,0x1f,0x01,0x00,0x03,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0xff,0xc4,0x00,0xb5,0x11,0x00,0x02,0x01,0x02,0x04,0x04,0x03,0x04,0x07,0x05,0x04,0x04,0x00,0x01,0x02,0x77,0x00,0x01,0x02,0x03,0x11,0x04,0x05,0x21,0x31,0x06,0x12,0x41,0x51,0x07,0x61,0x71,0x13,0x22,0x32,0x81,0x08,0x14,0x42,0x91,0xa1,0xb1,0xc1,0x09,0x23,0x33,0x52,0xf0,0x15,0x62,0x72,0xd1,0x0a,0x16,0x24,0x34,0xe1,0x25,0xf1,0x17,0x18,0x19,0x1a,0x26,0x27,0x28,0x29,0x2a,0x35,0x36,0x37,0x38,0x39,0x3a,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xff,0xda,0x00,0x0c,0x03,0x01,0x00,0x02,0x11,0x03,0x11,0x00,0x3f,0x00,0xfc,0xba,0xa9,0x53,0xef,0xd4,0x54,0xea,0xf7,0x4e,0x23,0xe8,0xcf,0x81,0xf6,0x3f,0x0f,0x67,0xb3,0xdd,0xe2,0x57,0x5f,0x3b,0xee,0x25,0x7d,0x25,0x69,0xf0,0x23,0xe1,0xbd,0xf6,0x83,0x3d,0xdd,0xbc,0x51,0x3d,0xae,0xcd,0x88,0xfb,0x36,0x3f,0xfe,0x3f,0x5f,0x9f,0x1e,0x1f,0xdd,0xf6,0xc8,0x51,0x1f,0xf8,0xeb,0xee,0x0f,0x1a,0xf8,0x8e,0xef,0xc2,0xdf,0x05,0x34,0x87,0xb7,0x79,0x7e,0xd6,0xa8,0x9f,0x3e,0xf7,0xf9,0x2b,0xdb,0xc1,0xce,0x12,0x83,0x52,0x8a,0xd0,0xfc,0x8b,0x89,0xb0,0x98,0xaa,0x38,0xaa,0x6f,0x0d,0x5e,0x49,0xd4,0x76,0xb5,0xf4,0x47,0xcb,0x3f,0x1a,0x7e,0x17,0xcb,0xe0,0x4f,0x10,0xcd,0x12,0x6f,0x9a,0xd5,0xdf,0xf7,0x53,0xed,0xfb,0xe9,0x5e,0x63,0xe5,0xfc,0xf5,0xf6,0xe2,0x3e,0x9f,0xfb,0x40,0xfc,0x3a,0xba,0x4b,0x88,0x92,0x0d,0x6f,0x4e,0x47,0x7d,0xef,0xff,0x00,0x2d,0x9e,0xbe,0x42,0xd7,0xfc,0x37,0x71,0xa1,0xeb,0x13,0x5a,0x5c,0x2e,0xc7,0x89,0xf6,0x57,0x06,0x22,0x92,0x83,0xe7,0x87,0xc2,0xcf,0xaf,0xc8,0xf3,0x49,0x62,0x69,0xcb,0x0f,0x89,0xd2,0xac,0x34,0x7e,0x7e,0x7f,0x33,0xd6,0xbf,0x65,0xbf,0x09,0x3e,0xb1,0xe3,0x44,0xbd,0x95,0x62,0xf2,0x2c,0x53,0xce,0x74,0x9f,0xee,0x3e,0xca,0xfa,0x57,0xc5,0x5e,0x32,0xb2,0xf8,0x9b,0xe1,0x5f,0x15,0xe9,0xed,0xb3,0xfd,0x06,0x1f,0x25,0x3f,0xb9,0x5e,0x6d,0xf0,0x4e,0x04,0xf0,0x1f,0xc1,0xfd,0x53,0x58,0x95,0x13,0xcf,0xbb,0x47,0x44,0xde,0x95,0xcb,0xfe,0xcf,0xda,0xe3,0xcf,0xe3,0xcb,0xab,0x4b,0x84,0x4f,0x22,0xf9,0x3e,0xe6,0xcf,0x93,0x7d,0x7a,0x74,0x1a,0xa5,0x4e,0x14,0xff,0x00,0x9a,0xf7,0xf9,0x9f,0x13,0x99,0xd3,0x79,0x86,0x2b,0x11,0x8e,0xbf,0xf0,0x6c,0xa3,0xf2,0xd5,0x9f,0x39,0xeb,0x96,0x8d,0x63,0x7f,0x34,0x4f,0xf7,0xd1,0xf6,0x55,0x1a,0xf4,0x4f,0x8d,0x1e,0x15,0xb8,0xf0,0xe7,0x8c,0xb5,0x1b,0x79,0x62,0x64,0x4d,0xef,0xb2,0xbc,0xe2,0xbc,0x39,0xc7,0x92,0x4e,0x27,0xea,0xd8,0x4a,0xd1,0xc4,0x50,0x85,0x58,0xbb,0xa6,0x82,0xaf,0x69,0xcf,0xe4,0x5c,0xa3,0xff,0x00,0xb7,0x54,0x6a,0x7f,0xbb,0x44,0x4e,0x99,0x2b,0xab,0x1f,0x6f,0xf8,0xb6,0xc6,0x6f,0x8a,0x7f,0xb3,0x6e,0x8f,0xa8,0x69,0x48,0x93,0x5f,0x69,0x69,0xe4,0xca,0x90,0xfd,0xfd,0x95,0xf3,0x57,0xc3,0x2b,0x2d,0x62,0xd3,0xc7,0x3a,0x77,0xd9,0x16,0x5f,0xb5,0x2d,0xc2,0x6c,0xd9,0x5a,0xff,0x00,0x04,0x3e,0x3a,0x5d,0xfc,0x32,0xbc,0x92,0x26,0x85,0x2e,0xb4,0xd9,0x93,0x64,0xb0,0xbd,0x7d,0x11,0xa0,0x7e,0xd1,0x1f,0x09,0xf4,0x3b,0x94,0xd7,0x6d,0x3c,0x35,0xbf,0x5b,0x7f,0xe0,0xd9,0xb3,0x67,0xfb,0x75,0xec,0x27,0x4f,0x10,0xe3,0x39,0x4a,0xcd,0x6e,0x7e,0x53,0x52,0x9e,0x3b,0x25,0x85,0x7c,0x25,0x3c,0x3b,0xab,0x4e,0x6d,0xb8,0xb5,0x6d,0x39,0xba,0x3b,0x9e,0xc9,0xf1,0x6f,0xe1,0x7d,0xac,0xf7,0x1e,0x14,0xf1,0x45,0xea,0xc5,0xf6,0xab,0x7d,0x89,0x71,0xf2,0x7c,0xf5,0xf0,0x67,0xed,0x11,0x77,0x71,0x3f,0xc4,0x5d,0x53,0xcd,0x89,0xed,0x76,0x3e,0xc4,0x47,0xfe,0xe5,0x7d,0xc5,0xa3,0x7c,0x54,0xbe,0xf1,0xe7,0xc2,0x2d,0x7b,0xc4,0x17,0x08,0xbf,0x65,0xb7,0x77,0x74,0x83,0xfb,0x95,0xf2,0x9f,0xed,0x2b,0xe0,0xa1,0xa9,0x49,0x63,0xe2,0xad,0x2a,0x27,0x9a,0xc6,0xee,0x2d,0x93,0x49,0xfe,0xde,0xc4,0xae,0xbc,0x74,0x54,0xe9,0x5e,0x3e,0xa7,0xcf,0xf0,0x85,0x5a,0x98,0x6c,0x6f,0xb1,0xc5,0xf4,0xbc,0x57,0x93,0xf8,0xad,0xf9,0x9f,0x3c,0xc1,0x77,0x34,0x0c,0x8e,0x8f,0xf3,0xad,0x6c,0x78,0x9b,0xc6,0x5a,0x97,0x8b,0x7e,0xcd,0xfd,0xa1,0x71,0xe7,0x7d,0x9e,0x2f,0x25,0x37,0xff,0x00,0x72,0xb0,0x3c,0xb7,0x47,0xdb,0xb6,0xb7,0x34,0x3f,0x07,0x6a,0x7e,0x20,0x49,0x9e,0xca,0xce,0x59,0xbe,0xce,0x9b,0xe5,0xd9,0xfc,0x09,0x5e,0x0a,0x6f,0x64,0x7e,0xd9,0x55,0x51,0x83,0x55,0x6a,0x5a,0xeb,0xaf,0x63,0x12,0x8a,0x7b,0xc7,0xb1,0xb6,0xd3,0x2a,0x4d,0xf9,0x82,0x9d,0x4d,0xa7,0x50,0x40,0x51,0x45,0x14,0x00,0x51,0x45,0x3e,0x82,0x02,0xad,0xe9,0xb7,0x0b,0x69,0x78,0x93,0x32,0x6f,0xda,0xfb,0xf6,0x55,0x4a,0x29,0xad,0xee,0x0d,0x5d,0x34,0xcf,0xb0,0x3c,0x57,0xfb,0x44,0x7c,0x2a,0xf1,0x98,0xd2,0xe7,0xd4,0xbc,0x11,0x75,0xa9,0x5e,0xdb,0xdb,0xa4,0x2f,0xbe,0xfb,0xc9,0x44,0xd9,0xfd,0xcd,0x95,0xd4,0x78,0xc7,0xc6,0x3e,0x0f,0xf1,0x9f,0xec,0xe3,0xa8,0xcd,0xa2,0x78,0x42,0xde,0xcd,0xec,0x66,0xf2,0x52,0x19,0x19,0xdd,0xed,0xf7,0xff,0x00,0x1a,0x3d,0x7c,0x3d,0x04,0x9e,0x5c,0xdb,0xeb,0xe8,0xdd,0x2b,0xf6,0xbc,0xbb,0xd0,0xfc,0x1e,0x34,0x2d,0x3f,0xc2,0xba,0x0d,0xb4,0x1e,0x4a,0x24,0xc9,0xf6,0x7f,0x92,0xe3,0x67,0xf1,0xba,0x7f,0x1d,0x7a,0xd4,0xf1,0x5c,0xdc,0xde,0xd5,0xa5,0xa7,0x63,0xf3,0x7c,0xc3,0x87,0x1e,0x1f,0xd8,0x3c,0xbe,0x32,0x97,0x2c,0x93,0xb3,0x9b,0x49,0x2b,0xeb,0xa7,0x99,0xab,0xf0,0x22,0xce,0xef,0xc4,0x3f,0x06,0xfe,0x24,0x78,0x66,0x38,0xa5,0x9a,0x64,0x86,0x0d,0x42,0xdf,0x67,0xf7,0xd1,0xfe,0x7a,0xf3,0xaf,0x02,0x7c,0x4c,0xf1,0x1f,0xc1,0xaf,0x18,0x7f,0xa4,0x44,0xfe,0x4b,0xfc,0x97,0x1a,0x5d,0xe2,0x3a,0x43,0x70,0x8f,0xf7,0xd1,0xd2,0xae,0xf8,0x23,0xf6,0xab,0xf1,0x7f,0xc3,0xed,0x26,0xe7,0x4c,0xd1,0x27,0xb5,0xb2,0xb7,0x9a,0x57,0x9b,0xe4,0xb5,0x4d,0xe9,0xbf,0xfd,0xba,0xf3,0xef,0x88,0x5f,0x12,0xb5,0xbf,0x89,0xba,0xc2,0x6a,0x5a,0xed,0xf3,0xde,0xdc,0xa2,0x6c,0x47,0xdb,0xfc,0x15,0x8c,0xea,0xc1,0x42,0x3c,0x8d,0xf3,0x23,0xd5,0xc3,0xe5,0xb8,0x89,0xe2,0x71,0x11,0xc4,0xd2,0x8f,0xb1,0xa8,0xef,0xbd,0xdd,0xec,0x97,0x6e,0xb6,0xf9,0x74,0x67,0xad,0xfc,0x65,0xf8,0x21,0x6f,0x7b,0xa5,0xbf,0x8f,0x7c,0x01,0x6b,0x2d,0xcf,0x82,0xee,0x21,0xf3,0xa5,0xf9,0xd3,0x7e,0x9c,0xff,0x00,0xc7,0x0b,0xd7,0xcf,0x1f,0xc5,0x5b,0x56,0xbe,0x2a,0xd5,0xad,0x34,0x99,0x34,0xc8,0x75,0x0b,0x84,0xb1,0x97,0xfd,0x6d,0xb2,0x4a,0xfb,0x1f,0xfd,0xf4,0xac,0x59,0x2b,0x9a,0xa4,0xa1,0x37,0xcd,0x15,0x6b,0xef,0xea,0x7b,0xf8,0x0c,0x3e,0x23,0x0b,0x4b,0xd8,0xd7,0x9f,0x3a,0x4f,0xdd,0x7a,0xde,0xdd,0x2f,0x7d,0xdf,0x9f,0xea,0x7a,0x47,0xec,0xfb,0x24,0x50,0x7c,0x55,0xd0,0x66,0xb8,0xd6,0x2d,0xf4,0x44,0x82,0xe1,0x26,0xfb,0x65,0xe7,0xfa,0x94,0xd9,0xf3,0xd7,0xa3,0x7e,0xd3,0x1e,0x1c,0xf0,0x86,0x9d,0xe2,0x3b,0xcf,0x12,0xf8,0x6b,0xc6,0x36,0x9a,0xd5,0xdd,0xed,0xdf,0x9d,0xf6,0x2b,0x68,0xbf,0xd4,0xa3,0xff,0x00,0xb7,0x5f,0x3a,0x24,0x8e,0x95,0x23,0xce,0xf2,0x7d,0xf7,0xad,0x23,0x51,0x2a,0x7e,0xcd,0xc7,0xcc,0xc2,0xb6,0x5e,0xea,0xe3,0xa3,0x8c,0x55,0x1a,0xb2,0xb3,0x8d,0x95,0x9a,0xf3,0x7b,0x9f,0x48,0xf8,0xcb,0xf6,0x81,0xd2,0xbe,0x24,0xfc,0x07,0x93,0x45,0xd7,0x62,0x6f,0xf8,0x4b,0xa0,0xb8,0xb6,0x78,0xaf,0x23,0x4f,0xf8,0xf8,0x44,0x4d,0x9f,0x3b,0xff,0x00,0x7f,0x65,0x65,0xfc,0x25,0xfd,0xa0,0xb4,0xad,0x27,0xc2,0x8f,0xe0,0xcf,0x1d,0xe8,0xa7,0xc4,0x9e,0x18,0xf3,0x7c,0xe8,0x91,0x1f,0x64,0xd6,0x93,0x7f,0x1b,0xa3,0xff,0x00,0xb7,0x5f,0x3f,0xd1,0x54,0xf1,0x13,0x72,0x52,0x7b,0xaf,0xc7,0xd4,0xe6,0x59,0x16,0x0e,0x34,0x25,0x87,0x49,0xf2,0xb9,0x73,0x2d,0x6c,0xe2,0xff,0x00,0xba,0xfa,0x1f,0x45,0x7c,0x70,0xf8,0xe9,0xe1,0x9d,0x73,0xc1,0x3a,0x77,0x82,0xfc,0x11,0xa1,0x3e,0x89,0xe1,0xeb,0x7b,0x87,0xbc,0x94,0xdd,0x4b,0xbe,0x6b,0x89,0xbf,0xbe,0xf5,0xf3,0xad,0x14,0x56,0x53,0x9c,0xaa,0x3b,0xb3,0xd0,0xc0,0xe0,0x69,0x65,0xd4,0xbd,0x8d,0x2b,0xda,0xed,0xb6,0xdd,0xdb,0x6f,0xab,0x66,0x25,0x14,0x51,0x5c,0x07,0xd1,0x1d,0x2f,0x81,0x2d,0x7e,0xd7,0xe2,0x1b,0x18,0x97,0xf8,0xe5,0x4a,0xfd,0x0e,0xf1,0x6f,0x86,0x34,0x7d,0x4b,0xc0,0x1a,0x76,0x9f,0xaf,0xca,0x96,0x50,0xdb,0xfc,0x90,0xc6,0xef,0xb3,0x7a,0x6c,0xfb,0xff,0x00,0xec,0x7f,0x1d,0x7c,0x47,0xf0,0x17,0xc2,0xbf,0xdb,0xfe,0x33,0xd3,0xb7,0x6c,0xd8,0xb2,0xa6,0xfd,0xf5,0xf5,0x6f,0xed,0x2d,0xf0,0xcb,0x55,0xd4,0xa1,0xfb,0x45,0xbd,0xda,0x41,0x05,0xba,0x7d,0xc4,0x7a,0xf6,0xb0,0x29,0xc6,0x8c,0xa5,0x6b,0x9f,0x91,0xf1,0x4d,0x48,0x62,0x33,
  2. 0x3c,0x3e,0x1d,0xd4,0xe4,0xb5,0xdd,0xfb,0x3e,0x83,0xfc,0x01,0x27,0xc3,0xdf,0x87,0xba,0x97,0xda,0x22,0xd4,0xd1,0x1d,0x25,0xd9,0xb1,0x1f,0x7f,0x9c,0x9f,0xdf,0xae,0x5f,0xf6,0xa4,0xf8,0x6b,0xa3,0xf8,0x89,0x13,0xc6,0x1e,0x1a,0x96,0x29,0x91,0xd3,0x7c,0xc8,0x8f,0xbd,0xeb,0xe4,0x8b,0xb9,0x2e,0x2c,0x75,0xb7,0xb7,0x96,0x5f,0xba,0xfb,0x1a,0xbe,0xe6,0xfd,0x9d,0xa4,0xf0,0xd5,0x87,0x82,0xa6,0xb7,0xd6,0xb5,0x88,0xbc,0x9b,0xb4,0xd9,0xb2,0x67,0xf9,0x36,0x56,0xb4,0x6a,0x2c,0x4c,0x5d,0x27,0x14,0x91,0xc3,0x98,0xe5,0xf5,0x72,0x2a,0x94,0xf3,0x2a,0x75,0x65,0x52,0x4f,0x46,0xbb,0xa6,0x72,0x1e,0x0a,0xf8,0xcb,0xe0,0x7b,0x3f,0x87,0x50,0x68,0x5a,0xec,0x5f,0x3c,0x29,0xb3,0x63,0xa6,0xff,0x00,0xfc,0x72,0x97,0xc2,0x3f,0x15,0xfe,0x18,0x68,0x3a,0xcc,0x32,0xe9,0x5a,0x56,0xc9,0xf7,0xec,0xdf,0xe5,0x7f,0x7e,0xbc,0x5f,0xf6,0x88,0xf0,0xe7,0x85,0x34,0x3d,0x6e,0x49,0xbc,0x29,0xa8,0x7d,0xaa,0x09,0x5f,0xfe,0xf8,0xae,0x5f,0xe1,0x0f,0x88,0x34,0x2d,0x2f,0x5e,0x8e,0x6d,0x79,0x1d,0xe1,0xdf,0xfc,0x1f,0xc1,0x58,0xbc,0x4c,0xe1,0x51,0x53,0x76,0xba,0xd2,0xe7,0xa7,0x1c,0x8f,0x0d,0x89,0xc1,0xcf,0x17,0x4d,0xcf,0xdf,0xd5,0xc6,0xed,0x3f,0x4b,0x1f,0x44,0xfe,0xd8,0xf7,0x76,0x9a,0x8e,0x97,0xa7,0x5f,0x45,0x69,0x9f,0xb4,0x27,0xc9,0x36,0xcf,0xf6,0x2b,0xe2,0xc9,0xd3,0xe7,0xaf,0xaf,0xfe,0x2d,0xfe,0xd0,0xbe,0x0c,0xf1,0x57,0x83,0xff,0x00,0xb1,0xec,0xac,0x93,0xf7,0x49,0xb1,0x26,0xf2,0xab,0xe4,0xbb,0xf7,0x59,0xae,0x5d,0x97,0xee,0x6f,0xac,0x31,0xce,0x32,0xa9,0xcd,0x17,0x73,0xde,0xe1,0x4a,0x75,0xf0,0xf8,0x25,0x46,0xb5,0x37,0x1b,0x37,0xbf,0x62,0xa4,0x71,0xd4,0xb4,0x51,0x5e,0x69,0xf6,0x8d,0x9a,0x9e,0x1f,0xd0,0xae,0x75,0xfd,0x4a,0x1b,0x2b,0x4f,0xf5,0xd2,0xfc,0x8b,0x5f,0x40,0xf8,0x3b,0xf6,0x47,0xf1,0x5d,0xde,0xa4,0x91,0x6a,0x08,0x9a,0x5c,0x3b,0xd3,0x7c,0xce,0xf5,0xf3,0xbe,0x95,0xaa,0xdc,0x69,0x57,0x89,0x71,0x6f,0x2b,0xc2,0xe9,0xf7,0x1d,0x2b,0xd1,0xae,0x3f,0x68,0xcf,0x19,0xdd,0x69,0x5f,0xd9,0xf2,0xeb,0x77,0x1e,0x46,0xcd,0x9b,0x37,0xff,0x00,0x05,0x77,0x52,0x74,0xa2,0xef,0x51,0x5c,0xf9,0xbc,0xd6,0x8e,0x65,0x5a,0xd1,0xc0,0xca,0x29,0x3d,0xdb,0xdc,0xfa,0x23,0xf6,0x81,0xf1,0xc6,0x85,0xf0,0xcb,0xe1,0xbc,0x3f,0x0f,0xfc,0x35,0x70,0x8f,0x3e,0xfd,0xf7,0x73,0xc0,0xff,0x00,0x7e,0xbc,0x07,0xe1,0xd7,0xc6,0x89,0x7c,0x36,0x64,0xd3,0x35,0x28,0x21,0xd4,0xb4,0x7b,0x8f,0x91,0xe1,0x99,0x37,0xec,0xaf,0x32,0xbe,0xd5,0x6e,0x35,0x29,0x9d,0xe5,0x67,0x7a,0xa3,0xfc,0x75,0x55,0x31,0x13,0x94,0xd4,0xa3,0xa5,0xba,0x1c,0xf8,0x0e,0x1f,0xa1,0x86,0xc2,0x3c,0x3d,0x7f,0x7e,0x52,0x77,0x6f,0xab,0x7d,0xcf,0xa4,0x24,0xf0,0x27,0xc3,0x0f,0x12,0xdd,0x7d,0xba,0xcb,0xc4,0xc9,0xa4,0x42,0xe9,0xbd,0xed,0xa6,0x4f,0x9d,0x3f,0xd8,0xa9,0x3c,0x55,0xf1,0x57,0xc3,0x5f,0x0f,0x7c,0x25,0x75,0xe1,0xaf,0x03,0xfe,0xf3,0xed,0x49,0xb2,0xef,0x50,0xfe,0x37,0xaf,0x9b,0xfe,0xd1,0x27,0xf7,0xa8,0x79,0x19,0xe9,0xfd,0x61,0xc5,0x3e,0x48,0xa4,0xdf,0x52,0x96,0x49,0xcd,0x28,0xfb,0x7a,0xd2,0x9c,0x56,0xd1,0x76,0xb7,0xcf,0xbf,0xcc,0x26,0x7d,0xef,0xba,0x99,0x45,0x15,0xc8,0x7d,0x20,0xea,0x28,0xa2,0x80,0x0a,0x28,0xa7,0xd0,0x26,0x14,0x51,0x45,0x04,0x85,0x09,0x45,0x49,0x1d,0x50,0x0b,0x45,0x14,0x50,0x48,0x51,0x45,0x39,0x20,0x96,0x7f,0xba,0x94,0x06,0x8b,0x56,0x36,0x9f,0x56,0xbf,0xb3,0x6e,0x11,0x37,0x79,0x4d,0x55,0x6a,0xac,0x4a,0x92,0x96,0xc1,0x45,0x15,0xa3,0xa1,0x68,0x57,0xbe,0x21,0xd4,0x12,0xd2,0xca,0x09,0x6e,0x66,0x7f,0xb8,0x90,0xa6,0xf7,0x7a,0xa4,0x9b,0x76,0x42,0x9c,0x94,0x17,0x34,0x9d,0x92,0x33,0xa8,0xaf,0x4e,0xd5,0x3f,0x67,0x3f,0x1d,0xe8,0x9a,0x05,0xce,0xb1,0x7b,0xe1,0xdb,0xe8,0xac,0x2d,0xd3,0xce,0x96,0x67,0x87,0x66,0xc4,0xfe,0xfd,0x41,0xf0,0x2b,0xc0,0x5a,0x7f,0xc4,0x5f,0x89,0x9a,0x47,0x86,0xf5,0x5b,0xd7,0xd2,0xed,0xaf,0x65,0xf2,0x5a,0x58,0xd3,0x7b,0xab,0xff,0x00,0x05,0x5f,0xb3,0x9f,0x32,0x83,0x5a,0xb3,0x81,0xe6,0x38,0x5f,0x61,0x3c,0x44,0x26,0xa5,0x18,0x5d,0xbb,0x6b,0xb7,0xa1,0xe7,0x7e,0x5b,0x7f,0x77,0xf4,0xa3,0xcb,0x78,0xfe,0xfd,0x7d,0x83,0x75,0xe1,0x8f,0xd9,0xe7,0xc2,0x7a,0xbb,0xd8,0x5e,0x5e,0xf8,0x9b,0x57,0xba,0x8a,0x5f,0x25,0xd1,0x2d,0xd2,0x24,0xdf,0xfc,0x75,0xe7,0x7f,0xb5,0x7f,0xc3,0x7f,0x0b,0xf8,0x1f,0x59,0xf0,0xdd,0xef,0x85,0x6d,0xee,0x2c,0xb4,0xbd,0x67,0x48,0x4b,0xff,0x00,0xb3,0x4c,0xfb,0xdd,0x37,0xbb,0xff,0x00,0x1d,0x6f,0x3c,0x34,0xa1,0x17,0x2b,0xa7,0x63,0xc7,0xc2,0x67,0xd4,0x71,0x58,0x88,0x61,0xdd,0x39,0xc7,0x9d,0x36,0x9c,0xa3,0x64,0xec,0x7c,0xc9,0x45,0x14,0x57,0x92,0x7d,0xd1,0xd2,0xf8,0x57,0xc6,0x9a,0x87,0x84,0xa7,0xf3,0x74,0xfb,0x8f,0x25,0xeb,0xab,0xd5,0x7e,0x3e,0xf8,0xaf,0x58,0x85,0xe1,0xb8,0xd5,0xa5,0x74,0x7f,0xbf,0xfe,0xdd,0x79,0x95,0x15,0xa2,0xa9,0x38,0xab,0x29,0x68,0x79,0xf5,0xb0,0x38,0x6a,0xd3,0x55,0x2a,0x53,0x4e,0x5d,0xda,0x27,0xba,0xbe,0x6b,0xb9,0xbc,0xe7,0x6f,0x9e,0xad,0xc7,0xaf,0x5e,0x5b,0xae,0xd4,0x9d,0xf6,0x7f,0xbd,0x59,0xb4,0x56,0x7a,0xf4,0x3a,0x9c,0x22,0xd5,0x9a,0xd0,0xb5,0x3d,0xf4,0xd7,0x7f,0x79,0xf7,0xd4,0x1e,0x66,0xca,0x62,0x53,0xe8,0x2d,0x25,0x1d,0x12,0x17,0xcf,0x7f,0xef,0x52,0x25,0x14,0x25,0x00,0x4b,0x45,0x14,0x55,0x25,0x72,0x02,0x8a,0x29,0xf5,0xa0,0x0c,0xa2,0x8a,0x7d,0x00,0x14,0x51,0x5a,0x9a,0x1f,0x87,0x2f,0x7c,0x41,0x78,0x96,0xf6,0x96,0xcf,0x34,0xcf,0xf2,0x22,0x22,0x50,0xae,0xdd,0x91,0x9d,0x49,0x46,0x11,0xe6,0x9b,0xb2,0x46,0x5d,0x3a,0xbb,0x7d,0x7f,0xe0,0xef,0x8a,0xbc,0x39,0xa5,0x7f,0x69,0x6a,0x1a,0x25,0xd5,0xb5,0x97,0xf7,0xdd,0x2b,0x88,0xaa,0x94,0x65,0x17,0x69,0x2b,0x1c,0xf4,0x6b,0xd2,0xc4,0x47,0x9a,0x94,0x94,0x97,0x90,0x51,0x45,0x15,0x26,0xe1,0x4f,0xa2,0x8a,0x08,0x0a,0x28,0xa5,0xd8,0x28,0x02,0x4a,0x28,0xa2,0xa8,0x4c,0xb5,0xa4,0xe9,0x93,0x6b,0x37,0xf0,0xda,0xdb,0xa3,0xcd,0x34,0xaf,0xb1,0x11,0x3f,0x8d,0xeb,0xde,0x34,0xaf,0xd8,0xab,0xe2,0x3d,0xf4,0x5e,0x6d,0xce,0x8e,0x9a,0x7c,0x7f,0xf4,0xfb,0x32,0x25,0x78,0x77,0x87,0x2f,0x9f,0x4d,0xd5,0x6d,0x6e,0x93,0xef,0xc4,0xdb,0xd6,0xbe,0x90,0xf8,0xfb,0xf1,0x0e,0xf6,0xc7,0xe2,0x26,0x89,0xab,0xe9,0xfa,0xd5,0xc4,0xf6,0x3a,0x8d,0x95,0x9e,0xa6,0xa8,0x97,0x1f,0x71,0xdd,0x3e,0x7f,0x92,0xbb,0x68,0x42,0x93,0x8b,0x95,0x45,0xb3,0x5f,0x89,0xf2,0xf9,0xb6,0x23,0x1f,0x1c,0x45,0x3a,0x18,0x36,0x97,0x32,0x93,0xbb,0x4d,0xea,0xad,0xa6,0x8d,0x6f,0xa9,0x35,0x97,0xec,0x41,0xab,0x26,0xa0,0x96,0x9a,0xaf,0x89,0x74,0x1d,0x2e,0x77,0x7d,0x9b,0x1e,0xe3,0x7b,0xef,0xad,0x7f,0xd9,0xfb,0xe1,0x7e,0x83,0xa1,0xeb,0xdf,0x10,0xb4,0xdf,0x15,0x78,0x7e,0x2d,0x7b,0x51,0xd0,0x6d,0xde,0x78,0xa0,0x91,0xdd,0x37,0xec,0x7f,0x9f,0xff,0x00,0x1c,0xae,0x7b,0xf6,0x92,0xd5,0x6e,0xb4,0x3f,0x89,0xba,0x57,0x8b,0x2d,0x26,0x94,0x41,0xac,0xda,0xdb,0x6b,0x31,0x37,0xfb,0x6f,0xf7,0xf6,0x7f,0xc0,0xd2,0xba,0x9f,0x01,0xfc,0x64,0xf0,0xbd,0xdf,0xed,0x2a,0x9a,0xc0,0xd4,0x3f,0xe2,0x43,0xaf,0x59,0xfd,0x9b,0x52,0xb9,0xbd,0x4d,0x9b,0x1e,0x68,0x7e,0x7d,0xff,0x00,0xf0,0x3a,0xee,0x4a,0x84,0x2a,0xd9,0x2b,0x34,0xfe,0xfb,0xa3,0xe3,0x6b,0x54,0xcd,0xf1,0x58,0x07,0x52,0x53,0x73,0x53,0x87,0x37,0xba,0xad,0x69,0x45,0xa6,0xd5,0xd6,0xba,0xea,0xbc,0xd9,0x93,0xe2,0x3f,0xda,0x3b,0xc2,0x56,0xb6,0x7a,0x85,0x96,0x95,0xf0,0xab,0xc3,0xd0,0x79,0xb1,0x3c,0x28,0xf7,0x3b,0xdf,0x6f,0xfb,0x7f,0xef,0xd7,0xcb,0x17,0x4f,0xe6,0x4e,0xf5,0xf6,0x16,0xb5,0xa8,0xfe,0xcf,0x3e,0x1f,0xd5,0x5f,0x4c,0x7d,0x2b,0x59,0xf1,0x09,0xdf,0xfb,0xdd,0x4e,0x1b,0xbd,0x89,0xff,0x00,0x00,0x4a,0xf2,0x4f,0xda,0x13,0xe0,0x9d,0xa7,0xc3,0xc7,0xd2,0xf5,0xad,0x02,0xf5,0xf5,0x5f,0x09,0x6b,0x71,0x3c,0xda,0x7d,0xcb,0xaf,0xcf,0xfe,0xda,0x3f,0xfb,0x69,0x5c,0xf8,0x88,0x4e,0x4b,0x9a,0xe9,0xdb,0xb1,0xed,0xe4,0x58,0xac,0x1e,0x1e,0xa2,0xa0,0xa9,0x4e,0x9b,0xa9,0xb3,0x9d,0xfd,0xeb,0x2e,0x97,0x6f,0x5f,0xba,0xe7,0x89,0x57,0x45,0xe0,0x1f,0x1c,0x6a,0xbf,0x0f,0x7c,0x47,0x6d,0xad,0xe8,0xb7,0xcd,0x67,0xa8,0xc1,0xf7,0x66,0x4a,0xe7,0x69,0xf6,0xbf,0xf1,0xf4,0x95,0xc0,0x9b,0x4e,0xe8,0xfb,0x9a,0xb0,0x85,0x48,0x4a,0x15,0x15,0xd3,0xdd,0x77,0x3f,0x45,0xb4,0x0f,0x8d,0xcc,0xff,0x00,0x06,0xbc,0x1d,0xab,0xf8,0xca,0xee,0xe3,0x57,0x83,0x59,0xd4,0xae,0xed,0xb5,0x0d,0xcb,0xf3,0xbd,0xbe,0xcd,0x95,0xf1,0xdf,0xc6,0xcf,0x87,0xd7,0x7f,0x09,0x7e,0x21,0xdc,0xc1,0x6b,0x2b,0x1b,0x2d,0xdf,0x69,0xb0,0xbc,0x4f,0x93,0xce,0x85,0xfe,0x74,0x74,0xaf,0xaa,0x6d,0xfe,0x17,0xe9,0xbe,0x31,0xfd,0x9b,0xbe,0x1b,0x5b,0x6b,0x1e,0x22,0xd3,0x7c,0x2f,0x0d,0xba,0x5c,0xdc,0xff,0x00,0xa6,0xbf,0xcf,0x36,0xf7,0xfb,0xff,0x00,0xf7,0xc5,0x55,0xf8,0xc5,0xe0,0x6f,0x0d,0x7c,0x49,0xf8,0x35,0x0e,0x9f,0xe1,0xdf,0x11,0x5b,0xf8,0xbb,0xc4,0x3e,0x11,0x89,0xde,0x27,0x87,0xfd,0x73,0xd8,0xff,0x00,0x73,0xfe,0x01,0xf7,0xeb,0xdb,0xad,0x09,0x55,0xa5,0xe6,0x96,0x87,0xe3,0x39,0x46,0x3b,0x0f,0x96,0xe3,0x65,0xc8,0x9f,0x24,0xe7,0x28,0xc9,0x59,0xf2,0xa5,0xcc,0xd4,0x5d,0xf6,0x5d,0xbd,0x19,0xf0,0xfd,0xad,0xd5,0xc5,0xf6,0xa6,0x8d,0x34,0xae,0xf2,0x33,0xfd,0xf7,0xaf,0x7f,0xfd,0xb0,0x9d,0xd2,0xef,0xc0,0x56,0x8c,0xfb,0xfc,0xaf,0x0c,0xd8,0x7f,0x06,0xcf,0xe0,0xaf,0x00,0xb1,0xb5,0x6b,0x7d,0x65,0x22,0x6f,0xbf,0xbe,0xbd,0xf3,0xf6,0xd0,0xf3,0xa3,0xf1,0xbe,0x81,0x6f,0x2b,0xa7,0xee,0xb4,0x1b,0x0d,0x88,0x9f,0xc1,0xfb,0x9a,0xf3,0xa1,0xfc,0x09,0xfc,0xbf,0x33,0xf4,0x0c,0x65,0x9e,0x6b,0x84,0x4b,0x6b,0x4d,0xfe,0x08,0xf9,0x52,0x8a,0x7c,0x91,0xba,0x7d,0xea,0x65,0x79,0x27,0xdd,0x8f,0xa2,0x8a,0x7c,0x09,0xbd,0xe8,0x25,0x8c,0xa1,0x11,0xbf,0xdf,0xaf,0xa1,0xbe,0x15,0xfe,0xcb,0xfa,0x9f,0x8f,0xf4,0xa4,0xd4,0xbc,0xd8,0xad,0x6c,0x7f,0xe7,0xb3,0xfc,0x89,0x5e,0x99,0x6b,0xfb,0x1f,0xe8,0x96,0x3b,0xff,0x00,0xb4,0x35,0xbf,0x2d,0xd3,0xef,0xa3,0xfc,0x9f,0xc1,0x5d,0x90,0xc2,0x55,0x9a,0xe6,0x4b,0x43,0xe4,0x71,0x5c,0x53,0x96,0xe1,0x2a,0x3a,0x52,0x9d,0xe4,0xb7,0x4b,0x53,0xe3,0x0d,0x8f,0xb3,0xee,0xbd,0x18,0x7f,0xee,0x57,0xdb,0xba,0xff,0x00,0xec,0x95,0xe1,0xa7,0xf0,0x4d,0xf6,0xb1,0xa6,0x6a,0x7f,0x3c,0x50,0xef,0x4d,0xff,0x00,0xdf,0xfe,0xe5,0x7c,0xf3,0xf0,0xeb,0xe1,0xce,0x9b,0xe2,0x7f,0x15,0x3e,0x9b,0xa9,0xea,0x09,0xa7,0x22,0x3e,0xc7,0x77,0x7a,0x27,0x85,0xa9,0x4e,0x4a,0x2f,0xa9,0xa6,0x0f,0x88,0xf0,0x58,0xda,0x55,0x2a,0xd3,0xbd,0xa1,0xbe,0x8e,0xff,0x00,0x71,0xe5,0x9e,0x43,0x7f,0x72,0x8f,0xb9,0x5f,0x7b,0x78,0x57,0xf6,0x3b,0xf0,0x3e,0xab,0x67,0xbd,0xfc,0x40,0x93,0xec,0x7d,0x8f,0xb1,0xeb,0xe6,0xef,0x8f,0xbf,0x04,0xe6,0xf8,0x65,0xac,0x6e,0xb7,0x57,0x9b,0x4a,0xb8,0xf9,0xed,0xe6,0xd9,0xfc,0x15,0x55,0x30,0x75,0x29,0x43,0x9e,0x5b,0x18,0x65,0xfc,0x53,0x80,0xcc,0xb1,0x1f,0x56,0xa6,0xda,0x97,0x9a,0xb5,0xcf,0x1b,0xa2,0x8a,0x2b,0x92,0x27,0xd6,0x8e,0x4a,0xf5,0xbf,0x85,0xff,0x00,0xb3,0x9f,0x8a,0x3e,0x28,0x59,0x9b,0xbd,0x2a,0xd7,0xce,0xb6,0xff,0x00,0x9e,0xcf,0x5e,0x4b,0x5e,0xd7,0xfb,0x3d,0xfc,0x65,0xd6,0x3c,0x07,0xe2,0x3d,0x3a,0xde,0xde,0xf1,0xe3,0xd3,0x9e,0x5f,0xde,0xc3,0xfc,0x1f,0xf7,0xc5,0x74,0xd1,0x50,0x73,0x4a,0xa6,0xc7,0x89,0x9c,0x4f,0x19,0x4f,0x09,0x29,0xe0,0x6d,0xce,0xb5,0xd4,0xf4,0x98,0x3f,0x61,0x2f,0x10,0x40,0x91,0xff,0x00,0x68,0x5d,0xda,0x5a,0xa7,0xfb,0xff,0x00,0x73,0xfd,0xfa,0xc1,0xf1,0x8f,0xec,0x5d,0xe2,0x6d,0x03,0x47,0x7d,0x43,0x4f,0x96,0xdf,0x58,0x81,0x13,0x7b,0xfd,0x99,0xf7,0xbe,0xca,0xed,0xbf,0x6b,0xbd,0x67,0xc4,0x16,0x9a,0xb6,0x97,0x7f,0x6b,0x7b,0x7a,0x96,0x37,0xd6,0x9b,0xf6,0x19,0x6b,0x97,0xfd,0x97,0xfc,0x5d,0xe2,0xdb,0x8f,0x1c,0xd9,0x5b,0xc5,0x2d,0xdd,0xcd,0xac,0xbf,0x24,0xa9,0xe6,0xbe,0xcd,0x95,0xe8,0xca,0x18,0x7f,0x6b,0xec,0x79,0x5e,0xbd,0x4f,0xce,0xf0,0xf8,0xec,0xe9,0xe0,0x56,0x66,0xf1,0x11,0x6b,0x77,0x16,0xbb,0x6e,0xaf,0x7d,0xcf,0x9b,0xe3,0xd1,0xa5,0x83,0x52,0xfb,0x2c,0xa9,0xb1,0xf7,0xec,0xd9,0x5f,0x65,0xe8,0xff,0x00,0xd9,0x5f,0xb2,0xff,0x00,0xc2,0xcb,0x2d,0x4e,0x5b,0x78,0xaf,0xbc,0x5f,0xab,0x45,0xe7,0x22,0x3f,0xfc,0xb2,0x4a,0xf3,0x3f,0x8e,0xde,0x1c,0xd2,0xb4,0x0f,0x8f,0x0f,0x15,0xa3,0xa7,0x92,0xd7,0x08,0xef,0xb1,0xfe,0x44,0x7d,0xf5,0xef,0x5f,0x15,0x3e,0x0d,0x5e,0xfc,0x57,0xf1,0x0e,0x91,0x71,0x71,0xa8,0x79,0x7e,0x1e,0x8a,0xd1,0x26,0x7b,0xaf,0xe0,0x44,0xff,0x00,0x62,0x9e,0x1e,0x8c,0xa0,0xe7,0xc9,0xf1,0x2d,0x11,0xa6,0x75,0x9a,0xd2,0xc6,0xc7,0x09,0xf5,0x97,0xcb,0x46,0x69,0xca,0x4b,0x5d,0x6c,0xb4,0x8e,0x9e,0xbf,0x33,0xe5,0x6f,0x1a,0x7e,0xd2,0x1e,0x30,0xf1,0x6e,0x95,0x75,0xa5,0x6a,0x1a,0x9f,0x9f,0x63,0x2f,0xf0,0x3a,0x25,0x78,0xeb,0xfd,0xfa,0xfa,0xf3,0x52,0xfd,0x9e,0xbe,0x1c,0x78,0x8d,0x3f,0xb3,0x3c,0x35,0xe3,0x05,0x7d,0x69,0x5d,0xd3,0x63,0xa7,0xdf,0x7f,0xee,0x25,0x7c,0xcd,0xe3,0x8f,0x05,0xea,0x1e,0x0b,0xd7,0x6e,0x74,0xcd,0x4e,0x07,0x86,0xe6,0xdd,0xf6,0x3a,0x57,0x1e,0x22,0x9d,0x55,0x69,0x54,0x77,0x5d,0xf7,0x3e,0xb7,0x25,0xc6,0xe5,0xd5,0x13,0xa1,0x83,0x87,0xb3,0x7b,0xb4,0xd7,0x2b,0x7e,0x76,0xea,0x73,0x94,0x51,0x4f,0xae,0x33,0xea,0x18,0x51,0x45,0x14,0x12,0x09,0x52,0xd2,0x24,0x74,0xb4,0x00,0x51,0x45,0x15,0x44,0x88,0x9f,0x27,0xdc,0xab,0x71,0xdf,0x4b,0x24,0x89,0xb9,0xbe,0xe5,0x55,0xab,0xfa,0x3d,0xac,0x57,0x97,0xd6,0xf0,0xcd,0x22,0x42,0x92,0xba,0x23,0xbb,0xfd,0xc4,0xa6,0xb7,0xb1,0x32,0xb7,0x2b,0x6c,0xf7,0xdf,0x89,0x48,0xde,0x2d,0xfd,0x9b,0x3c,0x09,0xad,0xed,0xf9,0xf4,0x6b,0x89,0xb4,0x57,0x7f,0xf6,0x3e,0xfa,0x57,0x80,0xda,0x5a,0x5c,0x5d,0xdc,0xa4,0x36,0xea,0xef,0x33,0xbe,0xc5,0x44,0xfb,0xed,0x5f,0x65,0xe9,0x1e,0x1c,0xf8,0x67,0xe1,0x9f,0x85,0x9a,0x8f,0x85,0x75,0xdf,0x88,0xd6,0xf7,0x90,0x5f,0xdc,0x43,0x7b,0x0b,0xe9,0x70,0xf9,0xde,0x4b,0xa2,0x7f,0x73,0xfd,0xba,0xf9,0xc7,0xc7,0x97,0x5e,0x1a,0xf0,0xaf,0x8d,0x61,0xbd,0xf0,0x0e,0xa7,0x7b,0x35,0xb5,0xb6,0xc7,0x4b,0x9b,0x94,0xd8,0xe9,0x32,0x57,0xa1,0x88,0xa6,0xec,0xa6,0xda,0xd9,0x5f,0x5b,0xb3,0xe2,0xb2,0x3c,0x67,0x37,0xb5,0xc3,0x52,0x84,0xac,0xa5,0x27,0x16,0xe2,0xd4,0x6c,0xdd,0xd6,0xad,0x77,0x6d,0x1c,0x7c,0xfa,0x36,0xa5,0x6f,0x7b,0xe4,0xcd,0x14,0xb0,0xcc,0x9f,0x7d,0x1f,0xef,0xa5,0x7d,0x39,0xe2,0x6b,0x26,0x4f,0xd8,0xa7,0x4b,0x6d,0x58,0xba,0x49,0x16,0xbe,0xff,0x00,0xd9,0xfb,0xdf,0xf8,0x36,0x7c,0xf5,0x5b,0x4e,0xfd,0xab,0xbc,0x2f,0xe2,0x31,0x6d,0x77,0xe3,0x8f,0x87,0xba,0x4f,0x88,0x75,0x88,0xbe,0xfe,0xa0,0x8f,0xe4,0xc9,0x37,0xc9,0xb3,0xe7,0xfe,0xfd,0x79,0xcf,0xc7,0x2f,0xda,0x06,0xf7,0xe2,0xec,0x96,0x56,0xa2,0xce,0xdf,0x47,0xd1,0x34,0xf4,0xd9,0x6b,0xa6,0xd9,0x7c,0x90,0xc3,0x4f,0xf7,0x54,0xe1,0x27,0x19,0x5e,0xea,0xc6,0x55,0x56,0x63,0x99,0xe2,0x68,0x42,0xad,0x0f,0x66,0xa9,0xc9,0x49,0xca,0xe9,0xad,0x13,0xd1,0x5b,0x5d,0x7d,0x11,0xe3,0x3f,0xc7,0x5a,0xde,0x1c,0xb1,0x5d,0x4f,0x5b,0xb1,0xb4,0xf3,0x52,0x1f,0x36,0x54,0x4d,0xf3,0x7c,0x88,0x9b,0xde,0xb3,0x68,0x8e,0x4d,0x8f,0xbe,0xb8,0x56,0x8c,0xfb,0x89,0x2e,0x68,0xb4,0x8f,0xbb,0xbf,0x68,0xbf,0x86,0xb6,0x0b,0xf0,0x9b,0xc3,0xea,0xde,0x34,0xd0,0xa0,0xb9,0xf0,0xde,0x98,0x90,0xad,0x94,0x17,0x08,0xef,0x70,0xff,0x00,0x7f,0xe4,0xd9,0xfd,0xfa,0xf1,0xff,0x00,0xd9,0x33,0xe2,0x1f,0x84,0xfc,0x03,0xe2,0x9b,0xbd,0x63,0xc5,0x7a,0xc5,0xfd,0x94,0xd6,0xe9,0xb2,0xdd,0x2d,0xad,0xfc,0xe4,0x99,0x1f,0xef,0xa3,0xff,0x00,0xb1,0x5f,0x3d,0xc9,0xaa,0xdc,0x4e,0x9b,0x59,0x9a,0xaa,0xf9,0xaf,0xe8,0xd5,0xd9,0x2c,0x4d,0xea,0x2a,0x91,0x5a,0x9f,0x23,0x86,0xc8,0x1c,0x30,0x13,0xc0,0xd7,0xaa,0xe4,0xa4,0xde,0xa9,0x24,0xd5,0xdd,0xdf,0x7d,0xdd,0xcf,0x58,0xf8,0xe9,0xac,0xf8,0x2a,0xfb,0xc7,0x22,0xf7,0xc0,0xb6,0xf7,0x76,0xda,0x73,0xa6,0xf9,0x7e,0xd3,0xff,0x00,0x3d,0xbf,0xd8,0xff,0x00,0x62,0xb2,0x7e,0x31,0x7c,0x54,0xb8,0xf8,0xb1,0xe2,0x0b,0x7d,0x56,0xe2,0xdd,0x2c,0x9e,0x2b,0x0b,0x7b,0x3f,0x22,0x16,0xde,0x9f,0xba,0x4d,0x95,0xe7,0xa2,0x4d,0xf4,0xea,0xe6,0x9d,0x49,0x4d,0xbe,0x97,0xdc,0xf7,0x70,0xf8,0x0a,0x54,0x23,0x4a,0xf7,0x94,0xa9,0xab,0x26,0xdd,0xdd,0x9e,0xf7,0x3d,0x13,0xf6,0x8c,0xf0,0x05,0xaf,0x82,0xfc,0x61,0x3d,0xa5,0x94,0x5e,0x4c,0x1b,0xfe,0xe5,0x78,0xf5,0x7d,0x19,0xfb,0x61,0xcf,0xbf,0xe2,0x4c,0xd1,0x6e,0x7f,0xdc,0xc4,0x89,0xf3,0xd7,0xce,0x75,0x8e,0x22,0x2a,0x35,0x64,0x91,0xa6,0x43,0x56,0xa5,0x7c,0xba,0x95,0x4a,0xae,0xed,0xa4,0x15,0x24,0x12,0xf9,0x72,0xee,0xa8,0xe8,0xae,0x63,0xdf,0x7a,0xe8,0xcf,0x71,0xf0,0x97,0xed,0x21,0xaa,0xf8,0x67,0xc1,0x3f,0xf0,0x8f,0xc5,0xf7,0x13,0xfd,0x4b,0xbf,0xf0,0x57,0x09,0xa8,0xfc,0x4d,0xd7,0x75,0x9b,0x9d,0xf3,0x6a,0x77,0x13,0x6e,0xfe,0xfc,0xaf,0x5c,0x4d,0x4f,0x6d,0xfe,0xba,0xb6,0x95,0x69,0xca,0x2a,0x2d,0xe8,0x8f,0x1e,0x9e,0x57,0x83,0xa3,0x29,0xd4,0x85,0x35,0x79,0x6a,0xcf,0xb8,0xff,0x00,0x67,0x4b,0xeb,0xd9,0xfe,0x14,0xeb,0x1a,0x83,0xcb,0x71,0x32,0x26,0xf4,0x78,0xe3,0x97,0x66,0xcf,0x93,0xef,0xbf,0xf7,0xeb,0xe4,0x1d,0x72,0xfe,0xe2,0xd7,0x5b,0x99,0xd5,0xb6,0x3e,0xf7,0xfb,0x95,0xf5,0xd7,0xc0,0x5b,0x18,0x8f,0xc0,0x4d,0x6e,0xe1,0xde,0x68,0x76,0x7c,0xfb,0xd1,0xf6,0x25,0x7c,0x75,0xaa,0xfe,0xff,0x00,0x5b,0x7f,0xf6,0xde,0xbb,0xf1,0x2d,0xfb,0x2a,0x77,0x3e,0x3b,0x20,0x51,0x96,0x3f,0x1a,0xed,0xa7,0x32,0xfc,0x8f,0xaf,0xfe,0x00,0xdd,0xdd,0xda,0xfc,0x16,0xd6,0xf5,0x3f,0x36,0xe1,0x1e,0x1d,0xef,0x0b,0xef,0xf9,0x37,0xff,0x00,0x97,0xa7,0xf8,0x2f,0x58,0x4f,0xda,0x07,0xc1,0xf7,0xbe,0x1a,0xd5,0x9f,0xfe,0x27,0x11,0x7f,0xaa,0x77,0xfe,0xe7,0xfb,0x15,0xd7,0xfc,0x08,0xf0,0x7e,0x9f,0xac,0x7c,0x05,0x7b,0x4b,0xb9,0x5e,0xcb,0x7a,0x3e,0xf9,0xb7,0xff,0x00,0x7e,0xa8,0xf8,0x3b,0xc0,0x9f,0x0d,0xfe,0x1a,0xf8,0x86,0xd7,0x55,0xb8,0xf1,0x42,0x49,0x74,0x89,0xbf,0xc9,0x49,0x6b,0xd4,0x8c,0x27,0xc9,0x04,0xde,0x96,0xd6,0xe7,0xc2,0x57,0xc4,0x50,0x96,0x23,0x14,0xe1,0x17,0xed,0x54,0xef,0x16,0xa2,0xdd,0xad,0xe9,0xdc,0xf8,0x9f,0xc7,0x1e,0x0e,0xbd,0xf0,0x76,0xbd,0x73,0xa7,0xdd,0xc5,0xb2,0x68,0x9e,0xb9,0xba,0xfb,0xa3,0xf6,0x96,0xf0,0x26,0x85,0xf1,0x4f,0xc3,0xdf,0xf0,0x95,0x78,0x4b,0xfd,0x37,0xc9,0x4d,0xf7,0x33,0x6f,0x4f,0xfb,0xe2,0xbe,0x20,0xbe,0xb5,0x7b,0x49,0x9d,0x59,0x76,0x57,0x89,0x5e,0x8f,0xb0,0x9d,0x96,0xdd,0x0f,0xd6,0xf2,0x1c,0xd9,0x66,0xb8,0x55,0x39,0x2b,0x4d,0x69,0x24,0xf7,0x4c,0xad,0x5a,0x7a,0x1d,0xd3,0xd8,0xea,0x50,0xcc,0xbf,0xc0,0xf5,0x99,0x56,0x6d,0x7f,0xe3,0xe6,0x3a,0xe7,0x3e,0x8a,0xa2,0x52,0x8b,0x4c,0xfd,0x30,0xb5,0x8f,0xc1,0xbe,0x25,0xf8,0x11,0xa1,0x78,0x83,0xc4,0xeb,0xf6,0xd4,0xb4,0x44,0xfb,0xff,0x00,0x3b,0xef,0xff,0x00,0xd9,0xe8,0xf8,0x59,0xf1,0x7f,0xe1,0xad,0xdc,0x37,0xda,0x2f,0x85,0x6d,0x22,0xf0,0xf6,0xab,0x32,0x3a,0x5b,0xcf,0x3e,0xcd,0x8f,0x5c,0x17,0xc0,0x5f,0x09,0x6b,0x1e,0x2e,0xfd,0x9f,0xf5,0x8d,0x1e,0xfa,0x29,0x7c,0x97,0x4f,0xf4,0x44,0x7f,0xfd,0x0e,0xbe,0x5d,0xf8,0x93,0xf0,0xe7,0xc5,0x1f,0x08,0x75,0x98,0x5f,0x52,0x89,0xec,0xe4,0x95,0xbf,0x74,0xe8,0xd5,0xf4,0x55,0x2b,0x4e,0x9c,0x61,0x51,0x47,0x4b,0x6b,0xdc,0xfc,0x0f,0x07,0x93,0xe1,0xb1,0xf5,0xf1,0x38,0x09,0xd7,0x6a,0x4a,0x4f,0x95,0x5f,0x4e,0xfb,0x75,0xf3,0x3a,0x1f,0x8e,0xfe,0x07,0xf1,0x2f,0x82,0xfc,0x70,0xf7,0x1a,0xc6,0xe9,0xbc,0xd7,0xf3,0x92,0xe7,0xef,0xa3,0xd7,0xd1,0x9a,0xaf,0xc4,0x9d,0x47,0xc7,0x9f,0xb2,0xdf,0xfc,0x49,0xee,0x3f,0xd3,0xac,0xa2,0x4b,0x6b,0x8b,0x54,0x85,0x37,0xa2,0x27,0xf1,0xd7,0x9e,0x7c,0x36,0xf8,0xbf,0xa2,0x7c,0x5f,0xf0,0x92,0x78,0x3f,0xc7,0xaf,0xe5,0xc9,0x6e,0x9f,0xe8,0x3a,0x87,0xdf,0x7f,0xf8,0x1d,0x72,0xf6,0x9e,0x3f,0xb4,0xfd,0x9d,0xfe,0x21,0x5d,0x69,0xfa,0x3e,0xa0,0x9e,0x21,0xd1,0x25,0xf9,0x2e,0x13,0xf8,0x26,0x4a,0xe6,0x84,0xe3,0x09,0x39,0xc6,0x5e,0xec,0xbe,0xf4,0xcf,0x76,0xbd,0x0a,0xf8,0xb8,0xd3,0xc2,0x56,0xa5,0xfb,0xfa,0x0e,0xeb,0x4f,0x76,0x49,0x79,0xf4,0xbf,0x63,0xc7,0x3c,0x3b,0xac,0x6a,0xba,0x4f,0x88,0xed,0xee,0x6d,0x1e,0x54,0xba,0x59,0x77,0xa3,0xa5,0x7b,0x57,0xed,0x7f,0x6c,0x97,0xcd,0xe1,0x4d,0x62,0x68,0x96,0x1d,0x46,0xeb,0x4b,0x4f,0xb5,0xc7,0xb3,0x63,0xef,0x4a,0xe9,0x34,0xff,0x00,0x1e,0x7c,0x12,0x93,0x5c,0xff,0x00,0x84,0x8e,0x4d,0x36,0x6b,0x5b,0xaf,0x9d,0xd3,0x4f,0x4f,0xb8,0x8f,0x5e,0x31,0xfb,0x40,0xfc,0x61,0x7f,0x8b,0x9e,0x30,0x7d,0x41,0x62,0xf2,0x2d,0x11,0x12,0x18,0xa1,0xfe,0xe2,0x25,0x61,0x28,0xc6,0x8d,0x19,0x41,0xcb,0x99,0xbb,0x58,0xf7,0x70,0xf3,0xaf,0x98,0x66,0x94,0x6b,0x2a,0x0e,0x9a,0xa6,0x9d,0xdb,0x56,0xbd,0xfa,0x2e,0xe7,0x92,0x53,0xe8,0xa2,0xbc,0xd3,0xef,0x42,0x8a,0x2a,0x48,0xfe,0xe5,0x00,0x2d,0x14,0x51,0x41,0x21,0x45,0x14,0x55,0x00,0x53,0x91,0xfc,0xba,0x6d,0x3e,0x80,0x26,0xfb,0x54,0xdb,0x3e,0xf5,0x32,0x49,0x1d,0xfe,0xf5,0x32,0x8a,0x0c,0xd2,0x4b,0x60,0xa3,0xef,0xd1,0x53,0x79,0x0f,0x27,0xdc,0x4a,0x06,0x32,0x8a,0x1d,0x1e,0x3a,0x2a,0xc0,0x28,0xa2,0x38,0xf7,0xd7,0xd0,0xdf,0x06,0xbf,0x66,0x58,0xbc,0x69,0xe1,0x57,0xf1,0x47,0x89,0x35,0xfb,0x4f,0x0a,0x78,0x6f,0xcd,0x78,0x52,0xf6,0xf3,0xfe,0x5a,0xbf,0xf7,0x11,0x2b,0x48,0x53,0x95,0x47,0x68,0x9e,0x7e,0x3b,0x1f,0x43,0x2f,0xa5,0xed,0x6b,0xbb,0x2b,0xdb,0xbb,0x6f,0xc9,0x1f,0x3c,0xd3,0xab,0xda,0x3e,0x33,0x7e,0xcf,0x37,0x1f,0x0e,0x6c,0xed,0x75,0x8d,0x2b,0x52,0xb4,0xf1,0x27,0x86,0xee,0x9f,0x64,0x3a,0x95,0x87,0xdc,0xdf,0xfd,0xc7,0x4f,0xe0,0x7a,0xb9,0xf0,0xf3,0xe1,0x07,0x87,0x6d,0x3c,0x1a,0x9e,0x33,0xf1,0xd6,0xb1,0x3e,0x91,0xa2,0x4b,0x71,0xe4,0xd8,0xda,0xdb,0x45,0xbe,0xe6,0xfb,0xfb,0xfb,0x3f,0xb8,0x9f,0xed,0xd6,0x9e,0xc2,0x7c,0xfc,0x9f,0xf0,0xc7,0x2f,0xf6,0xc6,0x11,0xe1,0xd6,0x26,0x12,0xe6,0x4d,0xd9,0x24,0xae,0xdb,0xed,0x6d,0xef,0xfa,0x6b,0xd0,0xe7,0x3f,0x69,0xd9,0xdd,0xfc,0x79,0x32,0x4d,0xfe,0xbd,0x11,0x37,0xd7,0x88,0xd7,0xaf,0x7e,0xd1,0xee,0x9f,0xf0,0xb1,0x75,0x44,0xd8,0x88,0xe8,0xfb,0x36,0x27,0xdc,0xaf,0x21,0xae,0x3a,0xff,0x00,0xc5,0x97,0xa9,0xe8,0xe4,0x91,0x51,0xcb,0xe8,0xdb,0xb2,0x0a,0x28,0xa2,0xb0,0x3d,0xa1,0xf5,0x25,0x8f,0xcf,0x72,0x95,0x1d,0x09,0x26,0xc7,0xa0,0x96,0xae,0x9a,0x3e,0xea,0xf8,0x5f,0x7a,0x9a,0x37,0xec,0xd5,0xaa,0x6f,0x89,0x1d,0x25,0x85,0xf6,0x4f,0xf7,0xfe,0x7f,0xee,0x57,0xc7,0x76,0x3a,0x74,0xba,0xce,0xbc,0x96,0xf0,0xae,0xf9,0xdd,0xeb,0xb4,0xd2,0xbe,0x3a,0x6a,0x1a,0x77,0xc3,0xd9,0x3c,0x2f,0x17,0xc9,0x03,0xff,0x00,0x1d,0x79,0xee,0x9b,0xe2,0x09,0xb4,0xad,0x59,0x2f,0x61,0xff,0x00,0x58,0x8f,0xbe,0xbb,0xaa,0xd6,0x85,0x45,0x08,0xf6,0x3e,0x37,0x2b,0xcb,0x71,0x18,0x39,0xe2,0xa7,0x2d,0xe7,0x26,0xd1,0xf7,0xb6,0xa3,0xf0,0xcb,0x5f,0xbb,0xf8,0x2f,0xa4,0x69,0x96,0x5a,0x85,0xbc,0x0f,0xf6,0x4f,0x9d,0x11,0xfe,0xfb,0xef,0xf9,0x2b,0xe2,0x7f,0x1a,0xe9,0xba,0x87,0x86,0x3c,0x43,0x3e,0x9f,0x76,0xdf,0xbf,0x89,0xfe,0x7a,0xea,0xee,0xbf,0x69,0x6f,0x19,0xdd,0xd8,0x3d,0xa3,0xea,0xae,0x90,0xba,0x6c,0x7f,0x92,0xbc,0xd3,0x58,0xd7,0x6e,0xb5,0xbb,0xa7,0xb9,0xbb,0x95,0xe6,0x99,0xfe,0xfb,0xbd,0x69,0x88,0xaf,0x4a,0xad,0xb9,0x0e,0x7c,0x8b,0x29,0xc6,0xe0,0x27,0x51,0xe2,0x5c,0x5a,0x93,0x6f,0x45,0xad,0xd9,0xf6,0x3f,0xec,0xdb,0xa9,0x78,0x5f,0x4e,0xf0,0x7b,0xff,0x00,0x6e,0xeb,0x7b,0xe0,0xbb,0x4f,0xdf,0x59,0x3c,0xc8,0x95,0xe3,0x7f,0xb4,0x65,0x87,0x81,0x60,0xd6,0x3c,0xdf,0x08,0xdc,0x6f,0xdf,0xf3,0xba,0x7f,0x72,0xbc,0x51,0x2f,0xe5,0x44,0xda,0x8c,0xf4,0xc9,0x2e,0x9d,0xfe,0xfb,0x6f,0xa5,0x3c,0x4b,0x9d,0x35,0x4f,0x97,0x63,0xaf,0x0d,0x90,0xfd,0x57,0x1d,0x3c,0x6a,0xaa,0xfd,0xef,0xb3,0xd0,0x65,0x3e,0x09,0xfc,0x87,0x46,0xa8,0x69,0xf5,0xc8,0x7d,0x63,0x57,0x56,0x67,0xba,0x78,0x57,0xf6,0xb3,0xf1,0x97,0x85,0x7c,0x2f,0x6b,0xa2,0x69,0xf7,0x71,0x43,0x67,0x17,0xdc,0xf9,0x2b,0xcf,0x7c,0x7b,0xf1,0x53,0xc4,0x1f,0x11,0xaf,0x7e,0xd1,0xad,0x6a,0x32,0xde,0x49,0xfe,0xdd,0x71,0xb4,0x56,0xb2,0xab,0x52,0x4b,0x95,0xcb,0x43,0xc7,0xa3,0x95,0xe0,0xb0,0xf5,0x5d,0x7a,0x54,0x92,0x93,0xeb,0x6d,0x49,0xa0,0x9d,0xed,0xfe,0xeb,0x52,0xbd,0xdc,0x93,0x7d,0xe6,0xa8,0xa8,0xac,0x4f,0x4e,0xca,0xf7,0xb1,0x27,0x9e,0xff,0x00,0xde,0xa6,0x17,0xdd,0x49,0x45,0x31,0x3b,0x2d,0x87,0xd1,0x45,0x14,0x08,0x2a,0x48,0xfe,0xe5,0x46,0x95,0x2d,0x00,0x14,0x51,0x45,0x04,0x85,0x14,0x51,0x54,0x03,0xe8,0xa2,0x8a,0x09,0x2e,0xc1,0xa4,0xdc,0x5d,0x26,0xe5,0x56,0xd9,0x56,0xf4,0x3f,0x0b,0xdf,0x78,0x8f,0x58,0x87,0x4c,0xb2,0x82,0x5b,0x9b,0xd9,0x5f,0x64,0x50,0xc2,0xbb,0xdd,0xde,0xbe,0xa0,0xfd,0x91,0x3e,0x38,0xf8,0x6b,0xc3,0x02,0x1f,0x0b,0xeb,0x5a,0x36,0x8b,0x0c,0x77,0x5b,0xff,0x00,0xe2,0x7b,0x73,0x6f,0xbe,0x65,0x7f,0xe0,0xdf,0xfe,0xc5,0x61,0x6b,0x3f,0x09,0xfc,0x4d,0xe0,0xdf,0x8f,0xf6,0x46,0x27,0x68,0x66,0xbd,0xbf,0x4b,0x9b,0x1b,0xfb,0x35,0xd8,0x8e,0x8e,0xff,0x00,0x23,0xa5,0x77,0x2c,0x3a,0x94,0x63,0x34,0xee,0x9b,0xd4,0xf9,0x0a,0x99,0xdd,0x4a,0x38,0x9a,0xd8,0x6a,0xd4,0xf9,0x1c,0x62,0xdc,0x5b,0x7a,0x4b,0xfa,0xfb,0xce,0x29,0xbf,0x67,0x6f,0x12,0xf8,0x4f,0x52,0xd0,0xa6,0xf1,0x56,0x93,0x77,0xa1,0xe8,0xf7,0xf7,0x49,0x6d,0xf6,0x99,0x93,0xfe,0xfb,0xaf,0x79,0xf1,0x9f,0xc3,0xaf,0x81,0x7f,0x05,0xf5,0x5b,0x9d,0x23,0x5b,0x4f,0x12,0x6b,0xda,0x95,0xbf,0xf7,0x1d,0x21,0x47,0xae,0x2b,0xf6,0xc7,0xf8,0x8c,0xda,0xa7,0xc6,0x01,0xa6,0x5b,0xdd,0x3c,0xd6,0xba,0x32,0x25,0xb2,0x7c,0xff,0x00,0xc6,0x89,0xf3,0xff,0x00,0xe3,0xf5,0xeb,0xbf,0x12,0x7c,0x0f,0xe0,0x5f,0x8a,0x3e,0x1a,0xf0,0xbf,0xc4,0x0f,0x15,0xf8,0xaa,0x2d,0x12,0xd6,0xe3,0x4b,0x85,0x1e,0xd6,0xd7,0x63,0xdc,0xdc,0x4c,0x9f,0x23,0xd7,0x6c,0x29,0xc2,0x32,0x9c,0x21,0xab,0x5d,0xcf,0x90,0xc5,0xe3,0xb1,0x78,0x88,0x61,0x2b,0xe3,0x65,0x28,0x42,0xa2,0x77,0x50,0xbd,0xef,0xbc,0x7b,0xbd,0x4f,0x8e,0x3e,0x2f,0x6b,0x3e,0x19,0xd7,0xfc,0x50,0xf7,0x1e,0x15,0xd1,0x5b,0xc3,0xda,0x5f,0x94,0x88,0x96,0xcf,0x71,0xe7,0x7c,0xff,0x00,0xdf,0xdf,0x5c,0x15,0x7d,0x4b,0xf1,0x0b,0xf6,0x77,0xf0,0xa6,0xbd,0xe0,0x9b,0xef,0x15,0x7c,0x32,0xd7,0x66,0xd6,0xed,0xb4,0xcf,0xf9,0x08,0x69,0xf7,0x29,0xb2,0xe6,0x14,0xfe,0xff,0x00,0xfb,0x95,0xf2,0xec,0xf0,0x79,0x0e,0xea,0xf5,0xe6,0xd5,0x84,0xa3,0x2b,0xcb,0xa9,0xfa,0x1e,0x53,0x8c,0xc3,0xe2,0xb0,0xea,0x14,0x1b,0xf7,0x34,0x6a,0x57,0xe6,0x5e,0xb7,0xd4,0x5b,0x7f,0x91,0x92,0xbe,0xbf,0xf1,0x06,0x81,0xaa,0xfc,0x50,0xfd,0x99,0xfc,0x0c,0xfe,0x15,0x59,0xaf,0x4e,0x88,0x93,0x5b,0x5e,0xd9,0xdb,0x7c,0xfe,0x4b,0xef,0xf9,0x1f,0x67,0xfb,0x69,0x5f,0x1e,0x57,0xd7,0x1f,0xb2,0x4f,0x88,0xa6,0xf8,0x7d,0xf0,0xe3,0xe2,0x07,0x8c,0x62,0x67,0x92,0xf7,0x4e,0x8a,0x1b,0x6b,0x78,0x77,0x7c,0x8e,0xf3,0x3f,0xf1,0xd7,0x46,0x11,0xae,0x67,0x17,0xb3,0x47,0x91,0xc4,0xb1,0x9d,0x3a,0x14,0xf1,0x54,0xb5,0x9c,0x26,0xac,0x9e,0xcd,0xbf,0x76,0xdf,0x89,0xa5,0xe1,0x9f,0x0b,0x6a,0xbe,0x14,0xfd,0x95,0xbc,0x65,0x1f,0x8a,0x12,0x5b,0x68,0x35,0x2b,0xab,0x6f,0xec,0xbb,0x69,0xbe,0xfb,0xdc,0x23,0xfc,0xee,0x9f,0xf0,0x0a,0xf3,0x1f,0xda,0x26,0xe8,0xa7,0x87,0xbe,0x1a,0xdb,0xda,0x7f,0xc8,0x2d,0x7c,0x3d,0x0b,0xc3,0xb3,0xee,0x6f,0xde,0xfe,0x77,0xfe,0x3f,0x5e,0xa9,0xf0,0xb3,0xf6,0x95,0xd5,0xfe,0x2d,0x78,0xce,0x1f,0x05,0x78,0xd4,0x26,0xb3,0xa0,0xeb,0x92,0xfd,0x8f,0x64,0xf1,0x7c,0xf6,0xee,0xff,0x00,0x22,0x3a,0x7f,0x73,0x65,0x73,0x7f,0x14,0x3c,0x18,0xfe,0x2a,0xf8,0x7a,0xfe,0x1f,0xb2,0x91,0xef,0x35,0xef,0x01,0xdd,0x5d,0x59,0xcb,0x0a,0x27,0xce,0xf6,0x0e,0xff,0x00,0x7d,0x3f,0xdc,0x7a,0xec,0x92,0x8d,0x4a,0x6f,0x91,0xf4,0xb7,0xdd,0xa9,0xf3,0x38,0x39,0xd6,0xc2,0xe6,0x2b,0xeb,0xd1,0x51,0x93,0x93,0x93,0xb7,0xc2,0x94,0xa2,0xe2,0x9f,0x95,0x9a,0xd7,0xd6,0xe7,0xcb,0x5e,0x34,0xf1,0x34,0xde,0x2a,0xd6,0xee,0xf5,0x06,0xfb,0xf7,0x0f,0xbe,0xb9,0xda,0x28,0xaf,0x9b,0x6d,0xb7,0x76,0x7e,0xcb,0x4e,0x9c,0x69,0x41,0x42,0x0b,0x44,0x14,0x51,0x45,0x22,0x87,0xd1,0x45,0x14,0x00,0x79,0x8f,0xeb,0x42,0x51,0xfc,0x75,0x2d,0x00,0x27,0x97,0x47,0x97,0x47,0x99,0x4b,0x40,0x05,0x14,0x9f,0x3d,0x3b,0xe7,0xa0,0x81,0x29,0xf4,0x51,0x5b,0x00,0x51,0x45,0x74,0x5e,0x0e,0xf0,0x75,0xf7,0x8c,0x75,0x88,0x74,0xfb,0x28,0x9e,0x6b,0xa9,0x5f,0x62,0x22,0x51,0x66,0xdd,0x91,0xcd,0x52,0xa4,0x29,0x41,0xce,0x6e,0xc9,0x1c,0xfd,0x15,0xf6,0x66,0x89,0xfb,0x19,0x68,0xfa,0x6d,0xa2,0x2f,0x8a,0x7c,0x57,0x6f,0xa5,0x5e,0xba,0x23,0xb4,0x1f,0xdc,0xae,0x1f,0xe2,0x7f,0xec,0x8f,0xa9,0xf8,0x73,0x4b,0x9b,0x57,0xf0,0xfd,0xe4,0x5e,0x21,0xd3,0xa1,0xfb,0xef,0x6d,0xf7,0xd3,0xfd,0xba,0xec,0x78,0x3a,0xd1,0x8f,0x35,0x8f,0x96,0xa3,0xc5,0x39,0x65,0x6a,0xde,0xc5,0x54,0xb5,0xf6,0x6d,0x34,0x9f,0xce,0xd6,0x3c,0x03,0x43,0xd0,0x2e,0xf5,0xfb,0xc4,0xb4,0xb4,0x81,0xe6,0x99,0xfe,0xe2,0x22,0x57,0xa4,0xdd,0x7e,0xcc,0x3e,0x3d,0xb5,0xb6,0xf3,0x5f,0x42,0xbb,0xd9,0xb3,0x7f,0xdc,0xaf,0x50,0xfd,0x97,0xb4,0xa4,0xf0,0xc6,0x83,0xe2,0xff,0x00,0x14,0x2d,0xa4,0x53,0xea,0x1a,0x65,0xbb,0xa4,0x5e,0x72,0x7f,0xa9,0x7a,0xe2,0x93,0xf6,0x97,0xf1,0xd4,0x1e,0x29,0x7b,0xd7,0xd6,0x2e,0x1f,0x7c,0xdb,0xfc,0x9f,0xe0,0x7a,0xb8,0x52,0xa5,0x08,0x46,0x55,0x6f,0x77,0xd8,0xe6,0xad,0x99,0x66,0x18,0x9c,0x55,0x4a,0x39,0x7a,0x8d,0xa9,0xda,0xfc,0xd7,0xd5,0xb5,0x7d,0x2d,0xf9,0x9e,0x2b,0xa9,0x69,0x57,0x1a,0x6d,0xcb,0xc3,0x70,0xac,0x93,0x27,0xdf,0x47,0xaa,0x75,0xf4,0xf7,0xed,0x57,0xe1,0xdd,0x3f,0x50,0xd0,0xbc,0x2f,0xe3,0x5b,0x7b,0x6f,0xb3,0x5d,0x6b,0x76,0xee,0xf7,0x10,0xff,0x00,0xb7,0x5f,0x30,0xd7,0x35,0x6a,0x5e,0xca,0x6e,0x27,0xbd,0x95,0xe3,0xd6,0x63,0x85,0x8d,0x7b,0x59,0xea,0x9a,0xec,0xd3,0xb3,0x24,0xf2,0xe9,0x68,0xa2,0xb1,0x3d,0x46,0x14,0x51,0x45,0x02,0x0a,0x28,0xa7,0xa5,0x50,0x05,0x14,0x51,0x41,0x04,0xd6,0x97,0x6f,0x69,0x32,0x32,0xfc,0x8e,0x95,0xf7,0x47,0xec,0x83,0xf1,0xdf,0xfe,0x12,0x68,0xec,0xbc,0x2f,0xe2,0x08,0x5f,0x50,0xd5,0x74,0xc4,0x9a,0xe7,0x44,0xb8,0x7f,0x9d,0xd1,0xd1,0x1d,0xfc,0x9a,0xf8,0x46,0xbe,0x97,0xfd,0x90,0x3e,0x1c,0xf8,0xaa,0xef,0xc5,0xfa,0x3f,0x8b,0x74,0x8d,0x3d,0xe6,0xd3,0x34,0xeb,0xb4,0x13,0x5c,0xbb,0xa2,0x27,0xfb,0x69,0xf3,0xff,0x00,0xb1,0x5d,0xb8,0x47,0x35,0x51,0x72,0xfc,0xcf,0x91,0xe2,0x8c,0x3e,0x1a,0xb6,0x5d,0x39,0xd7,0xb2,0x6b,0x67,0xb6,0xbd,0x3e,0xf3,0xc5,0x3e,0x23,0xea,0xb7,0x7a,0xcf,0x8b,0x75,0x0b,0xdb,0xbf,0x9e,0xe6,0x7b,0x87,0x77,0xff,0x00,0x7e,0xb2,0xcd,0xf6,0xa1,0x35,0xb2,0x43,0xb9,0xdd,0x13,0xee,0x26,0xff,0x00,0xb9,0x5f,0x4b,0xfe,0xd1,0x7f,0xb3,0xde,0x95,0xe1,0x6b,0xcf,0x12,0xeb,0xe9,0xe3,0x0d,0x17,0x1f,0x68,0x79,0xed,0x34,0xb8,0xee,0x37,0xdc,0xcc,0x8e,0xff,0x00,0x73,0xe4,0xfb,0x95,0xcb,0xfc,0x22,0xf8,0xbb,0xe0,0x5d,0x3f,0xc2,0xdf,0xf0,0x8c,0x78,0xe3,0xc1,0xf1,0x6b,0x16,0x49,0x33,0xbc,0x5a,0x8d,0x9b,0xf9,0x37,0x91,0x7f,0xf1,0x74,0xe5,0x4e,0x4a,0xab,0x8c,0xdd,0x87,0x43,0x33,0x85,0x5c,0xbe,0x9d,0x7c,0x1d,0x27,0x51,0x46,0xc9,0xa4,0xac,0xd6,0x9d,0x2f,0x6b,0xdb,0xcb,0x7e,0x86,0xef,0xec,0x48,0xf7,0xd3,0x7c,0x48,0x9b,0x4f,0xb8,0xf3,0x7f,0xb2,0xf5,0x1d,0x3a,0xe6,0xda,0xef,0xfd,0xcd,0x8f,0x5f,0x3b,0x78,0xaa,0x04,0xb4,0xd7,0xae,0xa1,0x85,0xf7,0xc6,0x92,0xba,0x23,0xd7,0xd4,0x1e,0x23,0xfd,0xa3,0x3c,0x05,0xe0,0x7f,0x09,0x6a,0x7a,0x57,0xc3,0x2f,0x0d,0x4d,0xa5,0xdd,0x6a,0x91,0x79,0x37,0x1a,0x9d,0xeb,0xef,0x99,0x13,0xfb,0x89,0x5f,0x28,0xdd,0xce,0xf7,0x77,0x2e,0xcf,0x4e,0xb7,0x2c,0x61,0x1a,0x69,0xde,0xc4,0x65,0x11,0xaf,0x5b,0x19,0x88,0xc7,0x54,0xa4,0xe9,0xc6,0x6a,0x29,0x45,0xda,0xfa,0x75,0x76,0xbf,0xa7,0xc8,0xab,0x5e,0xd5,0xfb,0x3c,0xfc,0x63,0xb4,0xf8,0x71,0xa9,0xea,0x96,0x1a,0xed,0x97,0xf6,0x9f,0x86,0x35,0x8b,0x7f,0xb3,0x6a,0x16,0x7f,0xec,0x7f,0x7d,0x3f,0xdb,0x4a,0xf1,0x7a,0x55,0xeb,0x5c,0xd0,0x9b,0x84,0xb9,0x96,0xe7,0xd0,0xe3,0x30,0xd4,0xb1,0xd4,0x65,0x42,0xb2,0xd1,0x9f,0x64,0xf8,0x77,0x54,0xf8,0x31,0xf0,0x97,0x50,0x1e,0x32,0xd1,0xf5,0xdb,0xef,0x11,0x6b,0x16,0x88,0xf3,0x58,0x69,0x13,0x5a,0x79,0x3b,0x26,0xfe,0x0d,0xef,0xfd,0xca,0xf9,0xc7,0xfe,0x16,0xa6,0xbd,0xa7,0xf8,0xe6,0xef,0xc4,0xb6,0x3a,0x8c,0xb6,0x1a,0xac,0xb7,0x0f,0x33,0xcd,0x0b,0x7f,0x1b,0xbf,0xcf,0x5c,0x5f,0x9f,0x36,0xcd,0xbb,0xa9,0xb5,0xb4,0xeb,0xb9,0x24,0xa2,0xac,0x97,0x63,0xca,0xc1,0xe4,0xf4,0xb0,0xce,0x72,0xab,0x27,0x51,0xc9,0x24,0xdc,0xac,0xf4,0x5d,0x2d,0x6b,0x5b,0xe5,0xab,0x39,0xca,0x2a,0x44,0xb4,0x96,0x4f,0xb8,0xb5,0x3f,0xf6,0x4d,0xc3,0xae,0xed,0xad,0x5e,0x59,0xf6,0x8e,0x71,0x8e,0xec,0xa9,0x42,0x55,0xb7,0xd2,0xae,0x21,0x4d,0xcf,0x13,0x6c,0xaa,0xf4,0x02,0x69,0xec,0xc2,0x99,0x4f,0xa3,0xf8,0xe8,0x02,0xfe,0x9b,0xa1,0xdd,0x6a,0xaf,0xfe,0x8f,0x13,0xcc,0xff,0x00,0xec,0x2d,0x76,0xba,0x3f,0xc1,0x3f,0x15,0x6b,0x8f,0xb2,0xd3,0x47,0xbb,0x7f,0xf8,0x06,0xca,0xf6,0x3f,0xd8,0xb6,0x3d,0x32,0x7f,0x13,0xcc,0x97,0x71,0x79,0xf3,0xec,0xfd,0xd2,0x7f,0x03,0xd7,0x45,0xf1,0x43,0xf6,0x8b,0xd7,0x7c,0x33,0xe2,0x1d,0x47,0x4a,0xd3,0xf4,0xfb,0x78,0x61,0x47,0xd9,0xbf,0xc9,0xff,0x00,0x5a,0x9f,0xee,0x57,0xa1,0x4f,0x0f,0x4d,0x53,0x55,0x6a,0x49,0xea,0x7c,0x1e,0x37,0x3b,0xc6,0xfd,0x7a,0x58,0x1c,0x1d,0x24,0xdc,0x52,0x77,0x6e,0xdb,0x9f,0x3b,0x78,0xcb,0xe1,0x0e,0xbd,0xe0,0xbb,0x3f,0xb4,0x6a,0x76,0xfe,0x4a,0x57,0x23,0xa7,0x69,0x37,0x1a,0x8d,0xea,0x5b,0xc2,0xbb,0xdd,0xbf,0x82,0xbb,0x8f,0x1e,0x7c,0x4d,0xf1,0x37,0x8d,0x13,0xca,0xd4,0xee,0xde,0x68,0x7f,0xb9,0x5e,0x95,0xfb,0x27,0x78,0x56,0xca,0xfb,0xc5,0x53,0xea,0xfa,0x9c,0x5e,0x65,0xae,0x9d,0x17,0x9d,0xb3,0xfd,0xba,0x88,0xd3,0x85,0x5a,0xaa,0x9c,0x36,0x3d,0x4a,0x98,0xfc,0x46,0x07,0x2f,0x96,0x23,0x17,0x67,0x25,0xd1,0x6d,0xe4,0x3f,0xc0,0xff,0x00,0xb2,0xc3,0xdd,0x58,0x7d,0xaf,0xc4,0x5a,0x9c,0x5a,0x24,0x3b,0x3e,0xe4,0xdf,0x7e,0xba,0x8f,0x0e,0x7e,0xc9,0xda,0x2f,0x8a,0x6f,0xe0,0xb7,0xd3,0xf5,0xbd,0xe5,0xf7,0xfc,0x8f,0xb3,0xef,0xd7,0x99,0xfc,0x7d,0xf8,0xb7,0xa9,0xf8,0x9f,0xc6,0x17,0xd0,0xad,0xec,0xa2,0xc6,0xdd,0xf6,0x45,0x0a,0x37,0xf0,0x57,0x9e,0x78,0x6f,0xc7,0xfa,0xdf,0x87,0x35,0x18,0x6f,0x6c,0xae,0xa5,0x86,0x68,0x9f,0x7a,0x7c,0xf5,0xd0,0xe7,0x87,0xa5,0x2e,0x4e,0x4b,0xa5,0xd4,0xf1,0x21,0x84,0xce,0x71,0x78,0x7f,0xac,0x7d,0x63,0x92,0x52,0x57,0x4a,0xca,0xcb,0xcb,0x53,0x5f,0xe3,0x0f,0xc3,0x59,0xbe,0x19,0x78,0xb6,0xeb,0x47,0x95,0xd2,0x4f,0x2b,0xf8,0xd2,0xb8,0x0a,0xed,0x7e,0x22,0xf8,0xff,0x00,0x55,0xf8,0x8d,0xaa,0xff,0x00,0x68,0x6a,0xdf,0x3d,0xce,0xcd,0x9b,0xeb,0x8a,0xae,0x3a,0x8e,0x2e,0x6d,0xc3,0x63,0xeb,0xf0,0x3e,0xde,0x38,0x78,0x47,0x13,0xac,0xd2,0xd6,0xdd,0xc7,0x27,0xdf,0xaf,0xb2,0x7f,0x63,0x1d,0x0e,0xcb,0x4a,0xd1,0x7c,0x53,0xe3,0x09,0x9f,0x7d,0xde,0x99,0x68,0xfe,0x52,0x57,0xc6,0xc9,0xf7,0xeb,0xec,0x3f,0xd8,0xf3,0x55,0xb7,0xd7,0x3c,0x31,0xe2,0x8f,0x09,0x32,0xef,0x9a,0xee,0xd1,0xdd,0x3f,0xf8,0x8a,0xea,0xc1,0xb4,0xab,0x2b,0x9f,0x31,0xc5,0xbc,0xff,0x00,0xd9,0x93,0x71,0xda,0xea,0xfe,0x97,0x57,0x3c,0x03,0xe2,0x6f,0xc4,0x5d,0x4b,0xc4,0xfe,0x24,0xbb,0xbb,0xb8,0xbb,0x95,0xdd,0x9b,0xf8,0xde,0xbb,0xcf,0xd9,0xef,0xe3,0xd6,0xab,0xe0,0x8d,0x61,0x2c,0xa5,0xb8,0xf3,0xf4,0xbb,0x87,0x44,0x9a,0x19,0xbe,0x74,0xaf,0x22,0xf1,0xbe,0x8d,0x71,0xa3,0x6b,0xd7,0xb6,0xf7,0x71,0x3c,0x33,0x44,0xff,0x00,0x3a,0x3d,0x51,0xf0,0xfa,0x37,0xf6,0x92,0x6d,0xfe,0xfd,0x65,0x1a,0xb5,0x29,0xd5,0xe6,0xbe,0xb7,0x3d,0x0a,0xb9,0x76,0x0f,0x15,0x97,0x7b,0x07,0x14,0xe3,0x6d,0x3e,0xed,0xcf,0xb8,0x3c,0x62,0x64,0xf8,0x35,0xf1,0x1e,0x76,0xd3,0xed,0x12,0xeb,0xc3,0xde,0x24,0x8b,0x64,0xd6,0x70,0xfc,0xe9,0xf3,0xff,0x00,0x72,0x9f,0xe2,0x3f,0x84,0x3f,0x07,0x7c,0x2d,0xaa,0xda,0x6a,0xfa,0xde,0xb0,0xfa,0x7b,0xca,0xfb,0xdb,0x48,0x4f,0x9e,0xb7,0xbc,0x63,0x25,0xa6,0x9b,0xa6,0xfc,0x30,0x97,0x5a,0x74,0x77,0xfd,0xcf,0x9a,0x93,0xff,0x00,0xb9,0xff,0x00,0xa0,0x57,0xcd,0x9f,0xb5,0x46,0x8f,0xe2,0x0b,0x5f,0x88,0xf7,0x97,0x17,0xb2,0xb4,0xc9,0x71,0xf3,0xdb,0xce,0x9f,0x71,0xd3,0xfd,0x8a,0xf6,0xeb,0x35,0x4a,0x2d,0xf2,0xde,0xcf,0x6e,0xc7,0xe5,0x79,0x55,0x1a,0x98,0xfa,0xd0,0xa4,0xab,0x3a,0x6d,0xc5,0xa9,0x49,0x3f,0x8e,0xce,0xcb,0x7e,0xcb,0xae,0xe7,0xa8,0x7e,0xd2,0xda,0x32,0x7c,0x4d,0xf0,0xb5,0x8e,0xb5,0xe1,0x2b,0xe4,0xd4,0x74,0x1d,0x32,0x2f,0xf8,0xf6,0x86,0x2d,0x8f,0x0a,0x57,0xc6,0x73,0xa7,0x97,0x37,0xcf,0x5f,0x55,0xfe,0xc9,0x76,0xba,0x9a,0x5b,0x78,0x9e,0x5b,0xe5,0xff,0x00,0x8a,0x7b,0xfb,0x3a,0x6f,0xb4,0x79,0xdf,0x73,0xee,0x57,0xcc,0xba,0xee,0xcf,0xed,0x29,0xbc,0xaf,0xb9,0xbd,0xf6,0x57,0x97,0x8a,0xf7,0xd4,0x6b,0x35,0x66,0xef,0xf8,0x1f,0xa0,0x70,0xed,0xf0,0x95,0x2b,0x65,0xbc,0xdc,0xd1,0xa4,0xd5,0x9f,0xf8,0xae,0xec,0xfc,0xd1,0x9f,0x45,0x14,0x57,0x01,0xf6,0x41,0x45,0x14,0x50,0x01,0x4f,0x4a,0x65,0x3e,0x9a,0x10,0x51,0x45,0x14,0xc9,0x1f,0x5b,0x3a,0x6f,0x8b,0xf5,0x6d,0x2a,0xcf,0xec,0x96,0xf7,0xb3,0xc3,0x07,0xdf,0xf2,0x52,0x56,0x54,0xac,0x6a,0x2a,0x93,0x71,0x77,0x44,0x4e,0x10,0xa8,0xb9,0x66,0xae,0x8d,0x1b,0xed,0x72,0xee,0xfb,0xfd,0x6b,0xef,0xac,0xed,0xf4,0x53,0xa8,0xbd,0xdd,0xd8,0x46,0x11,0x82,0xb4,0x55,0x90,0xbb,0xc5,0x25,0x36,0x9d,0x4c,0x24,0x15,0x35,0x36,0x3a,0x75,0x04,0x85,0x26,0x1b,0xfb,0xb5,0xee,0x7f,0x0e,0x3e,0x02,0x69,0xbe,0x24,0xf0,0x3c,0x3e,0x2b,0xd6,0xfc,0x5b,0xa5,0xe8,0x3a,0x43,0xdc,0x3d,0xb7,0x97,0x73,0xbd,0xe6,0x77,0x4f,0xbf,0xf2,0x57,0xa4,0xf8,0x73,0xe1,0x2f,0xc1,0x9f,0x12,0xdb,0xea,0xfa,0x4e,0x85,0xac,0xeb,0x5a,0xde,0xb7,0x6f,0xa5,0xdc,0xde,0x45,0x79,0x34,0x49,0x0d,0xb2,0x79,0x49,0xbf,0xfe,0x07,0x5d,0x70,0xc3,0x4e,0x69,0x3b,0xa5,0x73,0xe6,0xb1,0x59,0xf6,0x13,0x0d,0x29,0x46,0xd2,0x97,0x2b,0xb3,0xb4,0x5d,0x97,0xab,0xdb,0xf1,0x1d,0xe0,0x7f,0xd9,0xcf,0xc2,0xbe,0x0b,0xd1,0x13,0x55,0xf1,0x85,0xd5,0xbf,0xc8,0x88,0xfe,0x5c,0xcf,0xb3,0xfe,0x01,0x5b,0x50,0x6b,0x9f,0x06,0xa6,0xb9,0x7b,0x49,0x62,0xb7,0x7d,0xef,0xf2,0x6f,0x44,0xfd,0xd7,0xfb,0x1b,0xeb,0xca,0x7f,0x6b,0x9f,0x1e,0x5e,0xdf,0x78,0xa6,0x4b,0x2d,0xd2,0xc3,0x04,0x48,0x9f,0xb9,0x7a,0xf9,0xa6,0x3d,0x5a,0x5f,0x37,0x76,0xfa,0x75,0x2b,0xc7,0x0f,0x2f,0x67,0x08,0x2d,0x0f,0x0f,0x03,0x92,0x62,0xf3,0x9a,0x0b,0x19,0x8a,0xc4,0x49,0x39,0x6c,0x93,0xb2,0x47,0xe8,0x6f,0xc4,0x6f,0x82,0xde,0x07,0xd7,0x3e,0x12,0xde,0xea,0xbe,0x1f,0xf2,0xb7,0xa2,0x3b,0xfc,0x8f,0x5f,0x9e,0x5a,0xa4,0x1f,0x65,0xbc,0x74,0xfe,0xed,0x76,0x5a,0x57,0xc5,0xed,0x6f,0x4b,0xd1,0xe4,0xd3,0x21,0xb9,0x7f,0x25,0xfe,0x4a,0xe1,0xae,0xee,0x3e,0xd5,0x2e,0xea,0xe4,0xc4,0xd6,0x85,0x6b,0x38,0xab,0x1f,0x51,0x90,0x65,0x58,0xbc,0xaf,0xda,0x53,0xc4,0x55,0xe7,0x8b,0x77,0x57,0xde,0xc4,0x74,0x51,0x45,0x71,0x9f,0x5c,0x7a,0xa7,0xc0,0x1f,0x1a,0x1f,0x07,0x78,0xf3,0x4e,0xbd,0xf3,0x52,0x14,0xdf,0xb1,0xdd,0xfe,0xe5,0x7d,0x75,0xf1,0x36,0xeb,0xe1,0x65,0xa6,0xb7,0xff,0x00,0x09,0x06,0xa7,0x70,0x9a,0x8d,0xd4,0xc8,0x8f,0xb1,0x2b,0xf3,0xda,0xde,0x66,0x85,0xd1,0xd7,0xef,0xd6,0x85,0xc6,0xa5,0x7d,0x76,0xbf,0xbd,0x95,0x9f,0xfd,0xf6,0xae,0xea,0x58,0xaf,0x65,0x07,0x06,0x93,0xf5,0x3e,0x37,0x33,0xe1,0xf8,0xe3,0xf1,0x91,0xc5,0x46,0xab,0x83,0xb5,0x9d,0xb4,0xba,0x3e,0xc1,0xb1,0xf1,0x6f,0xc2,0x8f,0x1c,0x7d,0x97,0x44,0x7d,0x3d,0x2d,0x66,0x6f,0xdc,0xad,0xeb,0xc3,0xf7,0x1f,0xfb,0xff,0x00,0xed,0xd7,0x49,0xf0,0xf7,0xe1,0x7b,0xfc,0x36,0xf1,0xcd,0xd6,0x9b,0xbd,0xde,0xca,0xf9,0x37,0xc2,0xe9,0xf7,0x26,0xf9,0x2b,0xe2,0x1d,0x0e,0x4b,0xaf,0xb7,0xc3,0xb5,0x9b,0x7e,0xea,0xfb,0xb3,0xc7,0x7e,0x34,0x7f,0x0e,0xfc,0x28,0xf0,0x86,0xb5,0x2d,0xbe,0xcd,0x51,0x36,0x3f,0xef,0x9f,0xef,0xa5,0x7a,0x38,0x6a,0xaa,0xad,0xe7,0x35,0x67,0x13,0xe2,0xb3,0xac,0xbe,0xae,0x5d,0x28,0x61,0xb0,0xf5,0x1c,0xa3,0x56,0xea,0xcd,0xde,0xcf,0x74,0xd7,0xdc,0x7c,0x69,0xf1,0x5f,0x43,0x9b,0x47,0xf1,0x9e,0xa9,0x6f,0x2a,0x3a,0x3a,0xca,0xff,0x00,0x7e,0xbb,0x8f,0x83,0xbe,0x07,0xf0,0x56,0xb3,0x66,0x97,0x7e,0x25,0xd5,0x7e,0xcb,0xb1,0xfe,0x74,0x47,0xfe,0x0a,0xf5,0xef,0x89,0xbf,0x0d,0xac,0xbe,0x3e,0xdb,0x27,0x89,0xbc,0x2e,0xf6,0xff,0x00,0xda,0x2d,0x6f,0xbe,0xe2,0xc9,0x1f,0xef,0xbf,0xfb,0x15,0xe4,0x56,0xbf,0xb3,0x37,0x8e,0x3e,0xd9,0x24,0x3f,0xd9,0x8e,0x9b,0x3e,0xfb,0xff,0x00,0x05,0x73,0x3a,0x13,0x85,0x5e,0x65,0x1e,0x64,0xcf,0xa3,0xa5,0x9a,0xd0,0xc5,0x60,0x15,0x0a,0x95,0xfd,0x8d,0x45,0xa4,0xb6,0x4d,0x5b,0xd4,0xf6,0x7d,0x67,0xe1,0x7f,0xc2,0xfb,0xef,0x85,0x3a,0x8e,0xbb,0xa1,0x45,0x77,0x73,0x3d,0xa2,0xba,0x7f,0xb7,0x5f,0x19,0xea,0x48,0x89,0x72,0xfb,0x2b,0xed,0xcf,0x0e,0x78,0x62,0xd3,0xe0,0x7f,0xc2,0xed,0x6e,0x2f,0x15,0xea,0x11,0x7d,0xb6,0xf9,0x36,0x25,0x92,0x3f,0xce,0x9b,0xd2,0xbe,0x27,0xd5,0x76,0xbd,0xe3,0xec,0xfb,0x9b,0xe8,0xc5,0xa5,0xee,0xbb,0x59,0xdb,0x61,0xf0,0xbd,0x59,0xce,0x58,0x85,0xed,0x1d,0x48,0x29,0x7b,0xb2,0x77,0x77,0x56,0xe9,0x7e,0xc5,0x2a,0xee,0xfe,0x14,0x7c,0x42,0xbb,0xf8,0x71,0xe2,0xab,0x1d,0x5a,0xd5,0xfe,0x78,0x9f,0xfe,0xfb,0xae,0x12,0x9d,0x5c,0x09,0xb8,0xb5,0x28,0xee,0x7d,0xa5,0x7a,0x30,0xc4,0xd2,0x95,0x1a,0x8a,0xf1,0x92,0xb3,0x3e,0xed,0xf1,0x3f,0xc3,0x2f,0x09,0x7e,0xd3,0x5a,0x6a,0x78,0x83,0xc3,0xfa,0x84,0x5a,0x7f,0x88,0x5d,0x3f,0xd2,0x2d,0x7f,0xbe,0xf5,0x5b,0xe1,0xff,0x00,0xec,0x4f,0x71,0xe1,0x4d,0x5e,0x1d,0x4f,0xc5,0x17,0xb6,0x90,0x59,0x5a,0xb7,0x9d,0x34,0x28,0xfb,0xdd,0xd2,0xbc,0x37,0xf6,0x5f,0xf1,0xae,0x8f,0xe1,0x9f,0x1b,0x41,0x77,0xaf,0x6a,0x0f,0xa7,0x5a,0xc5,0xf3,0xef,0x4f,0xef,0xd7,0xd3,0x3e,0x38,0xfd,0xb9,0xbc,0x35,0x6b,0x73,0x3d,0xbe,0x95,0xa3,0xbe,0xa2,0x88,0xff,0x00,0x24,0xd3,0x3e,0xc7,0x7a,0xf6,0xe9,0x4b,0x0f,0x51,0x7b,0x5a,0xaa,0xcc,0xfc,0x67,0x31,0xa1,0x9e,0x60,0x2a,0xcb,0x2d,0xcb,0x9c,0xa5,0x4b,0xa6,0x8b,0x45,0xda,0xef,0x43,0xca,0x7f,0x68,0xff,0x00,0x10,0x6a,0xdf,0x12,0x7c,0x48,0x9f,0xf0,0x8f,0xe9,0xf7,0x12,0x69,0x7a,0x4c,0x5e,0x4a,0x3c,0x3b,0xdf,0xe4,0x4f,0xe3,0xae,0x6b,0xc2,0x5f,0xb5,0x0c,0xb6,0x9a,0x32,0x69,0x5e,0x2d,0xd1,0xed,0xfc,0x4b,0x0c,0x31,0x6c,0x89,0xe6,0xfb,0xe9,0x5a,0x3f,0x11,0xbf,0x6b,0xcb,0x8f,0x11,0xf8,0x7a,0xeb,0x4c,0xd3,0x74,0x9b,0x7d,0x2f,0xed,0x7f,0xeb,0xa6,0x4f,0xbf,0x5f,0x32,0xdd,0x4f,0xf6,0x89,0xf7,0xd7,0x2d,0x6c,0x47,0x2d,0x4e,0x7a,0x52,0xbd,0xfe,0xe3,0xea,0xf2,0x9c,0x9d,0xd7,0xc1,0x47,0x0f,0x8f,0xa0,0xa0,0xa3,0xf0,0xeb,0xef,0x7a,0xb6,0xbb,0xf9,0x1e,0xf3,0xf1,0x1b,0xf6,0x99,0xb8,0xf1,0x37,0x87,0x3f,0xb0,0xb4,0x4d,0x2a,0xdf,0xc3,0x5a,0x53,0xa6,0xc9,0x61,0xb3,0xff,0x00,0x96,0xdf,0xef,0xbd,0x78,0x4c,0x8f,0xe7,0xbe,0xfa,0x82,0xa4,0x8f,0xee,0x57,0x14,0xea,0xce,0xa3,0xbc,0xd9,0xf5,0xf8,0x3c,0x06,0x1f,0x01,0x0f,0x67,0x87,0x8d,0x97,0xe7,0xea,0x2d,0x14,0x51,0x59,0x1d,0xc1,0x45,0x14,0x50,0x01,0x4f,0xa2,0x8a,0x68,0x90,0xa1,0x28,0xa7,0xd3,0x10,0x51,0x45,0x14,0x01,0xa5,0xe1,0xff,0x00,0x0f,0xdd,0xf8,0x93,0x56,0x86,0xc2,0xca,0x27,0x9a,0xe6,0xe1,0xf6,0x44,0x89,0xf7,0xdd,0xeb,0xa4,0xf8,0x8b,0xf0,0x9f,0xc4,0x5f,0x0a,0xf5,0x58,0x6c,0x3c,0x47,0xa7,0x3e,0x9f,0x73,0x2c,0x5e,0x72,0x23,0xff,0x00,0x72,0xbd,0x53,0xf6,0x29,0xf0,0xdd,0xbe,0xa5,0xf1,0x56,0x1d,0x56,0xf5,0x7f,0xd0,0xf4,0x3b,0x79,0xb5,0x29,0x5b,0xfb,0xbe,0x4a,0x57,0xa1,0x7e,0xd5,0x97,0x3f,0xf0,0xb3,0x3e,0x11,0xf8,0x53,0xc6,0xab,0x2b,0xcc,0xf0,0xdc,0x5c,0xd8,0x4c,0xee,0xbf,0xc7,0xbd,0xdd,0x2b,0xbe,0x18,0x75,0x2a,0x0e,0xa3,0xdc,0xf8,0xbc,0x56,0x79,0x52,0x8e,0x71,0x4f,0x03,0x18,0xfe,0xed,0xd9,0x37,0xda,0x4d,0x36,0xbf,0x23,0xcf,0x7e,0x19,0xfe,0xc7,0x1e,0x2a,0xf1,0xee,0x8f,0x65,0xaa,0xbb,0x69,0xfa,0x55,0x9d,0xdc,0x5e,0x75,0xbc,0xb7,0x57,0x1f,0x79,0x3f,0xdc,0x4a,0xe0,0xfe,0x36,0xfc,0x12,0xd4,0xfe,0x0d,0x78,0x93,0xfb,0x36,0xf5,0xd2,0xe9,0x1e,0x24,0x9a,0x1b,0x98,0x7e,0xe4,0xa9,0xfe,0xc5,0x7a,0x4f,0xec,0x5d,0xac,0x5f,0x4f,0xf1,0x7f,0x48,0x8a,0xe2,0xee,0x57,0xb5,0xb4,0xb7,0xb9,0x9b,0x63,0xbf,0xc8,0x9b,0x21,0x7a,0xee,0x6c,0x6e,0xa2,0xfd,0xa2,0xfe,0x1b,0x6b,0x7e,0x0f,0x9a,0x14,0x93,0xc4,0xfa,0x0c,0xb3,0x6a,0x7a,0x34,0xcf,0xff,0x00,0x2f,0x10,0xef,0xfd,0xf4,0x3f,0xfb,0x3d,0x6c,0xa8,0xd2,0xa9,0x45,0x38,0xaf,0x7b,0xf5,0x47,0x99,0x57,0x34,0xcc,0x70,0x39,0x9c,0xa3,0x88,0x9a,0x95,0x18,0xda,0xf6,0x56,0xe5,0x52,0x6d,0x27,0xe7,0x6b,0x6b,0xe5,0xf8,0xfc,0x6b,0x1d,0x3a,0xac,0xea,0x56,0x33,0x58,0x5e,0x3c,0x4e,0x8c,0x8e,0xad,0x55,0xab,0xcd,0x3f,0x40,0x4d,0x49,0x26,0x9e,0x86,0xc4,0x7e,0x2b,0xd4,0xe3,0xd0,0x53,0x46,0xfb,0x64,0xbf,0xd9,0xab,0x2f,0xda,0x12,0xdb,0x77,0xc9,0xe6,0xec,0xd9,0xbe,0xbd,0x7f,0xf6,0x58,0x76,0x4d,0x63,0xc6,0x57,0x29,0xb9,0xde,0x2f,0x0c,0x5f,0xbf,0xfe,0x39,0x5e,0x11,0x5e,0xeb,0xfb,0x35,0x9f,0x23,0x49,0xf8,0x93,0x70,0xc8,0xee,0x89,0xe1,0x8b,0x8d,0xdb,0x3f,0x83,0x7b,0xa5,0x74,0xe1,0xdb,0xf6,0xb1,0x7f,0xd6,0xc7,0x85,0x9c,0xc6,0x2b,0x01,0x51,0x45,0x5a,0xf6,0xfc,0x5a,0x44,0xdf,0xb5,0xa7,0x83,0x9e,0x0f,0x14,0x3e,0xa7,0x0f,0xef,0xad,0xae,0x3e,0x74,0x91,0x3e,0x7f,0xe0,0xaf,0x98,0x64,0x47,0x8d,0xf6,0x57,0xdd,0x5e,0x1c,0xf1,0xc7,0x86,0xbe,0x38,0x78,0x79,0x34,0x4d,0x6f,0x64,0x17,0xbb,0xfe,0x47,0x47,0xd9,0x5e,0x79,0xe2,0x3f,0xd9,0x1b,0x53,0x93,0x52,0x9f,0xfb,0x2a,0x58,0x6e,0xad,0x7f,0xe5,0x8b,0xef,0xfb,0xe9,0xfe,0xc5,0x15,0xe8,0x3a,0xb2,0xf6,0x94,0xb5,0x4c,0xf2,0x72,0x6c,0xf2,0x96,0x5b,0x45,0x60,0x73,0x0f,0x72,0x50,0xd2,0xef,0x66,0x8f,0x98,0xed,0x2c,0x26,0xbb,0x99,0x15,0x53,0x7e,0xea,0xd3,0xd6,0x7c,0x1d,0xa9,0x68,0x70,0xa4,0xd7,0x70,0x3c,0x08,0xff,0x00,0x73,0x7d,0x7d,0x71,0xf0,0xcb,0xf6,0x62,0xb7,0xf0,0x75,0xe2,0x6b,0x5e,0x25,0xb8,0xb4,0x92,0x0b,0x44,0xdf,0xe4,0x7d,0xa3,0xef,0xbf,0xf7,0x2b,0xcc,0xbf,0x69,0xdf,0x89,0x9a,0x57,0x8b,0xb5,0x58,0xed,0x74,0x7b,0x68,0xa0,0xb5,0xb7,0x44,0x4f,0x93,0xfb,0xf5,0x84,0xf0,0xce,0x95,0x37,0x3a,0x8e,0xcf,0xa2,0x3d,0x9c,0x3f,0x10,0x2c,0x76,0x35,0x61,0xb0,0x71,0xe6,0x87,0x59,0x74,0x47,0xcf,0x34,0x51,0x45,0x71,0x1f,0x62,0x4f,0x63,0xb7,0xed,0x29,0xba,0xbe,0xa4,0xf8,0x75,0xe1,0x1f,0x85,0xbe,0x3b,0xf0,0xdc,0x16,0x97,0xd7,0xbf,0xd9,0xda,0xba,0x27,0xce,0xf5,0xf2,0xa7,0xf0,0x55,0xb8,0x2f,0x66,0xb7,0xfb,0x8e,0xc9,0x5b,0xd2,0xaa,0xa9,0x3b,0xb4,0x99,0xe3,0x66,0x58,0x09,0xe3,0xa0,0x95,0x3a,0xae,0x0d,0x75,0x5f,0xd6,0xa7,0xda,0x5a,0x1f,0xc2,0x1f,0x85,0xbe,0x0a,0xd9,0xaa,0xea,0x1a,0xc2,0x5d,0x79,0x4f,0xfe,0xa7,0x7a,0x57,0x92,0xfe,0xd0,0x9f,0x1c,0x8f,0x8f,0xee,0x61,0xd3,0xec,0x65,0xff,0x00,0x89,0x5d,0x9f,0xc9,0x16,0xc4,0xd9,0x5e,0x1a,0xfa,0xcd,0xdb,0xfd,0xe9,0x59,0xff,0x00,0xe0,0x75,0x49,0xe4,0x77,0x7f,0x9a,0xba,0x2a,0x62,0xf9,0xa1,0xec,0xe9,0xc7,0x95,0x33,0xc5,0xc1,0x70,0xff,0x00,0xb1,0xc4,0x2c,0x56,0x2e,0xab,0xab,0x38,0xed,0x7e,0x9e,0x87,0x51,0xe1,0x9f,0x1f,0x6b,0x1e,0x15,0xba,0x49,0xf4,0xcb,0xe9,0x6d,0x9d,0x1f,0x7f,0xc8,0xf5,0xdf,0xbf,0xed,0x43,0xe3,0x89,0x2d,0xb6,0x26,0xa6,0xe9,0xfe,0xda,0x57,0x8c,0xd1,0x5c,0xf0,0xad,0x52,0x1a,0x46,0x4c,0xf7,0xab,0xe5,0xb8,0x3c,0x4c,0xfd,0xa5,0x5a,0x49,0xbe,0xed,0x23,0xab,0xf1,0x37,0xc4,0x2d,0x63,0xc5,0xd7,0x2f,0x2e,0xa7,0xa8,0x4b,0x72,0xff,0x00,0xed,0xbd,0x72,0xf4,0x51,0x53,0xcc,0xe4,0xdb,0x67,0x5d,0x3a,0x30,0xa3,0x15,0x0a,0x6a,0xcb,0xc8,0x29,0xd4,0xda,0x75,0x32,0x85,0x47,0x64,0xe9,0x4f,0x92,0x47,0x7f,0xbd,0x51,0xd4,0x91,0xc7,0xbe,0x81,0x31,0x28,0xab,0x7f,0xd9,0x57,0x1b,0x37,0x6d,0x7d,0x9e,0xbb,0x2a,0xa7,0x90,0xfb,0xf6,0x53,0xb1,0x09,0xa9,0x6c,0xc2,0x97,0xfd,0x5d,0x7a,0x27,0xc3,0x5f,0x82,0xde,0x22,0xf8,0x9b,0x73,0xe5,0x68,0xfa,0x7f,0x9c,0x89,0xf7,0xe6,0xdf,0xb1,0x13,0xfe,0x07,0x5e,0xdb,0x6f,0xfb,0x07,0x78,0xa1,0xe4,0x48,0xbf,0xb4,0x34,0x9f,0x3d,0xdf,0xfd,0x42,0x5c,0x7c,0xf5,0xbc,0x30,0xf5,0x6a,0x2b,0xc5,0x68,0x78,0x38,0xbc,0xfb,0x2d,0xc0,0xcf,0xd9,0xe2,0x2b,0x25,0x2e,0xdf,0xf0,0xc7,0xca,0x54,0x57,0xa5,0x7c,0x70,0xf8,0x2d,0xa8,0x7c,0x17,0xf1,0x4b,0xe8,0xba,0x84,0xa9,0x3b,0xec,0xde,0x8f,0x0f,0xdc,0xaf,0x35,0xac,0xa5,0x09,0x42,0x4e,0x32,0xdc,0xf5,0x30,0xd8,0x8a,0x58,0xba,0x51,0xaf,0x45,0xde,0x32,0xd9,0x85,0x3e,0x99,0x4f,0xa8,0x3a,0x42,0x8a,0x28,0xaa,0x20,0x29,0xf4,0x51,0x40,0x05,0x3a,0x9b,0x4f,0x4a,0x64,0xb3,0xeb,0xcf,0xd9,0xd7,0x43,0xb8,0xd0,0x3e,0x02,0x7c,0x42,0xf1,0x05,0xba,0xbf,0xda,0xf5,0x18,0x53,0x49,0xb5,0xd8,0x9f,0x3b,0xef,0xf9,0xde,0xbb,0x2f,0x86,0x3f,0x09,0xfc,0x4f,0xe3,0x6f,0xd9,0xd3,0xc4,0x9e,0x14,0xba,0xd3,0x2e,0x21,0x99,0xb5,0x18,0x6f,0x74,0xff,0x00,0xb6,0x45,0xe4,0xa3,0xbf,0xf1,0xfd,0xfa,0xf0,0x7f,0x84,0xff,0x00,0xb5,0x5f,0x88,0xbe,0x14,0x78,0x36,0x6f,0x0e,0xe9,0x76,0xf6,0x52,0x43,0x2d,0xc7,0x9c,0x93,0x5c,0xc3,0xbd,0xd1,0xeb,0xe9,0xff,0x00,0xd9,0xc3,0xc7,0x7f,0x10,0x3e,0x2f,0x59,0xea,0x9a,0xae,0xbb,0x7a,0x8f,0xe1,0x7b,0x88,0x66,0xb2,0x69,0xa4,0x74,0x85,0x11,0xf6,0x7f,0x72,0xbd,0xda,0x12,0xa5,0x35,0x18,0x75,0xb1,0xf8,0xce,0x79,0x47,0x31,0xc1,0x4a,0xbe,0x2a,0x6a,0x2a,0x2e,0xa4,0x64,0xa4,0xde,0xba,0x59,0x24,0x97,0xfc,0x13,0xc5,0xbf,0x64,0x4f,0x0e,0x1f,0x0f,0xfc,0x4e,0xf1,0x44,0x3a,0xb1,0x7b,0x54,0xd3,0xb4,0x8b,0xb4,0xbb,0x78,0x7e,0x7f,0x27,0xf8,0x1e,0xba,0xed,0x3b,0xe3,0xaf,0xc2,0x2f,0x86,0x5a,0xd7,0xda,0x3c,0x31,0xe1,0x2b,0xdb,0xdd,0x62,0x29,0xb7,0xa6,0xa7,0x75,0x71,0xb2,0xb4,0x3c,0x09,0x6b,0xf0,0xf7,0xe0,0xd6,0xa3,0xe3,0x15,0xf1,0x2f,0x8c,0x2d,0xee,0xaf,0x6e,0xd1,0xf4,0xf7,0xb6,0xd3,0x13,0xce,0xfd,0xcb,0xff,0x00,0x1a,0x3d,0x7c,0xb5,0xf1,0x3b,0x52,0xf0,0xbc,0x7e,0x3f,0x9a,0xef,0xc1,0xeb,0x76,0xfa,0x2a,0xec,0x74,0x4d,0x4b,0xe7,0x77,0x7f,0xe3,0xa9,0x94,0xbe,0xad,0x4a,0x29,0x5a,0xf7,0xf9,0x9d,0xd4,0x70,0x90,0xcf,0xb1,0xf5,0xa7,0x59,0x4f,0x91,0xc6,0x3b,0x5e,0x31,0x95,0x96,0xcf,0xbe,0xe7,0xab,0x7e,0xd2,0xdf,0x0b,0xe0,0xd6,0x16,0xc7,0xe2,0x2f,0x85,0x2d,0x5d,0xfc,0x3d,0xad,0xa7,0xda,0x65,0x48,0x13,0x7a,0x5a,0x4d,0xff,0x00,0x2d,0x93,0xe4,0xfb,0x95,0xf3,0x5d,0x7b,0xff,0x00,0x8a,0xbf,0x6c,0x6f,0x16,0xf8,0x83,0xc2,0xd7,0x3e,0x1f,0xb4,0x87,0x4f,0xd1,0x34,0xbb,0xb8,0xbc,0x99,0x61,0xd3,0xed,0x11,0x37,0x27,0xf7,0x2b,0xc0,0x1c,0xef,0x7a,0xe0,0xc4,0xca,0x9c,0xa7,0xcd,0x4f,0xa9,0xf6,0x59,0x25,0x2c,0x75,0x0c,0x2f,0xb1,0xc6,0xa5,0xee,0xbb,0x47,0x5b,0xbe,0x5e,0x97,0xf3,0x41,0x5d,0x9f,0x81,0x3e,0x23,0x5c,0x78,0x23,0x4d,0xf1,0x2d,0x95,0xbc,0x49,0x27,0xf6,0xde,0x9c,0xfa,0x63,0xbb,0xff,0x00,0x02,0x6f,0x47,0xdf,0xff,0x00,0x8e,0x57,0x19,0x45,0x73,0x46,0x4e,0x2e,0xe8,0xf6,0xea,0xd2,0x85,0x78,0x3a,0x75,0x15,0xd6,0x9f,0x83,0xb9,0x97,0xa6,0xeb,0xf7,0x7a,0x74,0xfe,0x6c,0x32,0xba,0x3a,0xff,0x00,0x1a,0x3d,0x7a,0x4e,0x87,0xfb,0x46,0x78,0xaf,0x46,0xb6,0xf2,0x62,0xd4,0x1d,0xd3,0xfb,0x8f,0x5e,0x4b,0xb2,0x8a,0xe7,0x85,0x49,0xc3,0xe1,0x67,0xa3,0x88,0xc0,0x61,0xb1,0x76,0xf6,0xd0,0x4c,0xf4,0x7f,0x15,0x7c,0x6f,0xf1,0x2f,0x8a,0x97,0xc9,0xbd,0xd4,0x65,0x91,0x3e,0xe6,0xca,0xf3,0xfb,0xbb,0xa7,0xbb,0x7d,0xcd,0x50,0x50,0x94,0xa5,0x39,0x4f,0x59,0x32,0xe8,0x61,0x28,0x61,0x63,0xcb,0x46,0x0a,0x2b,0xc8,0x7d,0x14,0x51,0x50,0x74,0x92,0x47,0xf7,0x29,0x69,0x23,0xfb,0x94,0xb4,0x09,0x85,0x14,0x53,0x92,0xd6,0x69,0x3e,0xea,0x50,0x4e,0x9d,0x46,0xd3,0xea,0x67,0xd3,0xa6,0x45,0xdc,0xc9,0x5d,0x67,0xc3,0x6f,0x87,0xba,0x87,0xc4,0x2f,0x10,0xc1,0xa6,0x69,0xf6,0xfb,0xe6,0x95,0xea,0xe1,0x17,0x29,0x24,0xb7,0x39,0xea,0xe2,0x29,0x50,0xa6,0xea,0xd4,0x95,0x92,0xdc,0xe4,0x12,0x07,0x7f,0xe1,0xa3,0xcb,0x7f,0x4a,0xfb,0x4b,0xfe,0x14,0x47,0xc3,0x7f,0x87,0xbf,0x65,0xd3,0xfc,0x51,0xad,0xdb,0xc9,0xa8,0xba,0x6f,0x97,0x63,0xff,0x00,0xa9,0xff,0x00,0x80,0x57,0x2f,0xf1,0x8b,0xf6,0x65,0xd3,0x20,0xf0,0xdf,0xfc,0x25,0x5e,0x09,0xb8,0x7d,0x47,0x48,0x4f,0xf5,0xdb,0xff,0x00,0xe5,0x8d,0x77,0x3c,0x1d,0x48,0x45,0xbb,0xab,0xae,0x87,0xc8,0x51,0xe2,0xbc,0x15,0x6a,0xb1,0xa6,0xd3,0x4a,0x5b,0x49,0xab,0x45,0xfc,0xcf,0x95,0x28,0xa9,0x27,0xb7,0xf2,0x25,0xdb,0x51,0xd7,0x21,0xf6,0x29,0xdd,0x5d,0x05,0x7b,0x47,0xec,0xef,0xf0,0xf7,0x4f,0xf1,0x56,0xb9,0x3d,0xee,0xb1,0xff,0x00,0x20,0x7d,0x3a,0x27,0x9a,0x5f,0x9e,0xbc,0x5e,0xbe,0x87,0xfd,0x97,0xef,0xed,0x35,0x29,0x35,0xef,0x0e,0xdc,0x4a,0xfe,0x7e,0xa7,0x69,0xb2,0xdd,0x3f,0x83,0x7d,0x74,0x61,0xd4,0x5d,0x54,0xa4,0x78,0x59,0xe5,0x4a,0x94,0xb0,0x15,0x25,0x49,0xb4,0xf4,0xdb,0x74,0xae,0xaf,0xf8,0x1b,0xd3,0xfe,0xd0,0x9e,0x1f,0xfe,0xd5,0x9f,0x4a,0xff,0x00,0x84,0x43,0x4b,0xfe,0xc4,0x76,0xd9,0xf2,0x26,0xc7,0xff,0x00,0x7e,0xb9,0xef,0x88,0xdf,0x09,0x74,0xa9,0x2f,0x34,0x8d,0x7b,0xc3,0x2e,0xef,0xa2,0xea,0x6e,0x88,0xa8,0xff,0x00,0x3f,0x94,0xff,0x00,0xdc,0xdf,0x5e,0x71,0xaf,0xfc,0x39,0xd6,0xb4,0x6f,0x12,0xbe,0x9f,0x71,0x63,0x2f,0xda,0xbc,0xdd,0x9f,0x77,0xef,0xd7,0xd8,0x9f,0x0d,0xbc,0x07,0xa7,0xda,0x7c,0x29,0x87,0x47,0xd4,0x2e,0x13,0xfb,0x5f,0xca,0xfb,0x6b,0xd9,0x4d,0xbf,0xe4,0xaf,0x42,0x8c,0x67,0x8a,0x6e,0x15,0x16,0xde,0x5b,0x1f,0x17,0x8f,0xab,0x86,0xc9,0x21,0x4f,0x13,0x83,0x9b,0xf7,0xb4,0x69,0x37,0x2b,0xab,0x6f,0xd7,0x6e,0xe6,0x47,0xc6,0x9f,0x13,0x7f,0xc3,0x3a,0x7c,0x34,0xd1,0x7c,0x1f,0xe1,0xf7,0x44,0xbd,0xbd,0x8b,0xce,0xbe,0xb9,0x44,0xf9,0xeb,0xe5,0x9d,0x2b,0xe2,0xff,0x00,0x89,0xb4,0xed,0x55,0x2e,0xed,0xf5,0x6b,0xa8,0xe7,0xdf,0xf7,0xfc,0xd7,0xaf,0xa0,0xbf,0x6d,0xfd,0x35,0xef,0x9f,0xc3,0x5a,0xc4,0x3b,0x3c,0x99,0x6c,0x52,0x1d,0x89,0xf7,0x3e,0x4a,0xf2,0x2f,0x80,0x3e,0x0b,0xf0,0x6f,0x8b,0x35,0x5b,0xaf,0xf8,0x4c,0xb5,0xef,0xec,0x4b,0x5b,0x74,0xde,0xbf,0xdf,0x9a,0xa2,0xbf,0x3f,0xd6,0x3d,0x9c,0x74,0xb6,0xc5,0xe4,0x6b,0x07,0x4f,0x27,0x78,0xdc,0x44,0x39,0xe5,0x2b,0xb9,0x69,0x76,0xdb,0x7d,0xb5,0x33,0xfe,0x32,0x7c,0x62,0xd4,0xfe,0x30,0x5f,0x58,0xdf,0x6a,0x76,0x71,0x43,0x35,0x9d,0xbf,0x93,0xfb,0x94,0xfb,0xf5,0xe5,0xd5,0xf7,0xed,0xef,0xc3,0x0f,0x83,0xfa,0x97,0xc1,0xef,0x15,0x6b,0x1e,0x15,0xd3,0x2e,0x75,0x5b,0x9d,0x2e,0x2f,0x91,0xe7,0x7f,0xe3,0xfe,0xfd,0x7c,0x11,0x7e,0x8a,0xb7,0x2f,0xb7,0xee,0x57,0x36,0x2a,0x9c,0xe1,0x25,0x29,0xbb,0xdc,0xf7,0xb8,0x7f,0x30,0xc3,0x62,0xe9,0x4e,0x86,0x16,0x93,0xa7,0x1a,0x6e,0xd6,0x7f,0x7e,0xc4,0x34,0x51,0x45,0x71,0x9f,0x58,0x3e,0x8a,0x28,0xa0,0x80,0xa7,0xd3,0x29,0xf5,0x40,0x14,0x25,0x14,0x25,0x00,0x3a,0xb6,0xac,0x7c,0x5d,0xaa,0xe9,0xb6,0x7f,0x64,0xb7,0xbe,0x9e,0x18,0x3f,0xe7,0x8a,0x4a,0xfb,0x2b,0x16,0x8a,0xa4,0xdc,0x5d,0xd3,0x31,0x9d,0x38,0x4d,0x5a,0x6a,0xe8,0xb9,0x3d,0xf4,0xb7,0x6f,0xb9,0xa4,0x6a,0xaf,0xf3,0xd1,0x1f,0xdc,0xa7,0x50,0x24,0x94,0x55,0x90,0x51,0x45,0x3b,0x65,0x30,0x0a,0x29,0xb5,0xdd,0x7c,0x24,0xf0,0x6e,0x95,0xe3,0x5f,0x14,0x25,0x8e,0xb5,0xaf,0xd9,0x78,0x6f,0x4e,0x58,0x9e,0x69,0x6f,0x2f,0x37,0xec,0xff,0x00,0x73,0xe4,0xfe,0x3a,0x71,0x5c,0xce,0xc8,0xc2,0xb5,0x58,0xd0,0xa7,0x2a,0xb3,0xd9,0x6b,0xdf,0xf0,0x47,0x91,0x51,0x5a,0x49,0xe1,0xfb,0xe7,0x4d,0xde,0x43,0x7f,0xdf,0x35,0x56,0x3b,0x29,0x9e,0x4f,0x23,0x6b,0x6f,0xae,0x33,0xdc,0x55,0x21,0x2d,0x99,0x5e,0x8a,0xec,0xf4,0x3f,0x85,0x1a,0xf6,0xb7,0xb1,0xad,0xf4,0xfb,0x87,0x47,0xfb,0x8f,0xb2,0xbd,0x27,0x43,0xfd,0x94,0x7c,0x51,0x7c,0x9b,0xee,0xe2,0x4b,0x24,0xf9,0x1f,0xf7,0xef,0xb2,0xb6,0x85,0x1a,0x95,0x3e,0x08,0xdc,0xf2,0xb1,0x19,0xb6,0x07,0x0b,0xfc,0x5a,0xa9,0x7c,0xcf,0x03,0xa7,0xd7,0xa0,0x7c,0x4d,0xf8,0x6b,0xff,0x00,0x08,0x05,0xe7,0xd9,0xde,0xe1,0x2e,0xa4,0xfe,0x3d,0x9f,0xc1,0x5e,0x7f,0x51,0x38,0xb8,0x4b,0x96,0x5b,0x9d,0xf8,0x7c,0x45,0x3c,0x4d,0x35,0x56,0x93,0xba,0x64,0x91,0xfd,0xca,0x3f,0x8a,0x88,0xfe,0xe5,0x2d,0x41,0xbb,0x3d,0xc3,0xe0,0x47,0xc0,0xfb,0x5f,0x89,0x5f,0xe9,0x17,0xba,0x9c,0x56,0x56,0xa8,0xff,0x00,0x3e,0xfa,0xfa,0x93,0xc0,0x9f,0xb2,0xbf,0xc3,0x58,0x34,0x47,0xbe,0x97,0x50,0xfe,0xd7,0x86,0xdd,0xdf,0xce,0x7d,0xf5,0xf9,0xff,0x00,0xa7,0x78,0x8e,0xf7,0x4a,0x5d,0x96,0xf7,0x72,0xc2,0x8f,0xf7,0xd1,0x1f,0xef,0xd7,0xd3,0x9f,0xb2,0x1f,0xc4,0x6b,0xd1,0xe2,0x6b,0x9d,0x2a,0x66,0x9a,0xea,0x1b,0xe8,0xbf,0xd4,0xff,0x00,0x1e,0xfa,0xf5,0xb0,0x95,0x29,0x5e,0x30,0x94,0x75,0xee,0x7e,0x63,0xc4,0xf8,0x2c,0xd3,0xd9,0x54,0xc5,0x51,0xc4,0x35,0x15,0xaf,0x2a,0xd3,0x4e,0xba,0x8f,0xf8,0xe1,0xe3,0x5f,0x86,0x96,0x3a,0x24,0xda,0x2f,0x87,0xf4,0x74,0x4b,0xa4,0xde,0x9e,0x72,0x26,0xcd,0x95,0x4b,0xf6,0x2b,0xd5,0x6c,0xad,0x3e,0x22,0xba,0xcc,0xe9,0x0d,0xdd,0xe4,0x2f,0x0c,0x5b,0xdf,0x65,0x79,0x17,0xc6,0xfd,0x11,0xb4,0x3f,0x1c,0x6a,0xf6,0xeb,0x2f,0x99,0x1a,0xdc,0x3e,0xc7,0x4f,0xb8,0xf5,0x83,0xf0,0xf3,0x5b,0xbd,0xd1,0xbc,0x49,0x63,0x71,0xa7,0xca,0xf0,0xdd,0x2b,0xfc,0x8e,0x95,0x9f,0xb7,0xe5,0xc4,0x29,0x38,0xed,0xd1,0x1d,0xd4,0xf2,0x98,0x55,0xc9,0x67,0x46,0x9d,0x46,0xf9,0xd5,0xee,0xdd,0xfa,0x5c,0xf6,0x0f,0x8e,0xde,0x11,0xf1,0x44,0x9f,0x10,0xb5,0x59,0xae,0x20,0xb8,0x7d,0xd7,0x1f,0x7f,0xef,0xd7,0xb9,0x7c,0x21,0xf0,0xfe,0xb7,0xe0,0xff,0x00,0x82,0x9a,0xf4,0xba,0xd5,0xbc,0xb0,0xda,0xdd,0xc4,0xfb,0x11,0xfe,0xfa,0x6c,0xf9,0xfe,0xe5,0x7a,0x17,0x88,0xbe,0x34,0xe9,0x9f,0x0f,0x7c,0x03,0x63,0x75,0xe2,0x38,0xa1,0xd4,0x35,0xb7,0x85,0x1f,0xc8,0x44,0x47,0x4d,0xff,0x00,0xdf,0x7a,0xe0,0x3c,0x33,0xfb,0x61,0xe9,0x9e,0x3b,0xbc,0x7f,0x0e,0x6b,0x1a,0x3c,0x36,0xba,0x75,0xf3,0xf9,0x3f,0x27,0xdc,0x4a,0xf5,0x23,0x0a,0x34,0xaa,0xb9,0x39,0x6a,0xcf,0xce,0xea,0x62,0xb3,0x1c,0xc3,0x01,0x1a,0x50,0xc3,0x7e,0xee,0x9b,0x57,0x6b,0xaa,0x8f,0x6d,0x8f,0x86,0x7c,0x41,0xff,0x00,0x21,0x39,0xdd,0x57,0xe4,0xdd,0x59,0x55,0xef,0x9f,0xb5,0x5f,0xc2,0x18,0xbe,0x1a,0xf8,0xc3,0x7d,0x93,0xef,0xd2,0xf5,0x14,0xfb,0x4d,0xbf,0xfb,0x09,0x5e,0x07,0x5e,0x1d,0x48,0x3a,0x73,0x71,0x96,0xe7,0xed,0x79,0x6e,0x2e,0x9e,0x3b,0x09,0x4e,0xbd,0x2d,0x9a,0x0a,0xd2,0xd1,0xb5,0x9b,0xbd,0x0e,0xfd,0x2e,0xed,0x25,0x78,0x66,0x89,0xfe,0x47,0x4a,0xcd,0xa9,0x11,0x37,0xbd,0x65,0xad,0xee,0x8e,0xf9,0x46,0x32,0x4e,0x32,0x57,0x4c,0xfa,0x02,0xcb,0xf6,0xb0,0xf1,0x07,0xd9,0xed,0x7e,0xd1,0x61,0x61,0x73,0x7d,0x6e,0x9b,0x12,0xe5,0xe2,0xf9,0xeb,0xb4,0xf8,0x2d,0xe2,0xdd,0x4f,0xc4,0x77,0x9e,0x2b,0xf1,0x67,0x88,0x2e,0xa5,0x78,0x61,0xb1,0xf9,0xdd,0xfe,0xe6,0xff,0x00,0xe0,0xaf,0x3d,0xf8,0x73,0xf0,0x67,0xc3,0xfa,0xc6,0x97,0x0e,0xb1,0xad,0xf8,0xae,0xcb,0x4e,0xb5,0xfb,0xfe,0x46,0xff,0x00,0x9d,0xea,0xd7,0xc5,0x1f,0x8a,0xfa,0x3d,0x8f,0x87,0xa3,0xf0,0x97,0x83,0xd1,0xe0,0xd2,0xd3,0xfd,0x74,0xdf,0xc7,0x71,0xfe,0xdd,0x7a,0xb0,0x9d,0x48,0x25,0x56,0xb4,0xb4,0x5b,0x23,0xf3,0xac,0x4e,0x0f,0x07,0x88,0x9c,0xb0,0x78,0x0a,0x36,0x93,0xd2,0x52,0xb3,0xb4,0x55,0xee,0xd2,0x6f,0xf2,0x47,0xb5,0x78,0x13,0xc4,0xde,0x19,0xfd,0xa0,0x7e,0x1e,0xbf,0x81,0xf5,0xdd,0x4d,0x34,0xfd,0x6a,0xd1,0xf7,0xe9,0xf3,0x4c,0xff,0x00,0x23,0xd7,0x9b,0x4d,0xfb,0x16,0xf8,0xea,0x3b,0xf9,0xfe,0xcb,0x64,0x9e,0x4a,0x3b,0xfe,0xfd,0xe5,0x44,0x4d,0x9f,0xdf,0xaf,0x9c,0x2d,0x35,0x9b,0x8b,0x1b,0xaf,0x3a,0x19,0x19,0x1d,0x7f,0x8d,0x2b,0xb6,0xff,0x00,0x85,0xe7,0xe3,0x03,0x67,0xf6,0x46,0xd7,0x6f,0x5e,0x1d,0xbb,0x36,0x79,0xcf,0xf7,0x2a,0x3e,0xb3,0x4a,0xa2,0x5e,0xd6,0x37,0x6b,0xa9,0xd3,0xfd,0x89,0x98,0x60,0x27,0x25,0x96,0xd5,0x4a,0x12,0x77,0x71,0x92,0xbd,0x9f,0x95,0xac,0x7d,0x6d,0xe1,0x8b,0x1d,0x17,0xf6,0x71,0xf8,0x71,0xad,0x43,0xe2,0x3d,0x6e,0xdb,0x50,0xbe,0xd5,0xad,0x1d,0x13,0x4f,0x86,0x6d,0xfb,0x1f,0x67,0xc9,0xf2,0x57,0xc2,0x7a,0xac,0x8b,0x3d,0xe4,0xce,0x9f,0x73,0x75,0x5a,0xd5,0x7c,0x47,0x7d,0xac,0x4d,0xbe,0xee,0x77,0x99,0xff,0x00,0xdb,0x6d,0xf5,0x97,0x5c,0xf5,0xab,0x2a,0xa9,0x45,0x2b,0x24,0x7a,0xf9,0x46,0x53,0x2c,0xba,0x55,0x2b,0x56,0x9f,0x3d,0x4a,0x8e,0xed,0xec,0xb4,0xda,0xc8,0x28,0xa2,0x8a,0xe6,0x3e,0x8c,0x7d,0x14,0x51,0x41,0x01,0x4f,0xa6,0x53,0xea,0x80,0x28,0x4a,0x28,0x4a,0x00,0x75,0x2c,0x69,0xbd,0xf6,0xd2,0x57,0xab,0x7e,0xcd,0x7f,0x0e,0xa2,0xf8,0x9b,0xf1,0x53,0x42,0xd1,0x6e,0x3f,0xe3,0xd6,0x59,0x77,0xdc,0x3f,0xfb,0x09,0xf3,0xbd,0x5c,0x22,0xe7,0x25,0x14,0x71,0xe2,0xf1,0x10,0xc2,0x50,0x9e,0x22,0xa6,0xd1,0x4d,0xb3,0x7b,0xe1,0xbf,0xec,0xa1,0xe3,0x0f,0x88,0x5a,0x2a,0x6b,0x31,0x45,0x1e,0x97,0xa6,0xb3,0xec,0x5b,0xcd,0x4a,0x5f,0x25,0x1f,0xfd,0xca,0x93,0xc1,0x1f,0xb2,0x87,0x8a,0x3c,0x6f,0xa9,0x6a,0xf6,0xf6,0xbf,0x62,0x8e,0xdb,0x4c,0x9a,0x58,0x6e,0x35,0x09,0xae,0x93,0xec,0xc8,0xe9,0xf7,0xfe,0x7a,0xdb,0xfd,0xa1,0x7e,0x2b,0xeb,0x7e,0x32,0xf1,0x3d,0xc6,0x95,0xa3,0xbc,0xb6,0xde,0x1b,0xd3,0x3f,0xd0,0xec,0xac,0xed,0xbe,0x44,0xd8,0x9f,0x26,0xfd,0x95,0x5f,0xf6,0x4d,0xf1,0x25,0xdd,0x8f,0xc5,0x0b,0x6d,0x1e,0xec,0x33,0xdb,0x6a,0xc9,0x35,0x83,0xc2,0xef,0xb1,0x3e,0x74,0xaf,0x42,0x30,0xa3,0xed,0x15,0x3b,0x7c,0xcf,0x88,0xa9,0x8b,0xcd,0xde,0x06,0xae,0x37,0x9e,0x29,0xdb,0x99,0x46,0xd7,0x71,0x5b,0xea,0xef,0xab,0xb1,0x8b,0xe0,0x1f,0x87,0xfe,0x0a,0xd2,0xbe,0x25,0x6a,0x9a,0x0f,0x8d,0x75,0x89,0x9e,0xd6,0xc7,0xe4,0x8a,0x6d,0x19,0x52,0x64,0xb8,0x9b,0xfd,0xff,0x00,0xee,0x54,0xff,0x00,0xb5,0x77,0x82,0xfc,0x3f,0xe0,0x4f,0x88,0xaf,0xa5,0x78,0x73,0x4c,0xb8,0xd3,0xed,0xa2,0xb7,0x87,0x7f,0xda,0x65,0xf3,0xbc,0xd7,0x74,0xdf,0xbf,0xff,0x00,0x1f,0xae,0xba,0x0f,0xd9,0x0b,0xc7,0x5a,0x8f,0x8b,0xee,0xe5,0xfb,0x07,0xd8,0xac,0x60,0x95,0xd3,0xed,0x37,0x32,0xa4,0x29,0xb6,0xae,0xfe,0xdb,0x1e,0x0e,0xfe,0xce,0xff,0x00,0x84,0x3b,0x56,0x4b,0x88,0xaf,0x7c,0xfd,0x21,0x2d,0x66,0xba,0x81,0xf7,0xa3,0xcd,0x0f,0xc9,0xff,0x00,0xa0,0x6c,0xaa,0x95,0x17,0x0a,0x32,0xbc,0x6d,0xa9,0x85,0x0c,0xce,0x95,0x5c,0xdb,0x0f,0xec,0xf1,0x0e,0x7c,0xd1,0x69,0xab,0xe8,0x9d,0x93,0xd9,0x77,0xd4,0xf9,0x4a,0xa6,0x8a,0x46,0x83,0xee,0xb6,0xca,0x86,0x9d,0x5e,0x69,0xfa,0x13,0x57,0xd1,0x9f,0xa0,0x9e,0x0e,0xf0,0xaf,0xc3,0xdf,0x1a,0x58,0x6b,0x16,0x5a,0x3d,0xba,0x3f,0x93,0x0a,0x26,0xf4,0x4f,0xbf,0xf2,0x7d,0xfa,0xf8,0xab,0xc6,0xf6,0xb6,0xbe,0x06,0xf8,0x91,0x7c,0x9b,0x77,0xc1,0x6f,0x71,0xf7,0x2b,0xe8,0x2f,0xd8,0xef,0xed,0x73,0xe8,0x9a,0xbb,0xfe,0xf9,0x11,0xfe,0xfb,0xff,0x00,0x05,0x7c,0xd9,0xf1,0xa2,0xef,0xed,0x5e,0x36,0xd5,0x25,0xdd,0xff,0x00,0x2d,0x6b,0xaf,0x15,0x25,0x3a,0x30,0xa9,0x6b,0x33,0xf3,0xfc,0x83,0x0f,0x52,0x86,0x6b,0x89,0xc2,0x4a,0xa3,0x94,0x12,0x5b,0x9e,0xd7,0xe1,0x9f,0xda,0x92,0xcb,0x4a,0x1a,0x75,0xbd,0x96,0x94,0x90,0xf9,0x48,0x88,0xff,0x00,0xdc,0x7a,0xf4,0xcf,0x8e,0xff,0x00,0x13,0x75,0x39,0xfe,0x1e,0xd9,0x6b,0x1a,0x3d,0xc2,0x42,0x8f,0xb3,0xee,0x6c,0xfb,0xff,0x00,0xc7,0x5f,0x08,0x59,0x4e,0xf1,0xce,0x95,0xf5,0xd7,0x80,0x5d,0x3c,0x7f,0xf0,0x3a,0xeb,0x4f,0xb8,0x8b,0xcc,0x7b,0x14,0x7f,0x26,0x7f,0xe3,0x47,0xfe,0xe5,0x3c,0x3e,0x22,0xa5,0x65,0x2a,0x6d,0xf4,0xd0,0xdb,0x39,0xc9,0x70,0x98,0x1a,0xf4,0x71,0x91,0x8d,0xd2,0x92,0xe6,0xbe,0xbb,0xb3,0xe5,0x8f,0x13,0xf8,0x8f,0x50,0xd7,0x2f,0xde,0x5b,0xd9,0xde,0x67,0x7f,0xe3,0x7a,0xc4,0xab,0xfa,0xdd,0xa7,0xd9,0x6f,0x1d,0x07,0xf0,0xbd,0x50,0xaf,0x23,0x56,0xee,0xcf,0xd3,0x28,0xa8,0xaa,0x6b,0x91,0x59,0x12,0x47,0xf7,0x29,0x6a,0x28,0xe4,0xa9,0x68,0x35,0x68,0x2b,0xd1,0x7e,0x07,0xf8,0x9b,0xfe,0x11,0xcf,0x1c,0xe9,0x77,0x6e,0xee,0x88,0x92,0xa6,0xfd,0x9f,0xdc,0xaf,0x39,0x8c,0xef,0x73,0x5e,0xf9,0xf0,0x5b,0xf6,0x7b,0xd6,0xfc,0x6a,0x96,0xba,0xad,0xbb,0xc5,0x0d,0x8e,0xff,0x00,0xf5,0xce,0xf5,0xd1,0x42,0x33,0x95,0x45,0xc8,0xb5,0x47,0x85,0x9c,0x57,0xc3,0x51,0xc2,0x4e,0x38,0xa9,0x5a,0x2d,0x35,0xf8,0x1d,0x0f,0xed,0x6b,0xe1,0x57,0x83,0x5b,0xb2,0xd5,0x6d,0xff,0x00,0x7d,0x6b,0x7d,0x6f,0xbd,0x1d,0x13,0x65,0x78,0x07,0x86,0x5d,0xf4,0xad,0x62,0xde,0xe2,0x55,0xfb,0xad,0xbe,0xbf,0x48,0xbc,0x79,0xe1,0xcf,0x01,0x5f,0x78,0x3f,0x4e,0xd3,0xfc,0x51,0xaa,0xbb,0xbd,0xa7,0xc9,0xe7,0xa7,0xff,0x00,0x11,0x5f,0x22,0xfc,0x73,0x1f,0x0e,0xec,0x74,0xe8,0xed,0xbc,0x29,0xb5,0xf5,0x1d,0xef,0xbe,0x64,0xfb,0x9b,0x2b,0xd0,0xc5,0x61,0xd4,0x65,0xed,0x13,0x47,0xc2,0xf0,0xde,0x74,0xeb,0xe1,0xe3,0x80,0x95,0x29,0x3d,0xd7,0x35,0xb4,0xb6,0xb6,0x77,0x3d,0xd7,0xe2,0x1f,0x81,0xff,0x00,0xe1,0x7e,0xfc,0x34,0xd1,0x75,0x2f,0x0d,0x5c,0x23,0xbd,0x95,0xbe,0xcf,0xb1,0x6f,0x44,0xd9,0xfd,0xff,0x00,0xf8,0x1d,0x79,0x7f,0xc2,0x1f,0xd9,0x73,0xc4,0xb2,0x78,0xba,0x19,0xb5,0x5b,0x36,0xd3,0xb4,0xe8,0x9f,0xce,0x96,0x67,0xfe,0x24,0xaf,0x14,0xf0,0x5f,0xc5,0xef,0x10,0x78,0x0e,0x5d,0xfa,0x66,0xa3,0x2c,0x3f,0x26,0xcf,0xf6,0x2b,0xae,0xf1,0x37,0xed,0x4b,0xe3,0x8f,0x13,0x58,0x47,0x69,0x71,0xac,0x4b,0x0c,0x08,0x9b,0x36,0x43,0xf2,0x50,0xeb,0xd0,0xaa,0xd5,0x49,0xa7,0x73,0x55,0x93,0x67,0x38,0x4a,0x73,0xc1,0xe1,0x27,0x1f,0x65,0x2b,0xea,0xd3,0xba,0x4c,0xeb,0xff,0x00,0x6c,0x3f,0x1e,0x69,0xba,0xff,0x00,0x89,0x6c,0x74,0xad,0x26,0xe3,0xcf,0xb6,0xd2,0xe2,0xfb,0x36,0xff,0x00,0xe0,0xaf,0x9a,0x2a,0xc5,0xf5,0xf4,0xd7,0xf3,0x3c,0xb2,0xca,0xee,0xed,0xfc,0x6f,0x55,0xeb,0x86,0xa5,0x47,0x56,0x6e,0x6f,0xa9,0xf6,0xf9,0x66,0x02,0x39,0x6e,0x16,0x18,0x58,0xbb,0xf2,0xf5,0x0a,0x3f,0x8e,0x8a,0x2b,0x33,0xd4,0x2d,0xa5,0xdc,0xc8,0x9b,0x15,0xdf,0x65,0x40,0xee,0xce,0x6a,0x3a,0x7d,0x04,0x6c,0x15,0x24,0x7f,0x72,0xa3,0xa9,0x23,0xfb,0x94,0x00,0xb4,0x52,0x7d,0xf7,0xab,0xd6,0xfa,0x35,0xd5,0xc2,0x6e,0x58,0x99,0xff,0x00,0xdc,0xa0,0xcd,0xca,0x31,0xd6,0x4c,0xa5,0x45,0x39,0xd3,0x63,0xec,0x7a,0x6d,0x05,0x0f,0xa2,0x8a,0x28,0x20,0x29,0xf4,0xca,0x7d,0x34,0x01,0x45,0x14,0x53,0x00,0xaf,0xa2,0x7f,0x62,0x0d,0x46,0x2b,0x5f,0x8d,0x7a,0x5d,0xbc,0xad,0xb1,0xee,0xd2,0x6b,0x64,0x7f,0xee,0x3b,0xa3,0xec,0xaf,0x9d,0xab,0xa3,0xf0,0x27,0x89,0xee,0xfc,0x1b,0xe2,0x7b,0x1d,0x5a,0xca,0x5d,0x97,0x36,0xb2,0xa4,0xc8,0xff,0x00,0xdd,0x7a,0xda,0x8c,0xf9,0x2a,0x46,0x5e,0x67,0x95,0x9a,0xe1,0x65,0x8d,0xc0,0xd5,0xc3,0xc7,0x79,0x27,0xf7,0xd8,0xfb,0x5b,0xe2,0x1f,0xc4,0x6d,0x37,0xf6,0x56,0xb8,0x83,0xc3,0x1a,0x56,0x89,0xa7,0xea,0x9a,0xb4,0xa8,0x97,0x3a,0x86,0xa1,0xa9,0xdb,0xf9,0xce,0xce,0xff,0x00,0xc0,0x9f,0xec,0x57,0x27,0xe3,0xa8,0x34,0x2d,0x63,0x45,0xf0,0x6f,0xc5,0xef,0x0d,0x69,0x29,0xa2,0x4e,0xfa,0x92,0x43,0xaa,0x58,0x5a,0xfd,0xc8,0x6e,0x51,0xf7,0xa3,0xa7,0xfb,0xe9,0x56,0xbe,0x27,0xfc,0x2a,0xb9,0xfd,0xa5,0x60,0xd3,0xbc,0x77,0xe0,0xf9,0x62,0xbf,0x9a,0xee,0x24,0x4d,0x53,0x4f,0x13,0x7e,0xfa,0xde,0xe3,0xf8,0xdf,0x1f,0xdc,0xaa,0x9f,0x10,0xad,0xec,0xbe,0x0b,0x7c,0x28,0xf0,0xbf,0x80,0x35,0x8b,0xdb,0x79,0x2f,0x2e,0xf5,0x4f,0xed,0x0d,0x51,0x2c,0xdf,0xce,0x7b,0x48,0x7e,0xe6,0xcf,0xf7,0xeb,0xda,0x93,0x97,0x34,0xb9,0xb4,0x8f,0x46,0x7e,0x4f,0x86,0x85,0x18,0xc2,0x8c,0x68,0xc9,0xcb,0x13,0x26,0xd5,0x45,0xad,0xda,0xb3,0xe6,0xba,0xdb,0xb5,0xb4,0xdd,0xa3,0x33,0xf6,0xd5,0xf1,0x5f,0x88,0xe3,0xf8,0x8c,0xdb,0xb5,0x0b,0xa9,0xb4,0x8b,0xb8,0xa1,0xbc,0xb4,0x87,0xcd,0x7f,0x25,0x11,0xd3,0xf8,0x12,0xad,0x69,0xde,0x10,0xd7,0xfe,0x32,0xfe,0xcc,0x56,0x56,0x96,0x5a,0x75,0xc6,0xa7,0xaa,0xe9,0x3a,0xc3,0xf9,0x31,0xc3,0x17,0xce,0xf0,0xca,0x9f,0xfd,0x85,0x41,0xfb,0x41,0xfe,0xd0,0x9f,0x0f,0x7c,0x71,0xe1,0x08,0x74,0x7d,0x23,0xc3,0x77,0x17,0xb7,0xf6,0x96,0x90,0xd9,0x5b,0xeb,0x7a,0x94,0xbb,0x26,0x85,0x13,0xfd,0x84,0xaf,0x28,0xb7,0xfd,0xa7,0x7c,0x77,0x63,0xe0,0xbb,0x5f,0x0b,0x5a,0x6b,0x77,0x16,0x5a,0x45,0xba,0x79,0x29,0x0d,0xb7,0xee,0x7e,0x4f,0xf7,0xd3,0xe7,0xae,0x59,0xd4,0x84,0x6a,0x4a,0xee,0xe9,0xa3,0xdb,0xc1,0x60,0x31,0xb5,0x72,0xfc,0x3c,0x69,0x51,0x54,0xea,0x53,0x92,0xd6,0x5a,0x68,0xba,0xe9,0xde,0xfb,0x3b,0x1e,0x53,0x7d,0x69,0x2d,0x8d,0xe4,0xd6,0xf3,0x23,0x46,0xe8,0xdb,0x1d,0x1f,0xf8,0x2a,0x2a,0x2e,0x2e,0x1a,0xe2,0x57,0x66,0xfb,0xed,0x45,0x79,0x87,0xe9,0x4a,0xf6,0x57,0xdc,0xfa,0xdf,0xf6,0x4a,0x9f,0xec,0x3e,0x0d,0xd5,0x25,0x78,0x9e,0x4f,0x93,0xfb,0xe9,0xb2,0xbe,0x56,0xf8,0xa9,0x75,0xf6,0xbf,0x16,0x6a,0x92,0xed,0xd9,0xba,0xe1,0xeb,0xeb,0x3f,0xd9,0xce,0xd6,0x24,0xf8,0x3f,0xa8,0xcb,0x2a,0x6f,0xfb,0xee,0x9b,0xdf,0xe4,0xff,0x00,0x81,0xa5,0x7c,0x77,0xe3,0x79,0x96,0x4d,0x76,0xf9,0xff,0x00,0xbd,0x2b,0xd6,0xf8,0x8f,0xe0,0x53,0x47,0xc9,0x64,0x36,0x9e,0x6f,0x8c,0xa9,0xe7,0x63,0x06,0x3f,0xbe,0x6b,0xea,0x0f,0xd9,0x2b,0x55,0x7f,0xed,0x89,0xb4,0xa9,0x51,0xdd,0x2e,0x13,0xe4,0xff,0x00,0x62,0xbe,0x7d,0xf0,0x54,0x36,0x17,0x1a,0xc4,0x2b,0xa8,0x7c,0x96,0xdb,0xfe,0x77,0xaf,0xac,0xfc,0x25,0xf1,0x63,0xe1,0xff,0x00,0xc2,0x8b,0x6b,0x5b,0x8d,0x32,0xde,0x29,0xf5,0x14,0xfb,0xef,0xb2,0xb3,0xc2,0x59,0x4f,0x9e,0x52,0xb2,0x47,0x7f,0x13,0xd5,0x9c,0xf0,0xcf,0x09,0x4e,0x93,0x9c,0xa5,0xb5,0xba,0x1e,0x41,0xf1,0x47,0xe0,0x87,0x88,0x13,0xc6,0x7a,0xa4,0x50,0x69,0x92,0xc8,0x9e,0x6e,0xff,0x00,0x93,0xfd,0xba,0xf2,0x7f,0x13,0xf8,0x4a,0xf7,0xc2,0xb7,0x3f,0x67,0xd4,0x22,0xf2,0x66,0xaf,0xa6,0x7c,0x71,0xfb,0x63,0xcb,0xa8,0xbb,0xfd,0x8a,0xc5,0x5d,0xf6,0x6c,0xf3,0x9e,0xbe,0x70,0xf1,0xc7,0x8d,0x2e,0xfc,0x69,0xa9,0x3d,0xdd,0xdb,0x7c,0xef,0x4b,0x10,0xa8,0xad,0x69,0xbb,0xb3,0x5c,0x8e,0xae,0x6b,0x28,0xc6,0x38,0xca,0x6a,0x31,0x4a,0xde,0x67,0x37,0x1f,0xdf,0x35,0x25,0x45,0xfc,0x75,0x2d,0x71,0x1f,0x60,0xc4,0x8f,0xef,0xd7,0x65,0xa3,0xfc,0x58,0xf1,0x1e,0x89,0xa5,0xfd,0x82,0xcb,0x53,0xb8,0x86,0xd7,0xfb,0x88,0xf5,0xc7,0x51,0x54,0xa4,0xe2,0xee,0x8e,0x7a,0xb4,0x29,0x62,0x15,0xaa,0xc5,0x35,0xe6,0x6f,0x6a,0xbe,0x34,0xd4,0xf5,0x67,0xdf,0x77,0x7d,0x71,0x33,0xff,0x00,0x7d,0xdf,0x7d,0x63,0xcf,0x74,0xf7,0x1f,0x7a,0xa1,0xa2,0x93,0x6d,0xea,0xd8,0xe1,0x4a,0x9d,0x35,0x68,0x45,0x21,0xf4,0x52,0x25,0x2d,0x52,0xd9,0xb3,0x50,0xa7,0x54,0x90,0x58,0xcb,0x74,0xfb,0x51,0x77,0xd5,0xbb,0xbd,0x0e,0xea,0xc5,0x77,0x4d,0x13,0xa7,0xfb,0xe9,0xb2,0x9a,0x77,0x30,0x73,0x82,0x76,0x6f,0x52,0x85,0x14,0x51,0x54,0x50,0xa8,0x37,0x57,0x7f,0xf0,0xf7,0xe0,0xe7,0x88,0xfe,0x23,0x5c,0xf9,0x5a,0x3e,0x9f,0x2c,0xdf,0xed,0xec,0xf9,0x3f,0xef,0xba,0xe1,0xec,0x36,0xa5,0xd2,0x33,0x7d,0xca,0xfa,0x5b,0x5f,0xfd,0xa5,0xa1,0xf0,0xcf,0x80,0xf4,0xef,0x0b,0xf8,0x1e,0x24,0xd3,0x60,0x58,0x93,0xed,0x77,0x88,0x9b,0x26,0x99,0xeb,0x6a,0x51,0xa7,0x2b,0xba,0xae,0xc9,0x7d,0xe7,0x83,0x9a,0x62,0x31,0xb4,0x94,0x69,0xe0,0x69,0xf3,0x4a,0x5d,0x5e,0xd1,0xf3,0x67,0x2f,0xe3,0x1f,0xd9,0x27,0xc7,0x5e,0x0e,0xd3,0x4e,0xa1,0x73,0xa6,0xa4,0xd6,0xa8,0xfb,0x1d,0xed,0x65,0xdf,0x56,0xbe,0x0b,0xfe,0xcb,0xda,0x87,0xc5,0x48,0x67,0xb8,0x4d,0x5a,0xca,0xc9,0x62,0xff,0x00,0x96,0x33,0xbf,0xef,0x9f,0xfe,0x01,0x5d,0xe7,0xec,0xb1,0xf1,0x23,0xc5,0xbe,0x22,0xf8,0x8b,0x6d,0x65,0x7b,0x7d,0x71,0xa8,0xe9,0xd7,0x1b,0xd2,0xe1,0x2e,0x5f,0x7f,0xc9,0xb3,0xe7,0xae,0x03,0xe2,0x6f,0x8b,0xae,0x3e,0x1b,0x7c,0x5f,0xd5,0xe5,0xf0,0xed,0xdb,0xda,0xda,0xc5,0x76,0xef,0x0a,0x23,0xfc,0x9f,0x7e,0xbb,0x39,0x68,0x46,0x31,0xad,0x67,0xca,0xfa,0x1f,0x28,0xb1,0xb9,0xbd,0x5a,0xb5,0x72,0xdf,0x69,0x15,0x59,0x25,0x25,0x24,0x9d,0xac,0xfa,0x34,0xf6,0x38,0x3f,0x88,0x5e,0x07,0x5f,0x03,0xf8,0xc6,0xeb,0x4a,0x8a,0xe1,0x2f,0x63,0xb7,0x7f,0xf5,0xe8,0x95,0xf5,0x31,0xf1,0x76,0x8f,0xe0,0x7f,0xd9,0xab,0xfb,0x4e,0x2f,0x0e,0x58,0xe9,0x1a,0xa5,0xf2,0x7d,0x9a,0xd1,0xde,0x14,0x77,0x97,0xfb,0xf3,0x56,0x77,0x84,0xae,0xbc,0x2b,0xfb,0x51,0xa5,0xad,0x95,0xdd,0xbc,0x5a,0x27,0x8c,0xa1,0x4f,0x92,0x64,0x4f,0x92,0xe1,0x2b,0x94,0xfd,0xb1,0xa3,0x9b,0x47,0xd7,0xb4,0xbf,0x0d,0x5b,0xdb,0xbc,0x1a,0x76,0x8d,0x62,0x90,0xa3,0xec,0xd9,0xbe,0xb6,0x8c,0x15,0x08,0xce,0xb5,0x3d,0x53,0xd8,0xe0,0xab,0x89,0x96,0x6b,0x8a,0xc3,0x65,0xb8,0xa4,0xe3,0x52,0x0e,0xf3,0xbb,0xdd,0x2e,0xd6,0xd1,0xa6,0xcf,0x98,0xaf,0xa7,0xfb,0x45,0xcb,0xbf,0xf7,0x9e,0xa1,0xa4,0x93,0xef,0xd2,0xd7,0x8e,0x7e,0xa4,0x92,0x4a,0xc8,0x7d,0x14,0xca,0x7d,0x02,0x61,0x42,0x51,0x42,0x50,0x21,0xf4,0x51,0x45,0x50,0x05,0x3f,0xfd,0x5d,0x32,0x9d,0x40,0x1b,0xda,0x37,0x8c,0x75,0x4f,0x0f,0xef,0xfe,0xcf,0xbe,0x9e,0xdb,0x7f,0xdf,0xf2,0x5d,0x93,0x7d,0x54,0xd5,0xb5,0xcb,0xbd,0x66,0xeb,0xed,0x17,0x73,0xbc,0xd3,0x7f,0x7d,0xdf,0x7d,0x66,0x52,0xa5,0x53,0x94,0x9a,0xb3,0x7a,0x1c,0xaa,0x95,0x35,0x27,0x35,0x15,0x7e,0xe4,0x9b,0xda,0x96,0x8a,0x48,0x91,0x9f,0xf8,0x2a,0x4b,0x68,0x5a,0x2a,0xcc,0x96,0x37,0x11,0xa6,0xf6,0x5a,0xad,0x57,0xaf,0x52,0x53,0x4f,0x66,0x74,0xfe,0x15,0xf8,0xd1,0xab,0x78,0x5b,0x41,0x93,0x4a,0xb7,0x95,0xfc,0x87,0x47,0xf9,0x2b,0xcf,0x2f,0xae,0xda,0xea,0x67,0x76,0xfe,0x3a,0xab,0x4f,0xae,0x67,0x26,0xec,0x9b,0xd8,0xf4,0x69,0x61,0x68,0xd0,0x9c,0xaa,0x53,0x8d,0x9c,0xb7,0xf3,0x1e,0x8e,0xf1,0xd1,0xf6,0xa7,0xfe,0xfd,0x32,0x8a,0x93,0xa6,0xd7,0x1f,0xbc,0x51,0x45,0x14,0x08,0x3f,0x8e,0xa5,0xa8,0xbf,0x8e,0xa5,0xa0,0x4c,0x28,0xa2,0xb5,0xfc,0x31,0xe1,0x8b,0xef,0x14,0xea,0xb0,0xd8,0x58,0xc4,0xf3,0x5d,0x4a,0xfb,0x11,0x12,0x9a,0x57,0x76,0x46,0x53,0x9c,0x69,0xc5,0xce,0x6e,0xc9,0x19,0x14,0x57,0xb8,0xeb,0xff,0x00,0xb2,0x87,0x8c,0xfc,0x39,0xe1,0xb7,0xd5,0x6e,0xf4,0xff,0x00,0x2d,0x11,0x37,0xba,0x7f,0x1d,0x78,0xf7,0xf6,0x6b,0xc3,0x79,0xe4,0xba,0xd6,0x93,0xa5,0x3a,0x6e,0xd2,0x56,0x38,0x30,0xb9,0x8e,0x17,0x1b,0x17,0x2c,0x3d,0x45,0x24,0xb7,0xb1,0x26,0x9d,0xa1,0xdd,0x6a,0x5f,0x25,0xbd,0xb3,0x4d,0xfe,0xe2,0xd5,0xab,0x4f,0x0c,0xdd,0xc9,0xa9,0x25,0xa3,0x5b,0x3a,0x4c,0xcf,0xb3,0x63,0xa5,0x7e,0x85,0x7e,0xca,0x3f,0x0f,0x74,0x2d,0x37,0xe1,0xd5,0xae,0xa1,0xa9,0xe9,0x91,0x3d,0xf4,0xa8,0xfe,0x53,0xbe,0xcf,0x9f,0xfd,0xba,0xf3,0x2f,0x0c,0xf8,0x45,0xfc,0x55,0xfb,0x4c,0xcf,0x15,0xed,0xa5,0xbc,0x0f,0x14,0xce,0xee,0x9b,0x36,0x27,0xfd,0xf1,0x5e,0x82,0xc0,0xf2,0xc6,0x2d,0xbd,0x64,0x7c,0x37,0xfa,0xdf,0x19,0x57,0xc4,0x53,0x8c,0x34,0xa4,0x9e,0xb7,0xdd,0xa2,0x4f,0x03,0xfc,0x33,0xf0,0x97,0xc0,0x8f,0x09,0x43,0xe2,0x5f,0x19,0xfd,0x9e,0xf7,0x54,0x99,0x37,0xda,0x69,0xff,0x00,0xdc,0x7a,0xf2,0x5f,0x8f,0x5f,0xb4,0x2d,0x97,0xc4,0xcb,0x34,0xd3,0xec,0x74,0x3b,0x4d,0x2a,0x14,0x7d,0xfb,0xe0,0x44,0xf9,0xeb,0xd3,0x3e,0x37,0xf8,0x2f,0xc4,0xbf,0x1a,0x3e,0x2a,0xdc,0xd9,0x69,0x56,0xee,0xf0,0x5a,0x7e,0xe5,0x3f,0xb8,0x95,0xe7,0xbe,0x35,0xfd,0x8f,0xfc,0x55,0xe1,0x5b,0x39,0x2e,0x3f,0xd1,0xef,0xbc,0xaf,0xbe,0x90,0xbe,0xf7,0x4a,0xde,0xb4,0x6a,0x59,0xd3,0xa5,0x1f,0x74,0xf2,0xf2,0xba,0xd9,0x7c,0xaa,0xc3,0x1b,0x99,0x57,0xbd,0x79,0x6a,0x93,0x7a,0x45,0x74,0x56,0xdb,0xef,0x3e,0x75,0x7f,0xbf,0x45,0x5b,0xd4,0x74,0xe9,0x74,0xdb,0x97,0x86,0x55,0xd8,0xe9,0x55,0x2b,0xc9,0x3f,0x59,0x4d,0x49,0x29,0x27,0xa0,0x55,0xbb,0x19,0x15,0x2e,0x93,0x7f,0xdc,0xdf,0x55,0x2a,0xfd,0x86,0x95,0x71,0xa9,0x3e,0xcb,0x78,0x99,0xdd,0x7f,0xb8,0xb4,0x11,0x26,0xa2,0x9b,0x93,0xd0,0xfb,0x4b,0xe0,0xb7,0xed,0x2b,0xf0,0xe3,0xc0,0x16,0x09,0x65,0x6f,0xe1,0x99,0xad,0x27,0x95,0x36,0x3d,0xe1,0x44,0x77,0xfb,0x95,0xe7,0xff,0x00,0xb4,0x47,0xc2,0x8d,0x2a,0xef,0x41,0x8f,0xc7,0x5e,0x15,0xbe,0x7d,0x47,0x47,0xba,0x97,0xc9,0xb8,0x1b,0x3f,0xd4,0xcd,0x5e,0x0f,0xa3,0xf8,0x4b,0x52,0xbf,0xbc,0x48,0xa1,0xb4,0x95,0xdf,0xfb,0x88,0x95,0xf5,0xa7,0x8d,0x2d,0x3f,0xe1,0x57,0xfe,0xce,0x7a,0x5f,0x84,0x75,0xdd,0x89,0xab,0xeb,0x37,0x3e,0x77,0x90,0xff,0x00,0xf2,0xc5,0x2b,0xd7,0x85,0x49,0x57,0xa5,0x28,0xd4,0x49,0x25,0xb1,0xf9,0x7e,0x2b,0x0b,0x47,0x27,0xc7,0xd2,0xc4,0x60,0xaa,0x39,0x4e,0xa4,0xad,0x28,0xde,0xf7,0x5d,0x5e,0xb7,0x6a,0xde,0xa7,0x1b,0xfb,0x26,0xe9,0x6b,0xe1,0x2b,0x3f,0x11,0x78,0xef,0x51,0x67,0x4b,0x6d,0x1e,0xdd,0xd2,0x23,0xb3,0xe4,0x79,0xbf,0x82,0xb7,0xf4,0x3f,0x8d,0xfa,0x27,0xc7,0x04,0x93,0xc2,0xbe,0x3a,0xb4,0x54,0x9a,0x77,0x7f,0xb2,0xeb,0x48,0x9f,0x3d,0xbd,0x74,0xf7,0x7a,0xe7,0xc3,0x0f,0x07,0xfc,0x0b,0x87,0xc3,0x57,0xbe,0x22,0xfb,0x73,0xba,0x79,0xef,0x0e,0x9c,0x9f,0x3c,0xb3,0x3f,0xf7,0xeb,0xe4,0x8f,0x0a,0x78,0xf2,0x5f,0x01,0xf8,0xcf,0xfb,0x63,0x4a,0x48,0x9d,0xe2,0x7f,0xdd,0x25,0xca,0x6f,0x4a,0xa9,0x54,0x58,0x75,0x0a,0x69,0xab,0x75,0x23,0x0f,0x83,0x79,0xe5,0x6c,0x56,0x32,0x54,0xe5,0x1a,0x89,0xfe,0xed,0xbb,0xc6,0xd6,0x5a,0x59,0xfa,0xea,0xee,0xbe,0xf3,0xb9,0xf8,0xd9,0xfb,0x38,0x6b,0xbf,0x0b,0xee,0xa6,0xb8,0xf2,0x9e,0xe7,0x47,0xfb,0xe9,0x7a,0x9f,0x71,0xd3,0xf8,0x2b,0xc5,0x2b,0xd2,0xbe,0x22,0xfc,0x7a,0xf1,0x47,0xc4,0x98,0xbe,0xcf,0xaa,0xdf,0x6e,0xb5,0xdf,0xbf,0xec,0xd0,0xa6,0xc8,0x6b,0xcd,0x3f,0x8a,0xbc,0xda,0xae,0x9f,0x3b,0x74,0xf6,0x3e,0xef,0x2b,0x8e,0x3a,0x18,0x68,0xc7,0x30,0x69,0xcf,0xc8,0x5a,0x7d,0x32,0x9f,0x58,0x1e,0xb8,0x51,0x45,0x14,0x10,0x3e,0x8a,0x28,0xa6,0x80,0x28,0xa2,0x84,0xa6,0x04,0x91,0xa6,0xf7,0x45,0x5a,0xf6,0xcf,0x04,0x7e,0xc9,0xde,0x3d,0xf1,0xce,0x85,0x0e,0xb1,0x67,0xa4,0x3a,0x59,0xdc,0x7f,0xa9,0x79,0x9b,0x67,0x9d,0xfe,0xe6,0xfa,0xe0,0xfe,0x11,0xe9,0x36,0xba,0xef,0xc4,0x3d,0x0b,0x4f,0xbd,0xe2,0xda,0xe2,0xee,0x14,0x7f,0xf7,0x1d,0xeb,0xdd,0x3f,0x69,0x5f,0x1e,0x78,0x98,0x7c,0x5f,0xbd,0xd3,0xec,0xda,0x5b,0x2b,0x2d,0x26,0x5f,0xb1,0xda,0x5b,0x5b,0x3b,0xa2,0x42,0x89,0xf7,0x2b,0xb2,0x8d,0x38,0x72,0xba,0x95,0x15,0xd5,0xed,0xa1,0xf2,0xb9,0xa6,0x37,0x15,0x1c,0x4c,0x30,0x78,0x36,0xa3,0x26,0x9c,0x9b,0x96,0xd6,0x5f,0xe7,0x73,0xcf,0xfc,0x15,0xfb,0x36,0xf8,0x8b,0xc4,0x9f,0x13,0xff,0x00,0xe1,0x0d,0xd4,0x22,0x5d,0x17,0x50,0x44,0x77,0x97,0xed,0x9f,0x26,0xc4,0x4a,0xf7,0xff,0x00,0x00,0xfc,0x01,0xf8,0x41,0x65,0x75,0xaa,0x44,0x35,0xab,0xbf,0x1c,0xea,0xda,0x3d,0xa3,0xde,0x4d,0x65,0x6c,0xbf,0x66,0xb6,0x74,0x4f,0xe0,0xdf,0x5a,0x3e,0x37,0xf8,0x8d,0x37,0x80,0xd3,0xe0,0xc7,0x8b,0xfc,0x45,0x13,0x0d,0x69,0x61,0x74,0xd4,0x5f,0x67,0xef,0xa5,0xb6,0xdf,0xb1,0x37,0xff,0x00,0x7f,0xe4,0xaf,0x1e,0xf8,0x29,0xe3,0xfd,0x3a,0x0f,0xda,0x5a,0x3b,0x8b,0x45,0xdf,0xa2,0xea,0xd7,0xb3,0x59,0x24,0x33,0x7c,0x9f,0xe8,0xd3,0x6f,0x4f,0x9f,0xfe,0xfb,0xae,0xe8,0xc6,0x8d,0x29,0x28,0xda,0xf7,0x7d,0x4f,0x8d,0xad,0x89,0xcc,0xf3,0x5c,0x3d,0x4a,0xea,0x6e,0x11,0x8c,0x1b,0xf7,0x74,0x52,0x94,0x5b,0x52,0xd7,0x7d,0x52,0xba,0xb3,0x4e,0xc7,0x7f,0xae,0xf8,0xb7,0xc3,0x5f,0x16,0xfe,0x0c,0x78,0xef,0x4d,0xd2,0x3c,0x21,0xa6,0x78,0x6a,0x4d,0x05,0x21,0xd4,0xed,0xfe,0xc6,0x9f,0x3e,0xcd,0xfb,0x1f,0x7b,0xff,0x00,0xc0,0xeb,0xe3,0x47,0x4d,0x92,0x3a,0xff,0x00,0xb7,0x5d,0xef,0xc4,0x83,0xa9,0xfc,0x3f,0xf1,0xe7,0x8a,0x34,0x4b,0x69,0xe7,0xb2,0x4f,0xb4,0x4d,0x67,0x2a,0x23,0xec,0xdc,0x9b,0xfe,0xe3,0xd7,0x03,0x5c,0x35,0xe6,0xe7,0x2b,0x3d,0xd6,0x9f,0x89,0xf6,0x99,0x36,0x0a,0x38,0x3a,0x52,0x95,0x39,0x5e,0x13,0xb4,0x95,0xdb,0x6d,0x5d,0x2b,0xea,0xfb,0x9f,0xff,0xd9
  3. };
接下来是数据格式的转换,硬件JPEG输出的是YCrCb格式,可以调用如下接口转换为所需格式:
  1. void DMA2D_Copy_YCbCr_To_RGB(uint32_t *pSrc,
  2.                                     uint32_t *pDst,
  3.                                     uint16_t x,
  4.                                     uint16_t y,
  5.                                     uint16_t xsize,
  6.                                     uint16_t ysize,
  7.                                     uint32_t PixelFormat,
  8.                                     uint32_t ChromaSampling)
  9. {
  10.         uint32_t cssMode = DMA2D_CSS_420;
  11.         uint32_t inputLineOffset = 0;
  12.         uint32_t destination = 0;
  13.         /* 处理输入行偏移 */
  14.         if(ChromaSampling == JPEG_420_SUBSAMPLING)
  15.         {
  16.                 cssMode = DMA2D_CSS_420;
  17.                 inputLineOffset = xsize % 16;
  18.                 if(inputLineOffset != 0)
  19.                 {
  20.                         inputLineOffset = 16 - inputLineOffset;
  21.                 }
  22.         }
  23.         else if(ChromaSampling == JPEG_444_SUBSAMPLING)
  24.         {
  25.                 cssMode = DMA2D_NO_CSS;
  26.                 inputLineOffset = xsize % 8;
  27.                 if(inputLineOffset != 0)
  28.                 {
  29.                         inputLineOffset = 8 - inputLineOffset;
  30.                 }
  31.         }
  32.         else if(ChromaSampling == JPEG_422_SUBSAMPLING)
  33.         {
  34.                 cssMode = DMA2D_CSS_422;
  35.                 inputLineOffset = xsize % 16;
  36.                 if(inputLineOffset != 0)
  37.                 {
  38.                         inputLineOffset = 16 - inputLineOffset;
  39.                 }
  40.         }
  41.         /* 输出地址,特别注意末尾乘以2的对RGB565,如果输出格式是ARGB8888,需要乘以4 */
  42.         destination = (uint32_t)pDst + ((y * 320) + x) * 4;
  43.         DMA2D->CR      = 0x00010000UL | (1 << 9);
  44.         DMA2D->OOR     = 320 - xsize;
  45.         DMA2D->OPFCCR  = PixelFormat
  46.                          | (DMA2D_REGULAR_ALPHA << 20)
  47.                          | (DMA2D_RB_REGULAR << 21);
  48.         DMA2D->FGPFCCR = DMA2D_INPUT_YCBCR
  49.                          | (DMA2D_REPLACE_ALPHA << 16)
  50.                          | (DMA2D_REGULAR_ALPHA << 20)
  51.                          | (DMA2D_RB_REGULAR << 21)
  52.                          | (0xFFU << 24)
  53.                          | (cssMode << 18);
  54.         DMA2D->FGOR    = inputLineOffset;
  55.         DMA2D->NLR     = (uint32_t)(xsize << 16) | (uint16_t)ysize;
  56.         DMA2D->OMAR    = (uint32_t)destination;
  57.         DMA2D->FGMAR   = (uint32_t)pSrc;
  58.         DMA2D->CR   |= DMA2D_CR_START;
  59.         while (DMA2D->CR & DMA2D_CR_START) {}
  60. }
解码后图片的输出使用到了LTDC模块,首先要初始化LTDC模块的引脚与时钟:
  1. void HAL_LTDC_MspInit(LTDC_HandleTypeDef* hltdc)
  3.   GPIO_InitTypeDef GPIO_InitStruct = {0};
  4.   RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  5.   if(hltdc->Instance==LTDC)
  6.   {
  7.   /* USER CODE BEGIN LTDC_MspInit 0 */
  8.   RCC_OscInitTypeDef        RCC_OscInitStruct={0};
  9.   /* USER CODE END LTDC_MspInit 0 */
  10.   /** Initializes the peripherals clock
  11.   */
  12.     PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_LTDC;
  13.     PeriphClkInit.LtdcClockSelection = RCC_LTDCCLKSOURCE_PLL3R;
  14.     if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
  15.     {
  16.       Error_Handler();
  17.     }
  18.     /* Peripheral clock enable */
  19.     __HAL_RCC_LTDC_CLK_ENABLE();
  20.     __HAL_RCC_GPIOG_CLK_ENABLE();
  21.     __HAL_RCC_GPIOB_CLK_ENABLE();
  22.     __HAL_RCC_GPIOE_CLK_ENABLE();
  23.     __HAL_RCC_GPIOA_CLK_ENABLE();
  24.     /**LTDC GPIO Configuration
  25.     PG0     ------> LTDC_R7
  26.     PB3(JTDO/TRACESWO)     ------> LTDC_R4
  27.     PG2     ------> LTDC_HSYNC
  28.     PE11     ------> LTDC_VSYNC
  29.     PA11     ------> LTDC_B3
  30.     PB4(NJTRST)     ------> LTDC_R3
  31.     PA9     ------> LTDC_B5
  32.     PG1     ------> LTDC_R6
  33.     PA10     ------> LTDC_B4
  34.     PA8     ------> LTDC_B6
  35.     PG13     ------> LTDC_CLK
  36.     PA15(JTDI)     ------> LTDC_R5
  37.     PB12     ------> LTDC_G5
  38.     PA0     ------> LTDC_G3
  39.     PA1     ------> LTDC_G2
  40.     PB14     ------> LTDC_DE
  41.     PB15     ------> LTDC_G7
  42.     PB11     ------> LTDC_G6
  43.     PB13     ------> LTDC_G4
  44.     PA6     ------> LTDC_B7
  45.     */
  46.     GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2|GPIO_PIN_1|GPIO_PIN_13;
  47.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  48.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  49.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  50.     GPIO_InitStruct.Alternate = GPIO_AF13_LTDC;
  51.     HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  52.     GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_12|GPIO_PIN_14
  53.                           |GPIO_PIN_11;
  54.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  55.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  56.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  57.     GPIO_InitStruct.Alternate = GPIO_AF13_LTDC;
  58.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  59.     GPIO_InitStruct.Pin = GPIO_PIN_11;
  60.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  61.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  62.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  63.     GPIO_InitStruct.Alternate = GPIO_AF11_LTDC;
  64.     HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  65.     GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_8|GPIO_PIN_15|GPIO_PIN_0
  66.                           |GPIO_PIN_1;
  67.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  68.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  69.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  70.     GPIO_InitStruct.Alternate = GPIO_AF13_LTDC;
  71.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  72.     GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
  73.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  74.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  75.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  76.     GPIO_InitStruct.Alternate = GPIO_AF14_LTDC;
  77.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  78.     GPIO_InitStruct.Pin = GPIO_PIN_15|GPIO_PIN_13;
  79.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  80.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  81.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  82.     GPIO_InitStruct.Alternate = GPIO_AF10_LTDC;
  83.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  84.     GPIO_InitStruct.Pin = GPIO_PIN_6;
  85.     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  86.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  87.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  88.     GPIO_InitStruct.Alternate = GPIO_AF12_LTDC;
  89.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  90.   /* USER CODE BEGIN LTDC_MspInit 1 */
  91.   /* LCD clock configuration */
  92.   /* Typical PCLK is 25 MHz so the PLL3R is configured to provide this clock */
  93.   /* LCD clock configuration */
  94.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  95.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  96.   RCC_OscInitStruct.PLL1.PLLState = RCC_PLL_NONE;
  97.   RCC_OscInitStruct.PLL2.PLLState = RCC_PLL_NONE;
  98.   RCC_OscInitStruct.PLL3.PLLState = RCC_PLL_ON;
  99.   RCC_OscInitStruct.PLL3.PLLSource = RCC_PLLSOURCE_HSI;
  100.   RCC_OscInitStruct.PLL3.PLLM = 4;
  101.   RCC_OscInitStruct.PLL3.PLLN = 25;
  102.   RCC_OscInitStruct.PLL3.PLLP = 2;
  103.   RCC_OscInitStruct.PLL3.PLLQ = 20;
  104.   RCC_OscInitStruct.PLL3.PLLR = 16;
  105.   RCC_OscInitStruct.PLL3.PLLS = 2;
  106.   RCC_OscInitStruct.PLL3.PLLT = 2;
  107.   RCC_OscInitStruct.PLL3.PLLFractional = 0;
  108.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  109.   {
  110.    /* Initialization error */
  111.    while(1);
  112.   }
  113.   PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_LTDC;
  114.   PeriphClkInit.LtdcClockSelection   = RCC_LTDCCLKSOURCE_PLL3R;
  115.   if(HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
  116.   {
  117.     while(1);
  118.   }
  119.   /* USER CODE END LTDC_MspInit 1 */
  120.   }
  121. }
其次再对其进行初始化:
  1. static void MX_LTDC_Init(void)
  3. LTDC_LayerCfgTypeDef pLayerCfg = {0};
  4. hltdc.Instance = LTDC;
  5.   hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
  6.   hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
  7.   hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
  8.   hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
  9.   hltdc.Init.HorizontalSync = 3;
  10.   hltdc.Init.VerticalSync = 3;
  11.   hltdc.Init.AccumulatedHBP = 11;
  12.   hltdc.Init.AccumulatedVBP = 11;
  13.   hltdc.Init.AccumulatedActiveW = 811;
  14.   hltdc.Init.AccumulatedActiveH = 491;
  15.   hltdc.Init.TotalWidth = 819;
  16.   hltdc.Init.TotalHeigh = 499;
  17.   hltdc.Init.Backcolor.Blue = 0;
  18.   hltdc.Init.Backcolor.Green = 0;
  19.   hltdc.Init.Backcolor.Red = 0;
  20.   if (HAL_LTDC_Init(&hltdc) != HAL_OK)
  21.   {
  22.     Error_Handler();
  23.   }
  24.   pLayerCfg.WindowX0 = 0;
  25.   pLayerCfg.WindowX1 = 320;
  26.   pLayerCfg.WindowY0 = 0;
  27.   pLayerCfg.WindowY1 = 240;
  28.   pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_ARGB8888;
  29.   pLayerCfg.Alpha = 127;
  30.   pLayerCfg.Alpha0 = 0;
  31.   pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
  32.   pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
  33.   //pLayerCfg.FBStartAdress = (uint32_t)&image_data_Cloud_320_240;
  34.   pLayerCfg.FBStartAdress = 0;
  35.   pLayerCfg.ImageWidth = 320;
  36.   pLayerCfg.ImageHeight = 240;
  37.   pLayerCfg.Backcolor.Blue = 0;
  38.   pLayerCfg.Backcolor.Green = 0;
  39.   pLayerCfg.Backcolor.Red = 0;
  40.   if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0) != HAL_OK)
  41.   {
  42.     Error_Handler();
  43.   }
  44. }
最终解码后的JPEG图片显示在板载的屏幕上的效果:
Amazingxixixi 发表于 2024-10-31 16:14 | 显示全部楼层
这个是硬件解码还是软件解码?
suncat0504 发表于 2024-10-31 17:18 | 显示全部楼层
JPEG是库支持的吗?还是自己移植过来的?
地瓜patch 发表于 2024-10-31 18:36 来自手机 | 显示全部楼层
这个数组是来占版面的,得交版面费
