| 函数名: kbhit 功  能: 检查当前按下的键
 用  法: int kbhit(void);
 程序例:
 #include <conio.h>
 int main(void)
 CPRIntf("Press any key to continue:");
 while (!kbhit()) /* do nothing */ ;
 cprintf("\r\nA key was pressed...\r\n");
 return 0;
 函数名: keep
 功  能: 退出并继续驻留
 用  法: void keep(int status, int size);
 程序例:
 /***NOTE:
 This is an interrupt service routine.  You
 can NOT compile this program with Test
 Stack Overflow turned on and get an
 executable file which will operate
 correctly.  Due to the nature of this
 function the formula used to compute
 the number of paragraphs may not
 necessarily work in all cases.  Use with
 care!  Terminate Stay Resident (TSR)
 programs are complex and no other support
 for them is provided.  Refer to the
 MS-DOS technical documentation
 for more information.  */
 #include <dos.h>
 /* The clock tick interrupt */
 #define INTR 0x1C
 /* Screen attribute (blue on grey) */
 #define ATTR 0x7900
 /* reduce heaplength and stacklength
 to make a smaller program in memory */
 extern unsigned _heaplen = 1024;
 extern unsigned _STKlen  = 512;
 void interrupt ( *oldhandler)(void);
 void interrupt handler(void)
 unsigned int (far *screen)[80];
 static int count;
 /* For a color screen the video memory
 is at B800:0000.  For a monochrome
 system use B000:000 */
 screen = MK_FP(0xB800,0);
 /* increase the counter and keep it
 within 0 to 9 */
 count++;
 count %= 10;
 /* put the number on the screen */
 screen[0][79] = count + '0' + ATTR;
 /* call the old interrupt handler */
 oldhandler();
 int main(void)
 /* get the address of the current clock
 tick interrupt */
 oldhandler = getvect(INTR);
 /* install the new interrupt handler */
 setvect(INTR, handler);
 /* _psp is the starting address of the
 program in memory.  The top of the stack
 is the end of the program.  Using _SS and
 _SP together we can get the end of the
 stack.  You may want to allow a bit of
 saftey space to insure that enough room
 is being allocated ie:
 (_SS + ((_SP + safety space)/16) - _psp)
 keep(0, (_SS + (_SP/16) - _psp));
 return 0;
