[方案相关] hc32l136 Lpuart发生异常
2510|6
 楼主| qihao74 发表于 2025-1-7 15:20 | 显示全部楼层 |阅读模式
当发送指令放置在接收中断时,一切正常。如果把发送中断移值主程序,偶尔就会出现发送指令不执行或延迟执行的现象
// 初始化Lpuart
void lpuart_init(void)
    uint16_t u16Scnt = 0;
    stc_gpio_config_t stcGpioCfg;
    stc_lpuart_sclk_sel_t stcSclk;
    stc_lpuart_config_t  stcConfig;
    stc_lpuart_irq_cb_t stcLPUartIrqCb;
    stc_lpuart_multimode_t stcMulti;
    stc_lpuart_baud_t stcBaud;
    DDL_ZERO_STRUCT(stcConfig);
    DDL_ZERO_STRUCT(stcLPUartIrqCb);
    DDL_ZERO_STRUCT(stcMulti);
    DDL_ZERO_STRUCT(stcBaud);
    DDL_ZERO_STRUCT(stcGpioCfg);
    DDL_ZERO_STRUCT(stcSclk);
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
    Sysctrl_SetPeripheralGate(SysctrlPeripheralLpUart1, TRUE);
    stcGpioCfg.enDir =  GpioDirOut;
    Gpio_Init(GpioPortA, GpioPin0, &stcGpioCfg); //TX
    stcGpioCfg.enDir =  GpioDirIn;
    stcGpioCfg.enPuPd = GpioPu;
    Gpio_Init(GpioPortA, GpioPin1, &stcGpioCfg); //RX
    Gpio_SetAfMode(GpioPortA, GpioPin0, GpioAf2);
    Gpio_SetAfMode(GpioPortA, GpioPin1, GpioAf2);
    stcLPUartIrqCb.pfnRxIrqCb   = LPUartRxIntCallback;
    stcLPUartIrqCb.pfnTxIrqCb   = NULL;
    stcLPUartIrqCb.pfnRxFEIrqCb = NULL;
    stcLPUartIrqCb.pfnPEIrqCb   = NULL;
    stcLPUartIrqCb.pfnCtsIrqCb  = NULL;
    stcConfig.pstcIrqCb = &stcLPUartIrqCb;
    stcConfig.bTouchNvic = TRUE;
    stcConfig.enStopBit = LPUart1bit;
    stcConfig.enRunMode = LPUartMode1;//
    stcSclk.enSclk_Prs = LPUart4Or8Div;
    stcSclk.enSclk_sel = LPUart_Rcl;
    stcConfig.pstcLpuart_clk = &stcSclk;
    stcMulti.enMulti_mode = LPUartNormal;
    stcConfig.pstcMultiMode = &stcMulti;
    LPUart_Init(LPUART1, &stcConfig);
    LPUart_SetClkDiv(LPUART1, LPUart4Or8Div);
    stcBaud.u32Sclk = LPUart_GetSclk(LPUART1);
    stcBaud.enRunMode = LPUartMode1;
    stcBaud.u32Baud = 9600;
    u16Scnt = LPUart_CalScnt(LPUART1, &stcBaud);
    LPUart_SetBaud(LPUART1, u16Scnt);
    LPUart_EnableIrq(LPUART1, LPUartRxIrq);
    LPUart_ClrStatus(LPUART1, LPUartRC);
    LPUart_EnableFunc(LPUART1, LPUartRx);
// LPUART 中断服务函数
void LPUartRxIntCallback(void)
    Uartbuff[UartRX_dp++] = LPUart_ReceiveData(LPUART1);;
    if(UartRX_dp >= 8)
        if( (Uartbuff[0] == PollAdd) || (Uartbuff[0] == 0) )
            if((Uartbuff[1] == 3) || (Uartbuff[1] == 6) || (Uartbuff[1] == 8))
                ISRcrc16 = ISRcal_crc16(Uartbuff, 6);
                if( (Uartbuff[6] == ((uint8_t)ISRcrc16)) && ( Uartbuff[7] == ((uint8_t)(ISRcrc16 >> 8))) )
                    //准备发送
                    UartHartrecok = 0x55;
                    if((Uartbuff[1] == 3) || (Uartbuff[1] == 6))
                        **.ReportSum** = 0;
                    //                                        Rxreal**=0;
                    UartRX_dp = 0;
                code16 = 0;
            else if(Uartbuff[1] == 0x10)
                if(UartRX_dp >= (Uartbuff[6] + 9))
                    ISRcrc16 = ISRcal_crc16(Uartbuff, Uartbuff[6] + 7);
                    if( (Uartbuff[Uartbuff[6] + 7] == ((uint8_t)ISRcrc16)) && ( Uartbuff[Uartbuff[6] + 8] == ((uint8_t)(ISRcrc16 >> 8))) )
                        //准备发送
                        **.ReportSum** = 0;
                        //                        Rxreal**=0;
                        UartRX_dp = 0;
                    code16 = 0;  //20220419
                else code16 = 0x55;                //未收完
            else code16 = 0;
        if( (UartHartrecok != 0x55) && (code16 != 0x55) )                                //数据不对,移除最旧的一个字节
            uint8_t i;
            for(i = 0; i < UartRX_dp - 1; i++)        Uartbuff = Uartbuff[i + 1];
            UartRX_dp -= 1;
        if(UartHartrecok == 0x55)
            MODBUSManagement();
// LPUART发送命令处理函数
void MODBUSManagement(void)
        uint8_t UartTX_cn;
        UartHartrecok = 0;
        UartTX_cn = Uart_rx_deal(Uartbuff);
        /*数据发送*/
        for(uint8_t i = 0; i < UartTX_cn; i++)
            LPUart_SendData(LPUART1, Uartbuff);
// 主函数
int32_t main(void)
    lpuart_init();
    初始化
while(1)
        Wdt_Feed();
        MODBUSManagement();
        if((!**.M50** || Resetdly > 0) && Ovmagdly == 0)
            //LCDLIB_PrintRSSI(4);//关闭信号强度显示
            stcConfig.enSLEEPDEEP   = SlpDpEnable;
            Lpm_Config(&stcConfig);
            Lpm_GotoLpmMode();
        else
            stcConfig.enSLEEPDEEP   = SlpDpDisable;
            Lpm_GotoLpmMode();
356053261 发表于 2025-1-13 11:58 | 显示全部楼层
没遇到过,用这颗芯片几年了,也用了Modbus通信,一切正常
356053261 发表于 2025-1-13 12:02 | 显示全部楼层
我是Uart接收中断里只做接收处理,当接收数据空闲时间大于2mS后判断为接收数据结束,再解析缓存里的数据,校验CRC等
地瓜patch 发表于 2025-1-21 21:20 | 显示全部楼层
这种问题最难找
申小林一号 发表于 2025-1-22 08:57 | 显示全部楼层
学习一下
一点点0321 发表于 2025-4-30 22:31 | 显示全部楼层
在主程序中执行发送操作时,可能会受到其他任务或中断的干扰,导致发送操作的延迟。
