-  //BSP_MMC_Init(0);
 -         BSP_LCD_Init(0, LCD_ORIENTATION_LANDSCAPE);
 -   UTIL_LCD_SetFuncDriver(&LCD_Driver);
 2、可以运行一些程序测试LCD驱动是否成功
- static void Display_DemoDescription(void)
 -   char desc[64];
 -   uint32_t x_size;
 -   uint32_t y_size;
-   UTIL_LCD_SetFont(&UTIL_LCD_DEFAULT_FONT);
-   /* Clear the LCD */
 -   UTIL_LCD_SetBackColor(UTIL_LCD_COLOR_WHITE);
 -   UTIL_LCD_Clear(UTIL_LCD_COLOR_WHITE);
-   /* Set the LCD Text Color */
 -   UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_DARKBLUE);
-   /* Display LCD messages */
 -   UTIL_LCD_DisplayStringAt(0, 10, (uint8_t *)"STM32H745I BSP", CENTER_MODE);
 -   UTIL_LCD_DisplayStringAt(0, 35, (uint8_t *)"Drivers examples", CENTER_MODE);
-   BSP_LCD_GetXSize(0, &x_size);
 -   BSP_LCD_GetYSize(0, &y_size);
-  BSP_LCD_FillRect(0, 0, y_size/2 - 15, x_size, 100, UTIL_LCD_COLOR_BLUE);
如果正常可以显示一些文字和图案
3、编写一些处理获取中文字模和显示中文的函数
先通过U盘功能将gb2312_80.bin字库文件拷贝到emmc中
读取字库文件获取一个汉字的32个字节字模函数:
- FRESULT ReadBinaryFile(const char* path, FSIZE_t ofs, uint8_t* buffer, uint32_t* bytesRead)
 -         FRESULT res;
 -         FIL MyFile;             /* File object */
 -         UINT br;            /* Bytes read */
 -         /* Register the file system object to the FatFs module */
 -   if(f_mount(&MMCFatFs, (TCHAR const*)MMCPath, 0) != FR_OK)
 -                 printf("f_mount error\r\n");
 -                 return res;
 -   /* open the file in read mode */
 -   res = f_open(&MyFile, path, FA_READ);
 -   if(res != FR_OK)
 -                 printf("f_open error\r\n");
 -                 return res;
 -         res = f_lseek(&MyFile,ofs);
 -   if(res != FR_OK)
 -                 printf("f_lseek error\r\n");
 -                 return res;
 -         /* Read the file */
 -         res = f_read(&MyFile, buffer, 32, &br);
 -         if (res != FR_OK) {
 -                         f_close(&MyFile); /* Close the file if an error occurs */
 -                         return res;
 -         *bytesRead = br;
 -         f_close(&MyFile);
 -         return FR_OK; /* Success */
 GB2312字库偏移量计算函数
- void get_hzk_bmp(uint8_t *gb2312)
 -         uint8_t gbh=0, gbl=0;
 -         uint32_t gbbl=0;
 -         uint32_t hzk_buf_size=0;
 -         gbh=gb2312[0];
 -         gbl=gb2312[1];
 -         //printf("%02X,%02X\r\n",gbh,gbl);
 -         if(gbh>=0xb0)
 -                         gbbl =((gbh - 0xa7) * 94 + (gbl - 0xa1))*32; // 根据偏移量计算公式计算偏移量
 -         else
 -                    gbbl =((gbh - 0xa1) * 94 + (gbl - 0xa1))*32; // 根据偏移量计算公式计算偏移量
 -         if(FR_OK==ReadBinaryFile(GB2312_BIN_FILE,gbbl,hzk_bmp,&hzk_buf_size))
 -                 printf("read:%d\r\n",hzk_buf_size);
 -                 for(int i=0;i<32;i++)
 -                         printf("%02x ",hzk_bmp[i]);
 -                 printf("\r\n");
 -                 //disp_hz_bmp(hzk_bmp);
 -         else{
 -                 printf("ReadBinaryFile error\r\n");
在LCD上显示汉字函数:
- uint8_t GUI_Write16CnCharMatrix(uint16_t x, uint16_t y, uint8_t *cn, uint32_t wordColor, uint32_t backColor)
 -   uint16_t i=0, j,mx,my,wordNum;
 -         uint8_t zm[2];
 -   uint8_t color;
 -         uint16_t cur_index=0,ascii_num=0;
 -         mx=x;
 -   my=y;
 -         while (*cn != '\0')
 -                 if(mx>=480){
 -             mx=x;
 -             my+=16;
 -                 if(*cn<128){
 -                         ascii_num++;
 -                         cur_index++;
 -                         UTIL_LCD_DisplayChar(mx,my,*cn);
 -                         cn += 1;
 -                 else
 -                         //if((cur_index==1018)&&(ascii_num%2==1)) return 1;
 -                         cur_index+=2;
 -                         zm[1]=cn[1];
 -                         zm[0]=cn[0];
 -                         get_hzk_bmp(zm);
-                         for(i=0; i<32; i++)
 -                         {   //MSK的位数
 -                                 color=hzk_bmp[i];
 -                                 //printf("%02X,",color);
 -                                 for(j=0;j<8;j++)
 -                                         if(i%2==0)
 -                                                 UTIL_LCD_FillRGBRect(mx+j,my+i/2,&color,8,1);
 -                                         }else
 -                                                 UTIL_LCD_FillRGBRect(mx+j+8,my+i/2,&color,8,1);
 -                                         if((color&0x80)==0x80)
 -                                                 if(i%2==0)
 -                                                         BSP_LCD_WritePixel(0,mx+j,my+i/2,wordColor);
 -                                                         //UTIL_LCD_SetPixel(mx+j,my+i/2,wordColor);
 -                                                 else{
 -                                                         BSP_LCD_WritePixel(0,mx+j+8,my+i/2,wordColor);
 -                                                         //UTIL_LCD_SetPixel(mx+j+8,my+i/2,wordColor);
 -                                         else
 -                                                 if(i%2==0){
 -                                                         BSP_LCD_WritePixel(0,mx+j,my+i/2,backColor);
 -                                                         //UTIL_LCD_SetPixel(mx+j,my+i/2,backColor);
 -                                                 else{
 -                                                         BSP_LCD_WritePixel(0,mx+j+8,my+i/2,backColor);
 -                                                         //UTIL_LCD_SetPixel(mx+j+8,my+i/2,backColor);
 -                                         color<<=1;
 -                                 }//for(j=0;j<8;j++)结束
 -                         //printf("\r\n");
 -                 cn += 2;
 -     mx += 16;
 -         return ascii_num%2;
 4、main文件
按键外部中断回调控制显示下一页:
- void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
 -   if (GPIO_Pin == GPIO_PIN_13)
 -                 cur_page++;
 -                 refresh_page=1;
while(1)
-  while (1)
 -     /* USER CODE END WHILE */
-     /* USER CODE BEGIN 3 */
-                 if(refresh_page==1)
 -                         refresh_page=0;
 -                         UTIL_LCD_Clear(UTIL_LCD_COLOR_BLACK);
 -                         UTIL_LCD_SetBackColor(UTIL_LCD_COLOR_BLACK);
 -                         FS_listDirectory();
 -                 HAL_Delay(500);
 -   /* USER CODE END 3 */
 FS_listDirectory文件名瞎起的和内容没关系,
主要的功能是打开文本文件wkz.TXT,在LCD上显示文件内容。
- static void FS_listDirectory(void)
 -         FRESULT res;
 -         DIR dir;
 -         FILINFO fno;
 -         uint32_t bytesread;
 -         uint16_t i;
 -         //printf("[Directory list]:\r\n");
 -   if(f_mount(&MMCFatFs, (TCHAR const*)MMCPath, 0) == FR_OK)
 -                         //printf("[mount MMC success]\r\n");
 -                         res = f_opendir(&dir, "/");
 -                         if (res == FR_OK)
 -                                 //printf("[open directory success]\r\n");
 -                                 printf("\r\n[list directory / files ......]:\r\n");
 -         for (;;) {
 -                                                 i++;
 -             res = f_readdir(&dir, &fno);
 -             if (res != FR_OK || fno.fname[0] == 0) break;
 -             if (fno.fname[0] == '.') continue;
 -                                         printFileInfo(&fno);
 -         f_closedir(&dir);
 -                                 if(f_open(&MyFile, "wkz.TXT", FA_READ) == FR_OK)
 -        /* Read data from the text file */
 -                                                 memset(wz_buff,0,sizeof(wz_buff));
 -                                                 f_lseek(&MyFile,byte_offset);
 -                                                 res = f_read(&MyFile, ( void *)wz_buff, 1020, (void *)&bytesread);
-                                                 if((bytesread > 0) && (res == FR_OK))
 -                                                         //printf("\r\n[Display wz_buff.TXT file content]:\r\n%s\r\n",rtewz_buffxt);
 -        /* Close the open text file */
 -        f_close(&MyFile);
 -                                                 wz_buff[1020]='\0';
 -                                 UTIL_LCD_SetFont(&Font16);
 -                                 next_align=GUI_Write16CnCharMatrix(0,0,wz_buff,UTIL_LCD_COLOR_GREEN,UTIL_LCD_COLOR_BLACK);
 -                                 byte_offset=byte_offset+1020-next_align;
三、总结
目前USB接入电脑后,U盘中的内容如下:
其中gb2312_80.bin是字库文件,wkz.txt是要显示内容的文本文件。
本文本质上是实现了读取wkz.txt内容,然后按照GB2312偏移计算公式在gb2312_80.bin找到字模,并在LCD上显示汉字。
