求助:GDA490 spi dma通讯求助(主从模式 两个单片机之前SPI)
1803|0
 楼主| sweet蜘蛛侠 发表于 2025-2-12 17:53 | 显示全部楼层 |阅读模式
SPI通讯收不到数据主机代码
#include "gd32a490.h"
#include "SPI.h"
#define SPI_CRC_ENABLE           0
#define ARRAYSIZE                16
uint16_t spi1_send_array[ARRAYSIZE] = {0};
uint16_t spi1_receive_array[ARRAYSIZE] = {0};;
extern uint16_t i2s1_rxbuffer[ARRAYSIZE];
void spi_rcu_config(void);
void spi_gpio_config(void);
void dma_config(void);
void spi_config(void);
void SPI_Init(void)
  /* configure RCU */
    spi_rcu_config();
    /* configure GPIO */
    dma_config();
    /* configure I2C */
    spi_config();
          dma_interrupt_enable(DMA1, DMA_CH3,DMA_CHXCTL_FTFIE);
    nvic_priority_group_set(NVIC_PRIGROUP_PRE0_SUB4);
    nvic_irq_enable(DMA1_Channel3_IRQn, 0, 1);
//    /* enable SPI DMA */
    spi_dma_enable(SPI4, SPI_DMA_RECEIVE);
    spi_dma_enable(SPI4, SPI_DMA_TRANSMIT);
  /* enbale I2S and I2S_ADD*/
    spi_enable(SPI4);
    dma_channel_enable(DMA1, DMA_CH4);
    dma_channel_enable(DMA1, DMA_CH3);
    rcu_periph_clock_enable(RCU_GPIOE);
    rcu_periph_clock_enable(RCU_DMA1);
    rcu_periph_clock_enable(RCU_SPI4);
    \brief      configure the GPIO peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    /* configure SPI1 GPIO */
    gpio_af_set(GPIOE, GPIO_AF_6,  GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14);
    gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14);
    gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14);
/* set SPI1_NSS as GPIO*/
    \brief      configure the DMA peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    dma_single_data_parameter_struct dma_init_struct;
    /* configure SPI1 transmit dma */
    dma_deinit(DMA1, DMA_CH4);
    dma_init_struct.periph_addr         = (uint32_t)&SPI_DATA(SPI4);
    dma_init_struct.memory0_addr        = (uint32_t)spi1_send_array;
    dma_init_struct.direction           = DMA_MEMORY_TO_PERIPH;
    dma_init_struct.periph_memory_width = DMA_PERIPH_WIDTH_16BIT;
    dma_init_struct.priority            = DMA_PRIORITY_LOW;
    dma_init_struct.number              = ARRAYSIZE;
    dma_init_struct.periph_inc          = DMA_PERIPH_INCREASE_DISABLE;
    dma_init_struct.memory_inc          = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.circular_mode       = DMA_CIRCULAR_MODE_DISABLE;
    dma_single_data_mode_init(DMA1, DMA_CH4, &dma_init_struct);
    dma_channel_subperipheral_select(DMA1, DMA_CH4, DMA_SUBPERI2);
    /* configure SPI1 receive dma */
    dma_deinit(DMA1, DMA_CH3);
    dma_init_struct.memory0_addr = (uint32_t)spi1_receive_array;
    dma_init_struct.direction    = DMA_PERIPH_TO_MEMORY;
    dma_init_struct.priority     = DMA_PRIORITY_HIGH;
    dma_single_data_mode_init(DMA1, DMA_CH3, &dma_init_struct);
    dma_channel_subperipheral_select(DMA1, DMA_CH3, DMA_SUBPERI2);
    \brief      configure the SPI peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    spi_parameter_struct spi_init_struct;
    spi_i2s_deinit(SPI4);
    /* configure SPI1 parameter */
    spi_init_struct.trans_mode           = SPI_TRANSMODE_FULLDUPLEX;
    spi_init_struct.device_mode          = SPI_MASTER;
    spi_init_struct.frame_size           = SPI_FRAMESIZE_16BIT;
    spi_init_struct.clock_polarity_phase = SPI_CK_PL_LOW_PH_1EDGE;
    spi_init_struct.nss                  = SPI_NSS_HARD;
    spi_init_struct.prescale             = SPI_PSC_16;
    spi_init_struct.endian               = SPI_ENDIAN_MSB;
    spi_init(SPI4, &spi_init_struct);
    spi_nss_output_enable(SPI4);
    spi_nss_internal_low(SPI4);
#if SPI_CRC_ENABLE
    /* configure SPI CRC function */
    spi_crc_polynomial_set(SPI1, 7);
    spi_crc_on(SPI1);
#endif /* enable CRC function */
从机代码
#include "SPI.h"
void SPI_Init(void)
  /* configure RCU */
    spi_rcu_config();
    dma_config();
    /* configure I2C */
    spi_config();
    spi_enable(SPI4);
//    rcu_periph_clock_enable(RCU_GPIOD);
    \param[in]  none
    \param[out] none
    \retval     none
    gpio_af_set(GPIOE, GPIO_AF_6,  GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_14|GPIO_PIN_13);
    gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_NONE  ,  GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_14|GPIO_PIN_13);
    gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,  GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_14|GPIO_PIN_13);
    \param[in]  none
    \param[out] none
    \retval     none
    dma_init_struct.circular_mode       = DMA_CIRCULAR_MODE_ENABLE;
    \param[in]  none
    \param[out] none
    \retval     none
    spi_init_struct.device_mode          = SPI_SLAVE;
#if SPI_CRC_ENABLE
    spi_crc_on(SPI1);
