[AVR单片机] T1的中断问题,请教各位了!!!急急
2535|3
 楼主| yaoji104 发表于 2007-3-27 14:45 | 显示全部楼层 |阅读模式
设计思路:我想用Mega64 T1的比较匹配中断,产生固定的定时间隔。比如1ms或是10ms。
设置T1的工作模式(WGMn3:0 = 4) 设置OCR1A = 2000;打开了匹配中断 TIMSK |= (1<<OCIE1A);附上源码
#include <iom64v.h>
#include <macros.h>
#pragma interrupt_handler isr_timer1:15
unsigned int  counter;
void main()
       counter   = 300;
      TCCR1B |= (1<<WGM12);
      OCR1A  = 2000;
      DDRB     = 0xF0;
      SEI();
      TCCR1B |= 1<<CS10;
      while(1);
void   isr_timer1()
      if(counter != 0)
       counter--;
    else
        counter = 300;
        PORTB ^= 1<<PB7;
但是接在PB7的LED并没有按照600ms闪烁一次。不知道是什么原因,还望高手指点。
kennyzhao 发表于 2007-4-3 14:01 | 显示全部楼层
回复
注意对定时器输入时钟的设置,CS12,CS11,CS10位,默认是没有CLOCK的
kennyzhao 发表于 2007-4-3 17:14 | 显示全部楼层
呵呵
刚看错了,
avrvi 发表于 2007-4-4 00:27 | 显示全部楼层
中断向量不对,程序也不明了
timer1_compa_isr:13
中断向量都没有搞对哦,好像。
//ICC-AVR application builder : 2007-4-4 0:44:06
// Target : M64
// Crystal: 4.0000Mhz
#include <iom64v.h>
#include <macros.h>
void port_init(void)
 PORTA = 0x00;
 DDRA  = 0x00;
 PORTB = 0x00;
 DDRB  = 0xF0;
 PORTC = 0x00; //m103 output only
 DDRC  = 0x00;
 PORTD = 0x00;
 DDRD  = 0x00;
 PORTE = 0x00;
 DDRE  = 0x00;
 PORTF = 0x00;
 DDRF  = 0x00;
 PORTG = 0x00;
 DDRG  = 0x00;
//TIMER1 initialize - prescale:256
// WGM: 0) Normal, TOP=0xFFFF
// desired value: 10mSec
// actual value:  9.984mSec (0.2%)
void timer1_init(void)
 TCCR1B = 0x00; //stop
 TCNT1H = 0xFF; //setup
 TCNT1L = 0x64;
 OCR1AH = 0x00;
 OCR1AL = 0x9C;
 OCR1BH = 0x00;
 OCR1BL = 0x9C;
 OCR1CH = 0x00;
 OCR1CL = 0x9C;
 ICR1H  = 0x00;
 ICR1L  = 0x9C;
 TCCR1A = 0x00;
 TCCR1B = 0x04; //start Timer
#pragma interrupt_handler timer1_compa_isr:13
void timer1_compa_isr(void)
 //compare occured TCNT1=OCR1A
//call this routine to initialize all peripherals
void init_devices(void)
 //stop errant interrupts until set up
 CLI(); //disable all interrupts
 XDIV  = 0x00; //xtal divider
 XMCRA = 0x00; //external memory
 port_init();
 timer1_init();
 MCUCR = 0x00;
 EICRA = 0x00; //extended ext ints
 EICRB = 0x00; //extended ext ints
 EIMSK = 0x00;
 TIMSK = 0x10; //timer interrupt sources
 ETIMSK = 0x00; //extended timer interrupt sources
 SEI(); //re-enable interrupts
 //all peripherals are now initialized
相关链接:http://www.avrvi.com/
