USART 外设的通信速率最高为 6Mbit/s,同时支持DMA传输方式。
USART驱动代码如下:
- /* 串口 */
- #define UART_INS (USART1)
- /* 接收数据大小 */
- #define UART_RX_LEN (512)
- /* 接收缓存 */
- uint8_t rx_buf[UART_RX_LEN];
- /* 接收长度 */
- uint16_t rx_len;
- /* 接收完成 */
- uint16_t rx_complete;
- /* 发送索引 */
- uint16_t tx_index;
- /* 发送长度 */
- uint16_t tx_len;
- /* 发送缓存 */
- uint8_t *tx_buf;
- * [url=/u/brief]@brief[/url] 初始化
- * @param None
- * @retval None
- void bsp_uart_init(void)
- GPIO_Config_T gpioConfig;
- USART_Config_T configStruct;
- DMA_Config_T dmaConfig;
- /* GPIO */
- RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_GPIOB);
- GPIO_ConfigStructInit(&gpioConfig);
- gpioConfig.pin = GPIO_PIN_6 | GPIO_PIN_7;
- gpioConfig.mode = GPIO_MODE_AF;
- gpioConfig.outtype = GPIO_OUT_TYPE_PP;
- gpioConfig.speed = GPIO_SPEED_50MHz;
- gpioConfig.pupd = GPIO_PUPD_NO;
- GPIO_Config(GPIOB, &gpioConfig);
- /* TX */
- GPIO_ConfigPinAF(GPIOB, GPIO_PIN_SOURCE_6, GPIO_AF_PIN0);
- /* RX */
- GPIO_ConfigPinAF(GPIOB, GPIO_PIN_SOURCE_7, GPIO_AF_PIN0);
- /* DMA */
- RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_DMA1);
- DMA_ConfigStructInit(&dmaConfig);
- /* DMA -> USART_RX */
- dmaConfig.direction = DMA_DIR_PERIPHERAL;
- dmaConfig.circular = DMA_CIRCULAR_DISABLE;
- dmaConfig.memoryTomemory = DMA_M2M_DISABLE;
- dmaConfig.priority = DMA_PRIORITY_LEVEL_LOW;
- dmaConfig.memoryInc = DMA_MEMORY_INC_ENABLE;
- dmaConfig.peripheralInc = DMA_PERIPHERAL_INC_DISABLE;
- dmaConfig.memoryDataSize = DMA_MEMORY_DATASIZE_BYTE;
- dmaConfig.peripheralDataSize = DMA_PERIPHERAL_DATASIZE_BYTE;
- dmaConfig.bufferSize = sizeof(rx_buf);
- dmaConfig.memoryAddress = (uint32_t)rx_buf;
- dmaConfig.peripheralAddress = (uint32_t)&UART_INS->RXDATA;
- DMA_Config(DMA1_CHANNEL_3, &dmaConfig);
- /* 传输完成中断 */
- DMA_EnableInterrupt(DMA1_CHANNEL_3, DMA_INT_TFIE);
- /* DMA -> USART_TX */
- dmaConfig.direction = DMA_DIR_MEMORY;
- dmaConfig.memoryAddress = 0;
- dmaConfig.peripheralAddress = (uint32_t)&UART_INS->TXDATA;
- DMA_Config(DMA1_CHANNEL_2, &dmaConfig);
- /* 传输完成中断 */
- DMA_EnableInterrupt(DMA1_CHANNEL_2, DMA_INT_TFIE);
- /* 使能中断 */
- NVIC_SetPriority(DMA1_CH2_3_IRQn, 0);
- NVIC_EnableIRQ(DMA1_CH2_3_IRQn);
- /* USART */
- RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_USART1);
- USART_Reset(UART_INS);
- USART_ConfigStructInit(&configStruct);
- configStruct.baudRate = 115200;
- configStruct.wordLength = USART_WORD_LEN_8B;
- configStruct.stopBits = USART_STOP_BIT_1;
- configStruct.parity = USART_PARITY_NONE ;
- configStruct.mode = USART_MODE_TX_RX;
- configStruct.hardwareFlowCtrl = USART_FLOW_CTRL_NONE;
- USART_Config(UART_INS, &configStruct);
- USART_EnableDMA(UART_INS, USART_DMA_REQUEST_RX);
- USART_EnableDMA(UART_INS, USART_DMA_REQUEST_TX);
- /* 使能空闲中断 */
- USART_EnableInterrupt(UART_INS, USART_INT_IDLEIE);
- /* 使能中断 */
- NVIC_SetPriority(USART1_IRQn, 0);
- NVIC_EnableIRQ(USART1_IRQn);
- /* 使能串口 */
- USART_Enable(UART_INS);
- /* 接收数据 */
- bsp_uart_recv();
- * @brief 串口中断
- * @param None
- * @retval None
- void USART1_IRQHandler(void)
- uint16_t num = 0;
- /* 空闲 */
- if (USART_ReadIntFlag(UART_INS, USART_INT_FLAG_IDLE) != RESET) {
- USART_ClearIntFlag(UART_INS, USART_INT_FLAG_IDLE);
- /* 计算已经传输的数据量 */
- num = sizeof(rx_buf) - DMA_ReadDataNumber(DMA1_CHANNEL_3);
- if (num != 0) {
- rx_len = num;
- rx_complete = 1;
- bsp_uart_recv();
