M79S-100M Low Noise Oscillator
Key Features
Ultra-low phase noise
Exceptional static and dynamic phase noise (-155dBc/Hz @1kHz static, -140 to -135dbc/Hz @1kHz dynamic)
Small size, 50.8 mm x 50.8mm x 13.8mm
Applications
Avionics
Radar
Satellite communications
Instrument systems
ATE test
Mechanical Specifications, (50.8 x50.8 X 13.8 mm)
Electrical & Environmental Specifications (25 °±3C, +3.3 VDC input unless otherwise specified)
PARAMETERS Unit Min Typ. Max Note Comments
RF Output
• Frequency MHz 100
• Amplitude dBm +7
Power Input
• DC Input V 5 ±5%
• Power Consumption
A 0.17
At 25 °C
• Warm up Power A 0.4
• Warm up Min 5 Refer to1 hr, 25C, 5min of operation ±1x10-7
Environmental
Operating
• Temperature
& Stability
ppb ±100
-40 °C to +85 °C
• Mechanical Shock Mil-STD-202, see dynamic phase noise
• Vibration
• Humidity
• Storage temperature
C
Mil-STD-202, method 201, see dynamic phase noise spec
MIL-STD-202, Method 103, condition A
-55 °C to +85 °C
Stability
• Acceleration Sensitivity
/g ±3x10-12 Worst direction.
• Aging (after 30days) /day ± 5x10-9
±0.5ppb
±300ppb/first year, after 30days
• Frequency Control
• Frequency vs Supply
ppm
ppb ±2
+/-10 0-10V
+/- 5%
Phase noise
Static Phase noise, max.
≤ -100 dBc / Hz @10Hz
≤ -130 dBc / Hz @100Hz
≤ -160 dBc / Hz @1kHz
≤ -171 dBc / Hz @10kHz
≤ -172 dBc / Hz @100kHz
Dynamic phase noise, 100M, Min. to Max., 25C, vibration profile, up to 0.4g^2
-99dBc/Hz to -95dBc/Hz @10Hz
-129dBc/Hz to -117dBc/Hz @100Hz
-150dBc/Hz to -137dBc/Hz @1kHz
-167dBc/Hz to -157dBc/Hz @10kHz
Order Information
M79S-100M
