| AVR新人求助! 我将CAN的接收和发送脚短接。
 主要TXOK置1就发,但发不出去。(TKOK一直为0)
 那位高手帮我看看,指点指点。谢谢!
 uchar num_channel;
 uchar num_data;
 *函数名:CANint
 *功能    :initialize AT90CAN32 CAN
 *参数    :non
 void CANint()
 {   //uchar num_channel;
 CANGCON   |= (1<<SWRES);            //reset CAN controller by software
 /* reset all mailboxes */
 for (num_channel = 0; num_channel < 15; num_channel++)
 CANPAGE  = num_channel << 4;
 CANCDMOB = CH_DISABLE;
 CANSTMOB  = 0;
 CANIDT1  = 0;
 CANIDT2  = 0;
 CANIDT3  = 0;
 CANIDT4  = 0;
 CANIDM1  = 0;
 CANIDM2  = 0;
 CANIDM3  = 0;
 CANIDM4  = 0;
 for (num_data = 0; num_data < 8; num_data++) CANMSG = 0;
 /* setup bit timing at 500k with 12 MHz crystal*/
 CANBT1  = 0x02;
 CANBT2  = 0x08;
 CANBT3  = 0x25;
 CANGCON |=  MSK_CANGCON_ENA;      //start CAN
 /* Channel 0: identifier = 11bits. CANIDT=0x123 */
 CANIDT1 = 0x24;
 CANIDT2 = 0x60;
 /* Channel 0: mask = 11bits. 0x7F0 */
 CANIDM1 = 0xFE;
 CANIDM2 &= ~0xE0;
 CANIDM4 = 0;
 /* Channel 0 configuration */
 CANIDT4 &=~0x04;                             /* clear bit rtr in CANIDT4. */
 CANCDMOB |= DLC_MAX;                         /* Reception 8 bytes.*/
 CANCDMOB |= CH_RxENA;                                     /* Reception enabled without buffer.*/
 /* Channel 1 init */
 CANPAGE = (1 << 4);                          /* CHNB=0x01; select channel 1 */
 CANSTMOB  = 0x00;                            /* reset channel status */
 CANCDMOB = CH_DISABLE;                       /* reset control and dlc register */
 /* Channel 1: identifier = 11bits. CANIDT=0x123 */
 CANIDT1 = 0x24;
 CANIDT2 = 0x60;
 /* Channel 1: mask = 11bits. 0x7F0 */
 CANIDM1 = 0xFE;
 CANIDM2 &= ~0xE0;
 CANIDM4 = 0;
 /* interrupt configuration */
 CANIE2 |= 0x09;                     //开MOB3 & MOB0信箱接收中断(接收邮箱)
 CANPAGE  = 0x00;
 CANCDMOB |= 0x80;                  //MOB0接收使能
 CANGIE |= ((1<<ENRX)|(1<<ENIT));              /* Can_Rx & IT enable */
 SIGNAL( CANIT_vect )
 {    //LEDtest = ~LEDtest;
 uchar rxnum_i;
 CANGIE &= ~(1<<ENRX);                  //关接收中断****
 CANPAGE = 0x00;                        //
 for(rxnum_i = 0; rxnum_i < 8; rxnum_i++)
 {   can_receivedata[rxnum_i]=CANMSG;       //取得8个字节的数据
 R_test = can_receivedata[rxnum_i];
 CANPAGE = 0x00;
 CANSTMOB &= ~(1<<RXOK);                //清中断标志****
 CANCDMOB = 0x98;                       //接收使能
 CANGIE |= (1<<ENRX);                   //开中断
 CanReceiveEndFlag=1;
 *函数名:CANTX
 *功能    :transmit data
 *参数    : non
 void CANTX()
 {   uchar txnum_i;
 CANPAGE = 0x10;
 if(CANSTMOB & (1 << TXOK))                         //need to transmit
 {   LEDtest = ~LEDtest;
 CANSTMOB &= ~(1 << TXOK);                     //clear transmit flag
 for(txnum_i = 0; txnum_i < 8; txnum_i ++)                        //send data
 {   CANMSG = can_transdata[txnum_i];
 CANCDMOB = 0x58;                                  //frame send
 CANGIE |=(1 << ENRX);                           //open intermit
