| #include<reg52.h> #include<intrins.h>
 #define nop  _nop_()
 #define uchar unsigned char
 #define uint unsigned int
 uchar k ;
 sbit ACC7= ACC^7;
 sbit ACC0= ACC^0;
 sbit rs=P3^5;//1602 引脚
 sbit wr=P3^6;
 sbit e=P3^4;
 sbit rst=P3^3;         //1302引脚
 sbit sclk=P3^2;
 sbit io=P2^4;
 uchar code table1[] = {0x00,0x00,0x00,0x05,0x00,0x00,0x00};
 uchar code week[][3] = {{"SUN"},{"MON"},{"TUE"},{"WED"},{"THU"},{"FRI"},{"SAT"}};
 uchar data line1[] = {"2012/07/30"};
 uchar   code table2[] = {"0123456789"};
 uchar data line2[] = {"00:00:00"};
 void lcd_busy_wait() //CD1602 忙等待
 rs = 0;
 wr = 1;
 e = 1;
 P0 = 0xff;
 while (P0&0x80);
 P0 = 0;
 void delay(uint z)   //延时函数
 uint x,y;
 for(x=z;x>0;x--)
 for(y=110;y>0;y--);
 void writecom(uchar b)
 lcd_busy_wait();
 rs=0;   //根据时序图
 wr=0;
 P0=b;
 delay(1);
 e=1;
 delay(1);
 e=0;
 void writedate(uchar b)
 rs=1;    //根据时序图
 wr=0;
 P0=b;
 delay(1);
 e=1;
 delay(1);
 e=0;
 void init()  //初始函数1602
 wr=0;      //写
 e=0;
 delay(15);
 writecom(0x38);   //设置16x2显示,5x7点阵,8位数据口
 delay(5);
 writecom(0x38);
 delay(5);
 writecom(0x38);
 delay(5);
 writecom(0x38);
 writecom(0x08);
 delay(5);
 writecom(0x0c);   //设置开显示,显光标,光标闪烁
 writecom(0x06);    // 写一个字符地址指针加1
 writecom(0x01);   //显示清0;数据指针清0
 void writebit(uchar q)//1302写一字节
 uchar i;
 ACC=q;
 for(i=8;i>0;i--)
 sclk=0;
 io=ACC0;
 sclk=1;
 ACC =ACC>>1;
 uchar readbit(void)//读一字节
 uchar i;
 for(i=8;i>0;i--)
 ACC7=io;
 sclk=0;
 ACC7=ACC>>1;
 sclk=1;
 return(ACC);
 /*uchar  readbit()//读一字节
 uchar i,date;
 delay(2);
 for(i=0;i>8;i++);
 date>>=1;
 if(io==1)
 date|=0x80;
 sclk=1;
 nop;
 nop;
 nop;
 sclk=0;
 delay(2);
 return(date);
 void writebit (uchar q)//写一字节
 uchar i,num;
 for(i=8;i>0;i--)
 sclk=1;
 nop;
 nop;
 nop;
 num=q;
 io=num&0x01;
 q>>=1;
 sclk=0;
 void write1302(uchar add,uchar date)//往1302写入数据
 rst=0;
 nop;
 sclk=0;
 nop;
 rst=1;
 nop;
 writebit(add);
 writebit(date);
 sclk=1;
 rst=0;
 uchar read1302(uchar add)//从1302读取数据
 uchar date;
 rst=0;
 nop;
 sclk=0;
 nop;
 rst=1;
 writebit(add);
 date=readbit();
 sclk=1;
 rst=0;
 return(date);
 void set1302(uchar *a)//1302初始化
 uchar i,add=0x80;
 write1302(0x8e,0x00);//禁止写 保护
 for(i=7;i>0;i--)
 write1302(add,*a);
 a++;
 add+=2;
 write1302(0x8e,0x80); //允许写保护
 void get1302(uchar table[])//将1302读取的数据存到数组中
 uchar i,ad=0x81;
 for(i=0;i<7;i++)
 table[i]=read1302(ad);
 ad+=2;
 void display()   //1602显示
 uchar a,i,j;
 wr=0;
 e=0;
 writecom(0x81);
 lcd_busy_wait();
 for(a=0;a<10;a++)
 writedate(line1[a]);
 delay(5);
 writecom(0x80+0x0c);
 lcd_busy_wait();
 for(i=0;i<3;i++)
 writedate(week[k][i]);
 delay(5);
 writecom(0x80+0x43);
 lcd_busy_wait();
 for(j=0;j<8;j++)
 writedate(line2[j]);
 delay(5);
 main()
 init() ;
 set1302(table1);
 while(1)
 get1302(table1);
 line1[2]=table2[table1[6]/0x10];
 line1[3]=table2[table1[6]%0x10];
 line1[5]=table2[table1[5]/0x10];
 line1[6]=table2[table1[5]%0x10];
 line1[8]=table2[table1[4]/0x10];
 line1[9]=table2[table1[4]%0x10];
 k=table2[table1[3]%0x10]-'0';
 line2[0]=table2[table1[2]/0x10];
 line2[1]=table2[table1[2]%0x10];
 line2[3]=table2[table1[1]/0x10];
 line2[4]=table2[table1[1]%0x10];
 line2[6]=table2[table1[0]/0x10];
 line2[7]=table2[table1[0]%0x10];
 display();
