Please follow the steps to use chart display:
1. Chart - Data Settings, we have 16 variables available here. Choose one of them. For example, N1 ACTIVE(Choose) status(Variable name, will be used in command) Byte(Type) Sign(Not Choose) (Choose Scale, Offset, Color)
then, click OK.
2. Commands: (See variable name "status" used here)
w 00 03 p r 00 @status p
3. Click "Repeat"(Send), and choose other parameters according to your application.
4. View the chart.
