| <br />#include "f2407regs.h"<br />#include <stdlib.h><br />#include <stdio.h><br />#include <ctype.h><br />#include <math.h><br />#include <string.h><br /><br />void inline disable(void)    /*可屏蔽中断禁止*/<br />{<br />  asm(" setc INTM ");<br />}<br /><br />void inline enable(void)     /*未屏蔽中断使能*/<br />{<br />  asm(" clrc INTM ");<br />}  <br /><br />void initial(void)<br />{<br />   asm (" clrc CNF");         /*b0被设置为数据存储空间*/<br />   asm (" clrc OVM ");        /*累加器中结果正常溢出*/<br />   asm (" setc SXM ");        /*符号扩展有效*/<br />   *SCSR1 = *SCSR1|0x0001;           /* EVA模块使能*/<br />   *WDCR=0x00e8;<br />   *IMR = *IMR|0X0002;                /*中断级INT2被使能,其它屏蔽*/<br />   *IFR = 0XFFFF;                /*清除中断标志*/<br />} <br /><br />void timerlint(void)<br />{ <br />  *EVAIFRA = *EVAIFRA|0X0080;            /*上溢中断标志复位*/<br />  *EVAIMRA = *EVAIMRA|0x0080;            /*上溢中断使能*/ <br />  *T1CON = 0X9005;              /*t1连续增计数,定时器禁止,内部时钟,不倍频,等于周期寄存器时重装载*/<br />  *T1CNT=0X00;<br />  *T1CMPR = 0X00FF;<br />  *T1PR =  0XFFFF;<br />}<br /><br />void bright(void)<br />{<br /> *MCRC = *MCRC & 0xbfff;                    <br /> *PFDATDIR = *PFDATDIR | 0x4040;<br />}<br /><br />void black(void)<br />{<br />  *MCRC = *MCRC & 0xbfff;      /*暗的小灯*/<br />  *PFDATDIR = *PFDATDIR | 0x4000;<br />  *PFDATDIR = *PFDATDIR & 0xffbf; <br />}<br /><br />void interrupt T1PINT()    /*上溢中断服务程序*/<br />{<br /> int flag,i;<br /> *T1CNT = 0X00;<br /> flag = *EVAIFRA & 0X0400;   /*检测上溢中断标志是否为一*/<br /> black();<br /> if (flag != 0x0400)         /*不为一*/<br />  {<br />   enable();                 /*开总中断*/<br />   return;  <br />  }<br /> *EVAIFRA = 0X0400;        /*复位上溢中断标志*/<br /> i++;<br /> bright();<br /> if(i==7)<br />   {i=0;<br />    bright();<br />   }<br /> return;<br />}<br /><br />void interrupt nothing()<br />{ <br />  enable(); <br />  return;<br />}<br /><br />void main(void)<br />{   <br />    disable();<br />    initial();<br />    timerlint();<br />    enable();<br />    *T1CON = *T1CON | 0X0040;   <br />    while(1) <br />    {<br />    ;<br />    }<br />}<br /> |
