经测试能用,只是SPI的方式, 供大家使用。
- -- VHDL SD card interface
- -- by Steven J. Merrifield, June 2008
- -- Reads and writes a single block of data, and also writes continuous data
- -- Tested on Xilinx Spartan 3 hardware, using Transcend and SanDisk Ultra II cards
- -- Read states are derived from the Apple II emulator by Stephen Edwards
- library ieee;
- use ieee.std_logic_1164.all;
- use ieee.numeric_std.all;
- entity sd_controller is
- port (
- cs : out std_logic;
- mosi : out std_logic;
- miso : in std_logic;
- sclk : out std_logic;
- rd : in std_logic;
- wr : in std_logic;
- dm_in : in std_logic; -- data mode, 0 = write continuously, 1 = write single block
- reset : in std_logic;
- din : in std_logic_vector(7 downto 0);
- dout : out std_logic_vector(7 downto 0);
- clk : in std_logic -- twice the SPI clk
- end sd_controller;
- architecture rtl of sd_controller is
- type states is (
- RST,
- INIT,
- CMD0,
- CMD55,
- CMD41,
- POLL_CMD,
- IDLE, -- wait for read or write pulse
- READ_BLOCK,
- READ_BLOCK_WAIT,
- READ_BLOCK_DATA,
- READ_BLOCK_CRC,
- SEND_CMD,
- RECEIVE_BYTE_WAIT,
- RECEIVE_BYTE,
- WRITE_BLOCK_CMD,
- WRITE_BLOCK_INIT, -- initialise write command
- WRITE_BLOCK_DATA, -- loop through all data bytes
- WRITE_BLOCK_BYTE, -- send one byte
- WRITE_BLOCK_WAIT -- wait until not busy
- -- one start byte, plus 512 bytes of data, plus two FF end bytes (CRC)
- constant WRITE_DATA_SIZE : integer := 515;
- signal state, return_state : states;
- signal sclk_sig : std_logic := '0';
- signal cmd_out : std_logic_vector(55 downto 0);
- signal recv_data : std_logic_vector(7 downto 0);
- signal address : std_logic_vector(31 downto 0);
- signal cmd_mode : std_logic := '1';
- signal data_mode : std_logic := '1';
- signal response_mode : std_logic := '1';
- signal data_sig : std_logic_vector(7 downto 0) := x"00";
- begin
- process(clk,reset)
- variable byte_counter : integer range 0 to WRITE_DATA_SIZE;
- variable bit_counter : integer range 0 to 160;
- begin
- data_mode <= dm_in;
- if rising_edge(clk) then
- if (reset='1') then
- state <= RST;
- sclk_sig <= '0';
- else
- case state is
- when RST =>
- sclk_sig <= '0';
- cmd_out <= (others => '1');
- address <= x"00000000";
- byte_counter := 0;
- cmd_mode <= '1'; -- 0=data, 1=command
- response_mode <= '1'; -- 0=data, 1=command
- bit_counter := 160;
- cs <= '1';
- state <= INIT;
- when INIT => -- CS=1, send 80 clocks, CS=0
- if (bit_counter = 0) then
- cs <= '0';
- state <= CMD0;
- else
- bit_counter := bit_counter - 1;
- sclk_sig <= not sclk_sig;
- end if;
- when CMD0 =>
- cmd_out <= x"FF400000000095";
- bit_counter := 55;
- return_state <= CMD55;
- state <= SEND_CMD;
- when CMD55 =>
- cmd_out <= x"FF770000000001"; -- 55d OR 40h = 77h
- return_state <= CMD41;
- when CMD41 =>
- cmd_out <= x"FF690000000001"; -- 41d OR 40h = 69h
- return_state <= POLL_CMD;
- when POLL_CMD =>
- if (recv_data(0) = '0') then
- state <= IDLE;
- else
- state <= CMD55;
- end if;
- when IDLE =>
- if (rd = '1') then
- state <= READ_BLOCK;
- elsif (wr='1') then
- state <= WRITE_BLOCK_CMD;
- else
- state <= IDLE;
- end if;
- when READ_BLOCK =>
- cmd_out <= x"FF" & x"51" & address & x"FF";
- return_state <= READ_BLOCK_WAIT;
- when READ_BLOCK_WAIT =>
- if (sclk_sig='1' and miso='0') then
- state <= READ_BLOCK_DATA;
- byte_counter := 511;
- bit_counter := 7;
- return_state <= READ_BLOCK_DATA;
- state <= RECEIVE_BYTE;
- end if;
- when READ_BLOCK_DATA =>
- if (byte_counter = 0) then
- bit_counter := 7;
- return_state <= READ_BLOCK_CRC;
- else
- byte_counter := byte_counter - 1;
- bit_counter := 7;
- end if;
- when READ_BLOCK_CRC =>
- bit_counter := 7;
- return_state <= IDLE;
- address <= std_logic_vector(unsigned(address) + x"200");
- when SEND_CMD =>
- if (sclk_sig = '1') then
- state <= RECEIVE_BYTE_WAIT;
- else
- cmd_out <= cmd_out(54 downto 0) & '1';
- end if;
- end if;
- when RECEIVE_BYTE_WAIT =>
- if (miso = '0') then
- recv_data <= (others => '0');
- if (response_mode='0') then
- bit_counter := 3; -- already read bits 7..4
- else
- bit_counter := 6; -- already read bit 7
- end if;
- end if;
- end if;
- when RECEIVE_BYTE =>
- recv_data <= recv_data(6 downto 0) & miso;
- state <= return_state;
- dout <= recv_data(6 downto 0) & miso;
- else
- end if;
- end if;
- when WRITE_BLOCK_CMD =>
- cmd_mode <= '1';
- if (data_mode = '0') then
- cmd_out <= x"FF" & x"59" & address & x"FF"; -- continuous
- else
- cmd_out <= x"FF" & x"58" & address & x"FF"; -- single block
- end if;
- return_state <= WRITE_BLOCK_INIT;
- when WRITE_BLOCK_INIT =>
- cmd_mode <= '0';
- byte_counter := WRITE_DATA_SIZE;
- state <= WRITE_BLOCK_DATA;
- when WRITE_BLOCK_DATA =>
- if byte_counter = 0 then
- return_state <= WRITE_BLOCK_WAIT;
- response_mode <= '0';
- else
- if ((byte_counter = 2) or (byte_counter = 1)) then
- data_sig <= x"FF"; -- two CRC bytes
- elsif byte_counter = WRITE_DATA_SIZE then
- if (data_mode='0') then
- data_sig <= x"FC"; -- start byte, multiple blocks
- else
- data_sig <= x"FE"; -- start byte, single block
- end if;
- else
- -- just a counter, get real data here
- data_sig <= std_logic_vector(to_unsigned(byte_counter,8));
- end if;
- bit_counter := 7;
- state <= WRITE_BLOCK_BYTE;
- end if;
- when WRITE_BLOCK_BYTE =>
- if bit_counter=0 then
- else
- data_sig <= data_sig(6 downto 0) & '1';
- end if;
- end if;
- when WRITE_BLOCK_WAIT =>
- if sclk_sig='1' then
- if MISO='1' then
- state <= WRITE_BLOCK_INIT;
- else
- state <= IDLE;
- end if;
- end if;
- end if;
- when others => state <= IDLE;
- end case;
- end if;
- end if;
- end process;
- sclk <= sclk_sig;
- mosi <= cmd_out(55) when cmd_mode='1' else data_sig(7);
- end rtl;
