在CCS下load program时,偶尔出现下面的提示:<br /><br />Data verification failed at address 0x80.<br />Please verify target memory and memory map.<br /><br />这是什么原因?<br /><br />下面的两个错误提示:<br /><br />Trouble Writing Register:<br />Error 0x80001024/-1058<br />Fatal Error during: Register, Execution, Target, <br />Device driver: Emulator Controller not responding<br />It is recommended to RESET EMULATOR. This will disconnect each <br />target from the emulator. The targets should then be power cycled<br />or hard reset followed by an emureset and reconnect to each target.<br /><br />和<br />程序运行时halt出现的提示:<br /><br />Trouble Halting Target CPU:<br />Error 0x80001020/-1058<br />Fatal Error during: Execution, Target, <br />Device driver: Emulator Controller not responding<br />It is recommended to RESET EMULATOR. This will disconnect each <br />target from the emulator. The targets should then be power cycled<br />or hard reset followed by an emureset and reconnect to each target.<br /><br />是什么原因造成的?<br /><br />谢谢! |
