三星单片机主程序只跑一次就停了,why?
2805|7
 楼主| fenaniu 发表于 2012-9-3 11:21 | 显示全部楼层 |阅读模式
.public         main
        .public         start
        .include         "S3C8275.reg"
;//==============define symbol==============
page0to0          equ    00h
page1to1          equ    11h
page0to2          equ    20h
page1to2          equ    21h
page2to0          equ    02h
powerkey          equ    0fah   ;;//
; ==================intterupt define=====================
;;       vector 00f6h, watch_timer_int   ;// irq2 watch timer vector
        org    0100h
         jp     start
;;//=============reset===================================
start:
        nop
        nop
        ld     spl,# 0ffh
        call   init_hardware
;//=========main program=================================
       org     200h
main:
        sb0
  ;     ld     p4,#0ffh
        ld     r0,#0
        ld     r1,#1
        ldb    p0.3,r0
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        ldb    p0.3,r1
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        call   delay
        jp     main
;;//=================================================sub
init_hardware:
        di
;//------------chen xu chu shi hua
        ld     btcon,# 10100011b  ;//disable WATCH DOG
        ld     clkcon,# 00011000b ;fxx
        ld     imr,#00000101b    ;.3bit external inter(P0.0) ;.2bit  watchtime ;.0bit Timer1
        ld     sym,# 01h
        ld     pp,# page0to0
;//------------sb0------------------------------------
        sb0
        ld     osccon,# 04h  ;//main oscillator select
        ld     stpcon,# 10100101b
        ld     p0conh,# 00000010b
        ld     p0conl,# 10101010b
        ld     p0pur,# 0ffh
         ld     p0,# 0ffh
   ;     ld     p1conh,# 00h
   ;     ld     p1conl,# 00h
  ;      ld     p1,# 0ffh
   ;     ld     p1pur,# 0ffh
;        ld     p2conh,# 00h
;        ld     p2conl,# 00h
  ;      ld     p2pur,# 0ffh
;        ld     p3conl,# 00h
;        ld     p3conh,# 00h
   ;     ld     p3,# 7fh
;        ld     p3pur,# 0ffh
;        ld     extipnd,# 00h     ;//清除中断标志位
;        ld     exticonh,# 00h
;        ld     exticonl,#00000001b  ;p00 set falling edge into inter
;//------------sb1--------------------------
        sb1
        ld     wtcon,# 01001110b    ;;//0.91ms 中断;
;        ld     tadata,# 0ffh
;        ld     tbdata,# 0ffh
        ld     tacon,# 10111110b    ;set fxx/8
  ;      ld     p4conh,# 0aah
  ;      ld     p4conl,# 10101010b
;        ld     p4,#0ffh
;        ld     p5conh,# 10101010b
;        ld     p5conl,# 10101010b
;        ld     p5,00h
;        ld     p6con,# 000h
;       ld     lcon,# 01100001b
;//------------clear ram------------------------
        sb0
        ld     pp,#page0to0
   ;     call   rampage0clr
        ei
         ret
;//================delay================================
delay:
push
pp
push
r0
ld
pp,#00h
                ld      r0,#16-3
d50:
nop
djnz
r0,d50
pop
r0
pop
pp
                ret
        END
 楼主| fenaniu 发表于 2012-9-3 11:25 | 显示全部楼层
有谁用过三星827x系列的单片机?上面程序main只跑一次就没反应了。程序的功能是实现p0.3口灯的闪烁,现在灯只亮一次就灭了再无反应。p0.3=1时灯灭,0时亮
Ryanhsiung 发表于 2012-9-3 17:13 | 显示全部楼层
你的程序有问题!!!!!!!!!!!
  请检查程序
hp34401a 发表于 2012-9-3 18:14 | 显示全部楼层
不懂汇编(X86的反而会),不懂3*, 帮顶吧。
Dick00 发表于 2012-9-3 18:20 | 显示全部楼层
额,完全不懂,大学就单片机挂了,帮顶下
ningling_21 发表于 2012-9-3 21:13 | 显示全部楼层
用仿真器调试运行,看看程序到底跑到哪里去了...
阿南 发表于 2012-9-4 09:48 | 显示全部楼层
看程序,很大原因是产生中断了而没有相应的处理代码。
zhang7676050 发表于 2012-9-5 11:32 | 显示全部楼层
估计是中断里的程序没有处理好   汇编好久没有用过了
