LPC2119的IO模拟I2C读写PCF8563问题
2694|3
 楼主| gghhz 发表于 2012-9-6 17:09 | 显示全部楼层 |阅读模式
大侠帮忙看一下啊。读出来的数据不对,写进去的数据可能也不对,因为中断不动作
启动I2C
void I2CStart(void)
DATAHIG;
SCLRSET;
Delay_Us(60);
DATALOW;
Delay_Us(60);
SCLRCLR;
Delay_Us(60);
停止I2C
void I2CStop(void)
DATALOW;
SCLRCLR;
Delay_Us(60);
SCLRSET;
Delay_Us(60);
DATAHIG;
Delay_Us(60);
写1
void WriteHigh(void)
DATAHIG;
SCLRSET;
Delay_Us(60);
SCLRCLR;
Delay_Us(60);
写0
void WriteLow(void)
DATALOW;
SCLRSET;
Delay_Us(60);
SCLRCLR;
Delay_Us(60);
写一个字节
void WriteOneByte(uint8 Data)
uint8 i;
for(i=0;i<8;i++)
     if((Data<<8)&0x80)
         WriteHigh();
     else
         WriteLow();
写多个字节
void WriteNByte(uint8 *Data,uint8 WriteLength)
uint8 i;
I2CStart();
for(i=0;i<WriteLength;i++)
     WriteOneByte(Data[i]);
I2CStop();
连续写入
void WritePCF8563(uint8 WriteData,uint8 WriteAddr)
//uint8 i;
uint8 WriteBuf[4];
WriteBuf[0] = 0xa2;
WriteBuf[1] = WriteAddr;
WriteBuf[2] = WriteData;
WriteNByte(WriteBuf,3);
写一个字节
void WriteByte(uint8 Data)
uint8 i;
for(i=0;i<8;i++)
     if((Data<<i)&0x80)
         WriteHigh();
     else
         WriteLow();
void WriteNoACK(void)
DATAHIG;
Delay_Us(60);
SCLRSET;
Delay_Us(60);
SCLRCLR;
void WaitACK(void)
uint8 c_ErrTime = 20;
DATAHIG;
Delay_Us(60);
SCLRSET;
Delay_Us(60);
while((1<<3)==(IO0PIN&(1<<3)))
       c_ErrTime--;
       if(!c_ErrTime)I2CStop();
SCLRCLR;
Delay_Us(60);
读一个字节
uint8 ReadByte(void)
uint8 i;
uint8 ReadData;
DATAIN;
for(i=0;i<8;i++)
     SCLRSET;
     if((1<<3)==(IO0PIN&(1<<3)))
        ReadData<<=1;
        ReadData |= 1;
     else
        ReadData<<=1;
     SCLRCLR;
     Delay_Us(60);
DATAOUT;
return ReadData;
读多个字节
uint8 ReadData(uint8 ReadAddr)
//uint8 i;
uint8 ReadData;
I2CStart();
WriteByte(0xa2);
WriteByte(ReadAddr);
//Delay_Us(1);
I2CStart();
WriteByte(0xa3);
//Delay_Us(1);
ReadData = ReadByte();
WaitACK();
WriteNoACK();
I2CStop();
return ReadData;
初始化PCF8563
uint8 PCF8563Init(void)
DATAOUT;
SCLRDIR;
WritePCF8563(0x08,0x0a);
WritePCF8563(0x12,0x01);
WritePCF8563(0x12,0x02);
WritePCF8563(0x82,0x0e);
WritePCF8563(0x0a,0x0f);
WritePCF8563(0x00,0x00);
WritePCF8563(0x11,0x01);
return 1;
阿南 发表于 2012-9-6 18:08 | 显示全部楼层
中断不能产生,不一定是IIC的问题,也有可能是中断设置的问题。
楼主先思考如何确定读正确。
PCF8563,ZLG应该用测试代码呀。
 楼主| gghhz 发表于 2012-9-7 08:59 | 显示全部楼层
回复2楼:读出来的时间应该是BCD码,但是现在读出来的不是,应答信号也不知道该怎么处理。
周立功的测试代码用的是I2C的功能块儿,不是IO模拟的I2C。
阿南 发表于 2012-9-7 09:47 | 显示全部楼层
你可以先用测试代码,测试器件和接口本身没有问题,然后再调试你的程序,思路应该会更清晰。
