| 源码: #include <linux/module.h>
 #include <linux/kernel.h>
 #include <linux/fs.h>
 #include <linux/init.h>
 #define DEVICE_NAME "myfrisr_dev_hello"
 #define HELLO_MAJOR 45
 static int myfrist_dev_open(struct inode *inode,struct file *file)
 printk("come here I am here \n");
 printk("");
 return 0;
 static ssize_t myfrist_dev_write(struct file *file,const char __user *buf,size_t count, loff_t *ppos)
 printk("i will go ,thank you \n");
 return 0;
 static struct file_operations myfrist_dev_fops={
 .owner = THIS_MODULE,
 .open = myfrist_dev_open,
 .write = myfrist_dev_write,
 static int __init myfrist_dev_hello_init(void)
 int ret;
 ret = register_chrdev(HELLO_MAJOR,DEVICE_NAME,&myfrist_dev_fops );
 if(ret<0)
 printk(DEVICE_NAME "canot register major number");
 return ret;
 printk(DEVICE_NAME"init yes \n");
 return 0;
 static void __exit myfrist_dev_hello_exit(void)
 unregister_chrdev(HELLO_MAJOR,DEVICE_NAME);
 module_init(myfrist_dev_hello_init);
 module_exit(myfrist_dev_hello_exit);
 MODULE_LICENSE("GPL");
 自己写了一个Makefile
 NEL_DIR=/home/a123/lx/linux-2.6.30.4/
 all:
 make -C $(NEL_DIR) M=$(pwd) modules
 obj-m   += frist_driver_hello.o
 clean:
 rm -rf *.bak *.mod* *or* *.sym* *.ko *.o
 但make后
 出现如下:
 [email=root@a123-virtual-machine:/mnt/hgfs/Win/ARMEXP/frist_driver_hello]root@a123-virtual-machine:/mnt/hgfs/Win/ARMEXP/frist_driver_hello[/email]# make
 make -C /home/a123/lx/linux-2.6.30.4/ M= modules
 make[1]: Entering directory `/home/a123/lx/linux-2.6.30.4'
 CHK     include/linux/version.h
 make[2]: `include/asm-arm/mach-types.h' is up to date.
 CHK     include/linux/utsrelease.h
 SYMLINK include/asm -> include/asm-arm
 CALL    scripts/checksyscalls.sh
 <stdin>:1097:2: warning: #warning syscall fadvise64 not implemented
 <stdin>:1265:2: warning: #warning syscall migrate_pages not implemented
 <stdin>:1321:2: warning: #warning syscall pselect6 not implemented
 <stdin>:1325:2: warning: #warning syscall ppoll not implemented
 <stdin>:1365:2: warning: #warning syscall epoll_pwait not implemented
 Building modules, stage 2.
 MODPOST 413 modules
 make[1]: Leaving directory `/home/a123/lx/linux-2.6.30.4'
 并没有编译出想要的.ko文件,
 然后我使用 make -C /home/a123/lx/linux-2.6.30.4/ M=$(pwd) modules却能编译出.ko文件,这是为什么,请大侠指点一下吧 我郁闷一天啦
