使用STM32F207Z处理器,在keil4里建立工程,使用的是STM32F2xx_StdPeriph_Lib_V1.0.0固件函数库。编写的是最简单的串口程序。在keil4里编译没有问题,将.hex文件烧写进开发板,竟然没有现象?请问怎么回事?
usart.c:
#include "usart.h"
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
void Usart_Config(void)
USART_InitTypeDef USART_InitStructure;
/* typedef struct
u32 USART_BaudRate; 波特率
u16 USART_WordLength; 一个帧中传输或者接收到的数据位数
u16 USART_StopBits; 停止位数目
u16 USART_Parity; 奇偶模式
u16 USART_HardwareFlowControl; 硬件流控制模式
u16 USART_Mode; 使能或者失能发送和接收模式
u16 USART_Clock; USART时钟使能或者失能
u16 USART_CPOL; 指定SLCK引脚上时钟输出的极性
u16 USART_CPHA; 指定了SLCK引脚上时钟输出的相位
u16 USART_LastBit; 控制是否在同步模式下,在SCLK引脚上输出的最后发送的那个数据字(MSB)对应的时钟脉冲
} USART_InitTypeDef;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); //配置GPIOA和USART2时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
/*配置串口2的TX*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //最高输出速率50MHz
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //AF复用
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //PP推挽式
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOA, &GPIO_InitStructure); // void GPIO_Init(GPIO_TypeDef *GPIOx, GPIO_InitTypeDef *GPIO_InitStruct)
/*配置串口2的RX*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; //OD Open-Drain 开漏
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
/*配置串口2的模式*/
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure); // void USART_Init(USART_TypeDef *USARTx,)
USART_Cmd(USART1, ENABLE); // void USART_Cmd(USART_TypeDef *USARTx, FunctionalState NewState)
main.c :
#include "stm32f2xx.h"
#include "usart.h"
int main(void)
SystemInit(); /*配置系统时钟为120M*/
Usart_Config(); /*配置串口*/
while (1)
printf("test gprs\n");
