安装XILINX Floating License
4913|9
 楼主| GoldSunMonkey 发表于 2012-11-2 14:44 | 显示全部楼层 |阅读模式
英文资料供参考。
Floating License Installation on Servers
For existing FLEXnet license servers, a common practice is to copy the contents of the
license file into the existing license file
on your FLEXnet server.
Note: Restart the floating license server to enable the Xilinx licenses.
For New License Servers
1. Got the license.
2. Unzip these utilities into a destination directory. Xilinx recommends you place this
directory into your application search path.
3. Once the FLEXnet utilities are installed, run the following commands to start the floating
license server:
Linux
- <Server Tool directory>/bin/lin/lmgrd -c <path_to_license>/Xilinx.lic -l
<path_to_license>/log1.log
- <Server Tool directory> bin/lin64/lmgrd -c <path_to_license>/Xilinx.lic -l
° Windows
- < Server Tool directory>\bin\nt\lmgrd -c <path_to_license>\Xilinx.lic –l
<path_to_license>\log1.log
- < Server Tool directory>\bin\nt64\lmgrd -c <path_to_license>\Xilinx.lic –l
Client Machines Pointing to a Floating License
1. Run the Xilinx License Configuration Manager (XLCM).
2. Click the Manage Xilinx Licenses tab.
3. On the Manage Xilinx Licenses tab, enter the network path to the license server in the
port@server format into the XILINXD_LICENSE_FILE field. Click Set. The default Xilinx
port number is 2100.
4. For Linux operating systems, licensing environment variables cannot be set using the
Xilinx License Configuration Manager (XLCM). The environment variable fields are read
only, and they are grayed out and there are no Set buttons. The environment variable
must be set using the appropriate shell and commands
forgot 发表于 2012-11-2 18:08 | 显示全部楼层
这谁能静下心来看啊,O(∩_∩)O哈哈~
lxAPP 发表于 2012-11-4 20:10 | 显示全部楼层
必须能,顶猴哥
wmsk 发表于 2012-11-4 20:11 | 显示全部楼层
V5~拿板凳做看版主吵架。
xiao6666 发表于 2012-11-4 20:14 | 显示全部楼层
luyaoss 发表于 2012-11-13 21:54 | 显示全部楼层
顶猴哥
forgot 发表于 2012-11-14 10:34 | 显示全部楼层
V5~拿板凳做看版主吵架。
你家伙好坏:lol
 楼主| GoldSunMonkey 发表于 2012-11-14 18:54 | 显示全部楼层
F哥,你能不能好好搞搞EDA版啊。
 楼主| GoldSunMonkey 发表于 2012-11-15 21:05 | 显示全部楼层
个人签名:                     2014, 追逐梦想
264
