CCS仿真时的一个问题。愁死了,有眼熟的发表下意见
1908|2
 楼主| 飞天猪run 发表于 2012-11-9 16:27 | 显示全部楼层 |阅读模式
Trouble Reading Memory Block at 0xc0000000 on Page 0 of Length 0x200:
Error 0x00000006/-1060
Error during: Memory, Register,
An unknown error prevented the emulator from accessing the processor
in a timely fashion.
It is recommended to RESET EMULATOR.
This will disconnect each
target from the emulator.
The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
Sequence ID: 70
Error Code: -1060
Error Class: 0x00000006
 楼主| 飞天猪run 发表于 2012-12-5 10:13 | 显示全部楼层
oxC0000000的地址范围属于CE space,忘记给时钟了,所以访问不到属于正常现象~结贴了
拿起书本 发表于 2012-12-5 11:00 | 显示全部楼层
应当细心地观察,为的是理解;应当努力地理解,为的是行动
