每日翻译——电子工程师datasheet description
4484|12
 楼主| tee. 发表于 2012-12-3 17:30 | 显示全部楼层 |阅读模式
DESCRIPTION
The LM124/SA534/LM2902 series consists of four independent,
high-gain, internally frequency-compensated operational amplifiers
designed specifically to operate from a single power supply over a
wide range of voltages.
UNIQUE FEATURES
In the linear mode, the input common-mode voltage range includes
ground and the output voltage can also swing to ground, even
though operated from only a single power supply voltage.
The unity gain crossover frequency and the input bias current are
temperature-compensated.
FEATURES
*Internally frequency-compensated for unity gain
*Large DC voltage gain: 100dB
*Wide bandwidth (unity gain): 1MHz (temperature-compensated)
*Wide power supply range Single supply: 3VDC to 30VDC or dual
supplies: ±1.5VDC to ±15VDC
*Very low supply current drain: essentially independent of supply
voltage (1mW/op amp at +5V )
DC
*Low input biasing current: 45nADC (temperature-compensated)
*Low input offset voltage: 2mVDC and offset current: 5nADC
*Differential input voltage range equal to the power supply voltage
*Large output voltage: 0VDC to VCC-1.5VDC swing
Ryanhsiung 发表于 2012-12-4 08:26 | 显示全部楼层
看我翻的对不对。
DESCRIPTION   描述:
LM124/SA534/LM2902 系列由4个独立、高增溢、内部频率补偿运算放大器,特殊设计 由一个(宽电压)单电源供电。
UNIQUE FEATURES  特别的特性:
在线性模式,输入的共模电压范围包括GND,还有其输出电压能够摆动到GND,及时操作只有一个单电源供电时,这个单元的增溢交差频率和输入偏置电流具有温度补偿。
FEATURES 特性:
单元增溢的内部频率补尝
很大的DC电压增溢:100DB
完带宽(电元增溢):1MHZ(温度补尝)
单电源 宽电压供电:3VDC to 30VDC or 双电源供电
双电源供电范围:±1.5VDC to ±15VDC
非常小的电源损耗:——————————翻译不出来
电压(1mW/运放 比较器 在 +5V )——这一句也不懂 ,翻译不出来
DC DC特性
低输入偏置电压:45nADC(温度补尝)
低输入偏移压: 2mVDC 与偏移电源: 5nADC
差分输入电压范围等于电源输入范围。
大电压输出范围: 0VDC to VCC-1.5VDC 摆动
借助GOOGLE翻译,不懂的GOOGLE,还翻不出来,太差了。
nice  发表于 2012-12-7 16:29
uet_cache 发表于 2012-12-9 19:11 | 显示全部楼层
Ryanhsiung 发表于 2012-12-10 21:21 | 显示全部楼层
FlexiHash™ For Battery Authentication
The ISL6296A is a highly cost-effective fixed-secret hash
engine based on Intersil’s FlexiHash technology. The
device’s authentication is achieved through a challenge
response scheme, which is customized for low-cost
applications where cloning via eavesdropping without
knowledge of the device’s secret code is not economically
viable. When used for its intended applications, the
ISL6296A offers the same level of effectiveness as other
significantly more expensive high maintenance monetarygrade
hash algorithm and authentication schemes.
The ISL6296A has a wide operating voltage range and is
suitable for direct powering from a 1-cell Li-ion/Li-Poly or a
3-cell series NiMH battery pack. The ISL6296A can also be
powered by the XSD bus when the bus pull-up voltage is
3.3V or higher. The device connects directly to the cell
terminals of a battery pack and includes on-chip voltage
regulation circuit, POR and a non-crystal based oscillator for
bus timing reference.
Communication with the host is achieved through a single-wire
XSD interface (a light-weight subset of Intersil’s ISD bus
interface). The XSD bus is compatible for use with serial ports
offered by all 8250 compatible UART’s or a single GPIO
(General Purpose Input and Output) pin of a microprocessor.
A clone prevention solution utilizing the ISL6296A offers
safety and revenue protection at the lowest cost and power
and is suitable for protection against after-market
replacement for a wide variety of low-cost applications.
Siderlee 发表于 2012-12-18 18:21 | 显示全部楼层
尽量从英文的角度去理解手册,如果写手册的人是英语母语的话
Ryanhsiung 发表于 2012-12-20 19:37 | 显示全部楼层
电池FlexiHash认证:
The ISL6296A is a highly cost-effective fixed-secret hash engine based on Intersil’s FlexiHash technology.
ISL6296A 是一款基于intersil 的flexihash技术,具有高性价比 fixed-secret hash加秘芯片。
The device’s authentication is achieved through a challenge response scheme, which is customized for low-cost applications where cloning via eavesdropping without knowledge of the device’s secret code is not economically viable.
器件的认证方式是通过效应机制来实现的。在低成本的应用中,再没有knowledge(密钥)情况下窃听不是那么容易的。
When used for its intended applications, the ISL6296A offers the same level of effectiveness as other significantly more expensive high maintenance monetarygrade hash algorithm   and   authentication schemes.
当做为替换其它加密芯片时,ISL6296A提供与其它芯片的一样的性能,并提供更加经济的hash算法与认证。
The ISL6296A has a wide operating voltage range and is suitable for direct powering from a 1-cell Li-ion/Li-Poly or a 3-cell series NiMH battery pack. The ISL6296A can also be powered by the XSD bus when the bus pull-up voltage is 3.3V or higher. The device connects directly to the cell terminals of a battery pack and includes on-chip voltage regulation circuit, POR and a non-crystal based oscillator for bus timing reference.
ISL6296具有宽的操作电压范围,可以直接由1节li-ion/li-poly 电池或者 3串mimh电池供电,ISL6296A能够由XSD总线(当XSD总线具有3.3v或者
更高的上拉)进行供电。器件可以直接连接到电池端,器件内包含一个片内电源管理器、POR和用于总线时序的非晶体振荡器。
Communication with the host is achieved through a single-wire XSD interface (a light-weight subset of Intersil’s ISD bus
interface).
与主机通信是通过一个单线的XSD总线,(intersil 公司的ISD总线接口的一个轻量级的子集)。
The XSD bus is compatible for use with serial ports offered by all 8250 compatible UART’s or a single GPIO (General Purpose Input and Output) pin of a microprocessor.
XSD总线可以由一个串口兼容实现(所有兼容8250串口)或者由微处理器的一个GPIO口(普通输入和输出)实现。
A clone prevention solution utilizing the ISL6296A offers safety and revenue protection at the lowest cost and power and is suitable for protection against after-market replacement for a wide variety of low-cost applications.
防克隆的解决方案:利用ISL6296提供的安全与接收保护(最低成本及最低功耗),适用于保护需要保护的各种替代。
Authentication:认证
Scheme: 策划、机制
Utilize:利用 使用
Revenue:收入
jfqjqs 发表于 2012-12-23 22:06 | 显示全部楼层
我的翻译如下,请各位参考:
非常低的电源电流消耗(每路运放在5V供电时为1mW), 且基本上与电源电压无关
lzqxs89 发表于 2012-12-25 16:38 | 显示全部楼层
高手原来是这样的练成的,学习了
yong61 发表于 2013-6-4 16:22 | 显示全部楼层
大虾!!
raysin 发表于 2013-9-26 13:22 | 显示全部楼层
电池FlexiHash认证:
The ISL6296A is a highly cost-effective ...
最后一句:
一个使用ISL6296的防克隆方案,只需最低成本和最低功耗就提供安全性和保证收入,适用于各种低成本电器以对抗代用商品。
raysin 发表于 2013-9-26 13:30 | 显示全部楼层
challenge response scheme = 挑战应答机制
lidongxin3 发表于 2013-10-4 17:51 | 显示全部楼层
非常小的电源损耗:———————— ...
嗯,有意思。
dota_yy 发表于 2014-1-14 13:38 | 显示全部楼层
南山隐士 发表于 2014-7-27 21:40 | 显示全部楼层
这个栏目不错,可以锻炼大家,赞一个
个人签名:有进步,嘿嘿。。
23
