最白痴的CH452驱动
2475|1
 楼主| devil110 发表于 2008-8-22 15:42 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define uchar unsigned char
#define uint  unsigned int
#define CH452_SYSON1    0x0401
//#define CH452_SYSON1  0x0409
#define CH452_BCD       0x0580
//#define CH452_BCD     0x0500
#define CH452_RESET     0x0201
#define CH452_DIG0      0x0800
#define CH452_DIG1      0x0900
#define CH452_DIG2      0x0a00
#define CH452_DIG3      0x0b00
#define CH452_DIG4      0x0c00
#define CH452_DIG5      0x0d00
#define CH452_DIG6      0x0e00
#define CH452_DIG7      0x0f00
sbit   CH452_DCLK  = P1^2;
sbit   CH452_DIN   = P1^3;
sbit   CH452_LOAD  = P1^5;
#define   CH452_DCLK_SET   {CH452_DCLK=1;}
#define   CH452_DCLK_CLR   {CH452_DCLK=0;}
#define   CH452_DIN_SET    {CH452_DIN=1;}
#define   CH452_DIN_CLR    {CH452_DIN=0;}
#define   CH452_LOAD_SET   {CH452_LOAD=1;}
#define   CH452_LOAD_CLR   {CH452_LOAD=0;}
void delay_2us(uchar con)
     for(;con!=0;con--);
void delay_30ms(void)
    uchar dms1;
    uchar dms2;
    for(dms1=119;dms1!=0;dms1--)
        for(dms2=15;dms2!=0;dms2--)
            delay_2us(1);
void CH452_Write(uint cmd)
    uchar i;
    CH452_LOAD_CLR;
         CH452_DCLK_CLR;
    for(i=12;i!=0;i--)
           CH452_DIN=cmd&1;
                 CH452_DCLK_SET;
                 cmd=cmd>>1;
                   CH452_DCLK_CLR;
    CH452_LOAD_SET;
    delay_2us(3);
void main()
    //初始化
    CH452_Write(CH452_RESET);
    delay_30ms();                         //延迟30ms
    CH452_Write(CH452_SYSON1);             //开启显示
    while (1)
        //"|"后面为显示内容,具体参考DATASHEET
        CH452_Write(CH452_DIG7 | 0x01);
        CH452_Write(CH452_DIG6 | 0x02);
        CH452_Write(CH452_DIG5 | 0x03);
        CH452_Write(CH452_DIG4 | 0x04);
        CH452_Write(CH452_DIG3 | 0x01);
        CH452_Write(CH452_DIG2 | 0x02);
        CH452_Write(CH452_DIG1 | 0x03);
        CH452_Write(CH452_DIG0 | 0x04);
//去官网下了个驱动,感觉太多了,自己搞了个比较少的,写得不是很好!
//不过还好用哈!
//唯一的问题是,空白处有淡淡的重影,有谁知道怎么回事呀,难道是片子的病.
相关链接:https://bbs.21ic.com/upfiles/img/200710/2007107155839645.pdf
 楼主| devil110 发表于 2008-8-25 10:07 | 显示全部楼层
有错误都没有人知道?
CH452_Write(CH452_BCD);
相关链接:https://bbs.21ic.com/upfiles/img/200710/2007101010229617.pdf
