- static DMA_InitTypeDef DMA_InitStructureTx;
- static DMA_InitTypeDef DMA_InitStructureRx;
- static SPI_InitTypeDef SPI_InitStructure;
- static void NVIC_Configuration(void)
- NVIC_InitTypeDef NVIC_InitStructure;
- /* Configure the SPI interrupt priority */
- NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream2_IRQn;//spi1 rx;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream3_IRQn;//spi1 tx;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- static void SPI_RCC_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
- /*!< Connect SPI pins to AF5 */
- GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_SPI1);
- GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);
- GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);
- GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1);
- // NSS CLK MISO
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* MOSI
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
- /* SPI configuration -------------------------------------------------------*/
- SPI_I2S_DeInit(SPI1);
- SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
- SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
- SPI_InitStructure.SPI_CRCPolynomial = 7;
- SPI_CalculateCRC(SPI1,DISABLE);
- SPI_Init(SPI1, &SPI_InitStructure);
- SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);
- SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE);
- SPI_Cmd(SPI1, ENABLE); /* 使能SPI */
- void DMA_Config(void)
- //发送通道
- DMA_DeInit(DMA2_Stream3);
- DMA_InitStructureTx.DMA_Channel = DMA_Channel_3;
- DMA_InitStructureTx.DMA_PeripheralBaseAddr =(u32)&SPI1->DR;//SPI1的DR寄存器地址
- DMA_InitStructureTx.DMA_Memory0BaseAddr = 0;//(u32)SPI1_TX_Buf;
- DMA_InitStructureTx.DMA_DIR = DMA_DIR_MemoryToPeripheral;
- DMA_InitStructureTx.DMA_BufferSize = 1;
- DMA_InitStructureTx.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructureTx.DMA_MemoryInc = DMA_MemoryInc_Enable; //DMA内存地址自动增加模式
- DMA_InitStructureTx.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
- DMA_InitStructureTx.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
- DMA_InitStructureTx.DMA_Mode = DMA_Mode_Normal;
- DMA_InitStructureTx.DMA_Priority = DMA_Priority_Low;
- DMA_InitStructureTx.DMA_FIFOMode = DMA_FIFOMode_Disable;
- DMA_InitStructureTx.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull;
- DMA_InitStructureTx.DMA_MemoryBurst = DMA_MemoryBurst_Single;
- DMA_InitStructureTx.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
- DMA_Init(DMA2_Stream3, &DMA_InitStructureTx);
- DMA_ITConfig(DMA2_Stream3, DMA_IT_TC, ENABLE);
- DMA_Cmd(DMA2_Stream3, DISABLE);
- //接收通道
- DMA_DeInit(DMA2_Stream2);
- DMA_InitStructureRx.DMA_Channel = DMA_Channel_3;
- DMA_InitStructureRx.DMA_PeripheralBaseAddr =(u32)&SPI1->DR;//SPI2的DR寄存器地址
- DMA_InitStructureRx.DMA_Memory0BaseAddr = 0;//(u32)SPI2_RX_Buf;
- DMA_InitStructureRx.DMA_DIR = DMA_DIR_PeripheralToMemory;
- DMA_InitStructureRx.DMA_BufferSize = 10;
- DMA_InitStructureRx.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructureRx.DMA_MemoryInc = DMA_MemoryInc_Enable; //DMA内存地址自动增加模式
- DMA_InitStructureRx.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
- DMA_InitStructureRx.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
- DMA_InitStructureRx.DMA_Mode = DMA_Mode_Normal;
- DMA_InitStructureRx.DMA_Priority = DMA_Priority_High;
- DMA_InitStructureRx.DMA_FIFOMode = DMA_FIFOMode_Disable;
- DMA_InitStructureRx.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull;
- DMA_InitStructureRx.DMA_MemoryBurst = DMA_MemoryBurst_Single;
- DMA_InitStructureRx.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
- DMA_Init(DMA2_Stream2, &DMA_InitStructureRx);
- /* Enable SPI DMA Tx request */
- DMA_ITConfig(DMA2_Stream2, DMA_IT_TC, ENABLE);
- DMA_Cmd(DMA2_Stream2, DISABLE);
- DMA_ClearFlag(DMA2_Stream2,DMA_FLAG_TCIF2); //清DMA发送完成标志
- DMA_ClearFlag(DMA2_Stream3,DMA_FLAG_TCIF3); //清DMA发送完成标志
- int dummy[2];
- //dir =0 接收data = 1 发送pcm
- void DMA_Transmit(u32 addr, u32 size, u8 dir)
- if (dir==1)
- {//发送 tx
- DMA_InitStructureTx.DMA_Memory0BaseAddr = addr;
- DMA_InitStructureTx.DMA_BufferSize = size;
- DMA_Cmd(DMA2_Stream3, ENABLE);
- else
- {//接收 rx
- DMA_InitStructureRx.DMA_Memory0BaseAddr = addr;
- DMA_InitStructureRx.DMA_BufferSize = size;
- DMA_Cmd(DMA2_Stream2, ENABLE);
- unsigned char SPI_TX_Buf[10005];
- unsigned char SPI_RX_Buf[10005];
- void rt_hw_spi_init(void)
- SPI_RCC_GPIO_Config();
- NVIC_Configuration();
- DMA_Config();
- DMA_Transmit((u32)SPI_RX_Buf, sizeof(SPI_RX_Buf)-5, 0);
- void DMA2_Stream2_IRQHandler(void)//rx 主机发送
- /* Check the interrupt source */
- if (DMA_GetITStatus(DMA2_Stream2,DMA_FLAG_TCIF2)==SET)
- DMA_ClearITPendingBit(DMA2_Stream2,DMA_FLAG_TCIF2|DMA_FLAG_TEIF2);
- rt_kprintf(" spi rx done!\r\n");
- void DMA2_Stream3_IRQHandler(void)//tx 主机接收
- if (DMA_GetITStatus(DMA2_Stream3,DMA_FLAG_TCIF3)==SET)
- DMA_ClearITPendingBit(DMA2_Stream3,DMA_FLAG_TCIF3|DMA_FLAG_TEIF3);
- rt_kprintf(" spi tx done!\r\n");
