调试EKK-8962在debug时出现错误
1235|0
 楼主| wyjie 发表于 2013-4-14 22:21 | 显示全部楼层 |阅读模式
调试EKK-8962时,IDE为CCS4.2.4,在debug时出现如下的错误:
CORTEX_M3_0: Error connecting to the target: The target board you are attempting to connect to does not appear to be a Stellaris IDK and is not supported with this license. This license may only be used with the development board that is included with Stellaris IDKs bundled with Code Composer Studio.
