[ISE] xilin下载求教?
4105|1
 楼主| ljihai 发表于 2007-2-28 22:46 | 显示全部楼层 |阅读模式
AN, TI, IO, AC, Power
<br />在安装时&quot;select&nbsp;xilinx&nbsp;modules&quot;&nbsp;全选择(用并口下载线,用的ise&nbsp;6.2)<br />xilinx下载时能找到并口设备,但出现下列问题:<br />ERROR:iMPACT:585&nbsp;-&nbsp;A&nbsp;problem&nbsp;may&nbsp;exist&nbsp;in&nbsp;the&nbsp;hardware&nbsp;configuration.<br />&nbsp;&nbsp;&nbsp;&nbsp;Check&nbsp;that&nbsp;the&nbsp;cable,&nbsp;scan&nbsp;chain,&nbsp;and&nbsp;power&nbsp;connections&nbsp;are&nbsp;intact,<br />&nbsp;&nbsp;&nbsp;&nbsp;that&nbsp;the&nbsp;specified&nbsp;scan&nbsp;chain&nbsp;configuration&nbsp;matches&nbsp;the&nbsp;actual&nbsp;hardware,&nbsp;and<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;that&nbsp;the&nbsp;power&nbsp;supply&nbsp;is&nbsp;adequate&nbsp;and&nbsp;delivering&nbsp;the&nbsp;correct&nbsp;voltage.<br />是什么原因?用usb接口的也是这样.是否还需要并口的其他驱动程序.<br />&nbsp;<br />
huanbao286 发表于 2007-3-1 23:55 | 显示全部楼层
换台机器试试
可能是并口的问题<br />遇到过,未找到解决方法
