msp430g2553的I2C通信,
2473|6
 楼主| 孙大为1 发表于 2013-7-31 12:31 | 显示全部楼层 |阅读模式
官网给的的主机发送例程,调试时候停在开低功耗之后,始终没有触发发送中断,求指点迷津
#include "msp430g2553.h"
unsigned char TXData;
unsigned char TXByteCtr;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1SEL |= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  P1SEL2|= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
  UCB0BR1 = 0;
  UCB0I2CSA = 0x48;                         // Slave Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  IE2 |= UCB0TXIE;                          // Enable TX interrupt
  TXData = 0x00;                            // Holds TX data
  while (1)
    TXByteCtr = 1;                          // Load TX byte counter
    while (UCB0CTL1 & UCTXSTP);             // Ensure stop condition got sent
    UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
    __bis_SR_register(CPUOFF + GIE);        // Enter LPM0 w/ interrupts
                                            // Remain in LPM0 until all data
                                            // is TX'd
    TXData++;                               // Increment data byte
// The USCIAB0TX_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count.
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
  if (TXByteCtr)                            // Check TX byte counter
    UCB0TXBUF = TXData;                     // Load TX buffer
    TXByteCtr--;                            // Decrement TX byte counter
  else
    UCB0CTL1 |= UCTXSTP;                    // I2C stop condition
    IFG2 &= ~UCB0TXIFG;                     // Clear USCI_B0 TX int flag
    __bic_SR_register_on_exit(CPUOFF);      // Exit LPM0
 楼主| 孙大为1 发表于 2013-7-31 12:37 | 显示全部楼层
忘记说了,是在launchpad板子上调试的
1988020566 发表于 2013-7-31 23:57 | 显示全部楼层
一般用模拟的 !
评分
参与人数 1威望 +1 收起 理由
孙大为1 + 1 赞一个!
查看全部评分
1988020566 发表于 2013-7-31 23:58 | 显示全部楼层
lkl0305 发表于 2014-4-7 09:45 | 显示全部楼层
学习了
