我在用xilinx的FPGA进行相关项目的设计,只有在生成编程文件的时候会有错误报告,我在前面进行布局布线的时候有个错误信息如下 Place:848 - Automatic clock placement failed. Please attempt to analyze the global clocking required for this<br /> design and either lock the clock placement or area locate the logic driven by the clocks so that that the clocks may<br /> be placed in such a way that all logic driven by them may be routed. The main restriction on clock placement is that<br /> only one clock output signal for any competing Global / Side pair of clocks may enter any region. For further<br /> information see the "Quadrant Clock Routing" section in the Spartan3e Family Datasheet.<br /><br /> The competing Global / Side clock buffers for this device are as follows: <br /> Global : Side <br /> BUFGMUX_X1Y10 : BUFGMUX_X0Y9<br /> BUFGMUX_X1Y10 : BUFGMUX_X3Y9<br /> BUFGMUX_X1Y11 : BUFGMUX_X0Y8<br /> BUFGMUX_X1Y11 : BUFGMUX_X3Y8<br /> BUFGMUX_X2Y10 : BUFGMUX_X0Y7<br /> BUFGMUX_X2Y10 : BUFGMUX_X3Y7<br /> BUFGMUX_X2Y11 : BUFGMUX_X0Y6<br /> BUFGMUX_X2Y11 : BUFGMUX_X3Y6<br /> BUFGMUX_X1Y0 : BUFGMUX_X0Y5<br /> BUFGMUX_X1Y0 : BUFGMUX_X3Y5<br /> BUFGMUX_X1Y1 : BUFGMUX_X0Y4<br /> BUFGMUX_X1Y1 : BUFGMUX_X3Y4<br /> BUFGMUX_X2Y0 : BUFGMUX_X0Y3<br /> BUFGMUX_X2Y0 : BUFGMUX_X3Y3<br /> BUFGMUX_X2Y1 : BUFGMUX_X0Y2<br /> BUFGMUX_X2Y1 : BUFGMUX_X3Y2<br />哪位大虾帮忙解决一下告诉我是怎么回事怎么解决它,困扰了很长时间了。注我没有添加任何的约束信息。完全是软件默认设置。 |
