AT91SAM7S256芯片与温度传感器的I2C通信,我向传感器的寄存器写值,并把它读出来,但不知道为什么,我用的是KEIL 4,单步调试有问题,程序执行调用函数时,调用完子函数后,它返回不了原来的地方,而是继续往子函数下执行,是我代码有问题吗?请各位帮忙分析一下,我新手刚学,快焦头烂额了,谢谢各位好心人啊。。。。- init_twi(void)
- // Configure PIO controllers to periph mode, in open drain
- AT91F_TWI_CfgPIO();
- AT91F_PIO_CfgOpendrain(AT91C_BASE_PIOA,AT91C_PA3_TWD | AT91C_PA4_TWCK);
- // AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, 1 << AT91C_ID_PIOA ) ;
- AT91F_TWI_CfgPMC();
- AT91F_TWI_DisableIt(AT91C_BASE_TWI,0xFFFFFFFF); // Disable TWI IT
- AT91F_TWI_Configure(AT91C_BASE_TWI); // Configure TWI in master mode
- uint32_t MLX620_I2C_Driver_WriteRead(AT91PS_TWI pTWI,uint8_t *pWriteData,uint8_t *pReadData)
- int i;
- AT91C_BASE_TWI->TWI_CWGR = 0x40f0f;
- pTWI->TWI_CR = AT91C_TWI_MSEN;
- pTWI->TWI_MMR = (AT91C_TWI_IADRSZ_NO | (!AT91C_TWI_MREAD) | AT91C_TWI_DADR); //AT91C_TWI_DADR已经为从器件的地址了
- pTWI->TWI_IADR = 0x0; //INTERNAL ADDRESS
- pTWI->TWI_THR =*pWriteData++;
- pTWI->TWI_CR = AT91C_TWI_START; //start
- while(pTWI->TWI_SR&0x4==0 ){};
- for(i=0;i<3;i++){
- pTWI->TWI_THR=*pWriteData++;
- // must have a short delay when corresponding to the at24c02
- time_dly(100);
- //pTWI->TWI_CR = AT91C_TWI_STOP ; //stop
- // while(pTWI->TWI_SR&0x1==0){};
- AT91C_BASE_TWI->TWI_CR = AT91C_TWI_MSEN ;
- pTWI->TWI_MMR = (AT91C_TWI_IADRSZ_NO | AT91C_TWI_MREAD | AT91C_TWI_DADR);
- pTWI->TWI_CR |= AT91C_TWI_START; //start
- while((pTWI->TWI_SR & 0x2) == 0 ){};
- *pReadData++ = pTWI->TWI_RHR;
- time_dly(100);
- pTWI->TWI_CR |= AT91C_TWI_STOP; //stop
- while((pTWI->TWI_SR & 0x1) == 0){};
- uint32_t MLX620_I2C_Driver_Write(AT91PS_TWI pTWI, uint8_t *pData)
- int i;
- pTWI->TWI_THR =*pData++;
- for(i=0;i<4;i++){ //start
- time_dly(100);
- pTWI->TWI_CR = AT91C_TWI_STOP ; //stop
- while(pTWI->TWI_SR&0x1==0){};
- uint8_t MLX620_ReadRAM(uint8_t startAddr,
- uint8_t addrStep,
- uint8_t nWords,
- uint8_t *pData)
- uint8_t writeBuffer[] = {MLX620_CMD_READ,0,0,0};
- writeBuffer[1]=startAddr;
- writeBuffer[2]=addrStep;
- writeBuffer[3]=nWords;
- return MLX620_I2C_Driver_WriteRead(AT91C_BASE_TWI,writeBuffer, pData);
- uint8_t MLX620_WriteTrim(uint16_t trimReg)
- uint8_t pOut[] = {MLX620_CMD_WRITE_TRIM,0,0,0,0};
- pOut[1]=(uint8_t)((trimReg & 0xFF) - 0xAA);
- pOut[2]=(uint8_t)(trimReg & 0xFF);
- pOut[3]=(uint8_t)((trimReg >> 8) - 0xAA);
- pOut[4]=(uint8_t)(trimReg >> 8);
- MLX620_I2C_Driver_Write(AT91C_BASE_TWI,pOut);
- uint8_t MLX620_ReadTrim (uint16_t *pTrimReg)
- return (MLX620_ReadRAM(MLX620_RAM_TRIM,
- 0,
- sizeof(uint16_t),
- (uint8_t*)pTrimReg));
- int main()
- uint16_t *trim;
- init_twi();
- MLX620_WriteTrim(0x740E);
- MLX620_ReadTrim(trim);
- do
- }while(1);
