[程序源码] MFRC531和ISO14443卡通讯的代码有些不明白
2028|0
 楼主| new_year 发表于 2013-10-14 20:59 | 显示全部楼层 |阅读模式
MFRC531和ISO14443卡通讯
MFRC531和ISO14443卡通讯
// input: pi->MfCommand = RC531命令字
//        pi->MfLength  = 发送的数据长度
//        pi->MfData[]  = 发送数据
// output:status        = 错误字
//        pi->MfLength  = 接收的数据BIT长度
//        pi->MfData[]  = 接收数据
signed char MFRC531_ISO14443_Transceive(struct TransceiveBuffer *pi)
   unsigned char recebyte = 0;
   signed char status;
   unsigned char irqEn   = 0x00;
   unsigned char waitFor = 0x00;
   unsigned char lastBits;
   unsigned char n;
   unsigned int i;
   switch (pi->MfCommand)
      case PCD_IDLE:
         irqEn   = 0x00;
         waitFor = 0x00;
         break;
      case PCD_WRITEE2:
         irqEn   = 0x11;
         waitFor = 0x10;
         break;
      case PCD_READE2:
         irqEn   = 0x07;
         waitFor = 0x04;
         recebyte=1;
         break;
      case PCD_LOADCONFIG:
      case PCD_LOADKEYE2:
      case PCD_AUTHENT1:
         irqEn   = 0x05;
         waitFor = 0x04;
         break;
      case PCD_CALCCRC:
         irqEn   = 0x11;
         waitFor = 0x10;
         break;
      case PCD_AUTHENT2:
         waitFor = 0x04;
         break;
         irqEn   = 0x04;
      case PCD_RECEIVE:
         irqEn   = 0x06;
         waitFor = 0x04;
         recebyte=1;
         break;
      case PCD_LOADKEY:
         irqEn   = 0x05;
         waitFor = 0x04;
         break;
      case PCD_TRANSMIT:
         irqEn   = 0x05;
         waitFor = 0x04;
         break;
      case PCD_TRANSCEIVE:    // this one
         irqEn   = 0x3D;
         waitFor = 0x04;
         recebyte=1;
         break;
      default:
         pi->MfCommand = MI_UNKNOWN_COMMAND;
         break;
if (pi->MfCommand != MI_UNKNOWN_COMMAND)
      MFRC531_WriteReg(RegPage1,0x00);
      MFRC531_WriteReg(RegInterruptEn,0x7F);
      MFRC531_WriteReg(RegInterruptRq,0x7F);
      MFRC531_WriteReg(RegCommand,PCD_IDLE);
      MFRC531_SetBitMask(RegControl,0x01);  // Clear FIFO
      MFRC531_WriteReg(RegInterruptEn,irqEn|0x80);
      for (i=0; i<pi->MfLength; i++)
         MFRC531_WriteReg(RegFIFOData, pi->MfData); //将数据写入fifo
      MFRC531_WriteReg(RegCommand, pi->MfCommand);  //将命令写入command
      i = 0x3500;
      do
         n = MFRC531_ReadReg(RegInterruptRq);
         i--;
      }while ((i!=0) && !(n&irqEn&0x20) && !(n&waitFor));    //这个while循环的条件是怎么控制的,什么意思??????
