//#include "stm32f10x_lib.h"
#include "stm32f10x.h"
#include "stdio.h"
extern void SystemInit(void);
void NVIC_Configuration(void);
//void delay_ms(u16 nms);
void GPIO_Configuration(void);
void USART_Configuration(void);
int main(void)
unsigned char Buffer[]="i need you";
u16 i;
SystemInit();
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
NVIC_Configuration();
GPIO_Configuration();
USART_Configuration();
printf("\r\n this is a printf demo \r\n");
for(i=0;Buffer[i]!='\0';i++)
USART_SendData(USART1,Buffer[i]);
while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET);
while(1)
* Function Name : Delay
* Description : Inserts a delay time.
* Input : nCount: specifies the delay time length.
* Output : None
* Return : None
void GPIO_Configuration(void)//自己定义的函数
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
// u32 temp;
// nms=0;
// SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8); //选择外部时钟 HCLK/8
// //fac_us=SystemCoreClock/8000000; //为系统时钟的1/8
// nms=SystemCoreClock/8000;//非ucos下,代表每个ms需要的systick时钟数
// SysTick->LOAD = 9000*nms; //输入的nms即为延时多少ms
// SysTick->VAL=0X00;//清空计数器
// SysTick->CTRL=0X01;//使能,减到零是无动作,采用外部时钟源
// do
// temp=SysTick->CTRL;//读取当前倒计数值
// }while((temp&0x01)&&(!(temp&(1<<16))));//等待时间到达
// SysTick->CTRL=0x00; //关闭计数器
// SysTick->VAL =0X00; //清空计数器
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
USART_InitTypeDef USART_InitStructure;
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;//或者设为2位,参看手册
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl =USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
// USART_InitStructure.USART_Clock = USART_Clock_Disable;
// USART_InitStructure.USART_CPOL = USART_CPOL_High;
// USART_InitStructure.USART_CPHA = USART_CPHA_1Edge;
// USART_InitStructure.USART_LastBit = USART_LastBit_Enable;
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);//很容易丢失 勿忘
int fputc(int ch, FILE *f)
/* Write a character to the USART */
USART_SendData(USART1,(u8)ch);
/* Loop until the end of transmission */
while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
return ch;
软件调试,全速运行能在USART1窗口中看到输出,但是超级终端上就是看不到?纠结几天了,遇到过的给指导下吧 |
